1 #ifndef __CS_HHO_VECTEQ_H__ 2 #define __CS_HHO_VECTEQ_H__ 61 typedef struct _cs_hho_vecteq_t cs_hho_vecteq_t;
273 void *scheme_context);
289 void *scheme_context);
time step descriptor
Definition: cs_time_step.h:64
cs_real_t * cs_hho_vecteq_get_cell_values(void *data, bool previous)
Get the computed values at cells (DoF used in the linear system are located at primal faces) ...
Definition: cs_hho_vecteq.c:1560
void cs_hho_vecteq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Read additional arrays (not defined as fields) but useful for the checkpoint/restart process...
Definition: cs_hho_vecteq.c:1586
cs_real_t * cs_hho_vecteq_get_face_values(void *data, bool previous)
Get the computed values at faces (DoF used in the linear system are located at primal faces) ...
Definition: cs_hho_vecteq.c:1533
void cs_hho_vecteq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values required for ...
Definition: cs_hho_vecteq.c:1402
void cs_hho_vecteq_finalize_sharing(void)
Free buffers and generic structures related to HHO schemes.
Definition: cs_hho_vecteq.c:716
void cs_hho_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued HHO schemes.
Definition: cs_hho_vecteq.c:969
void cs_hho_vecteq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Write additional arrays (not defined as fields) but useful for the checkpoint/restart process...
Definition: cs_hho_vecteq.c:1668
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
Definition: cs_hho_builder.h:54
void cs_hho_vecteq_init_sharing(cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to HHO schemes Set shared pointers.
Definition: cs_hho_vecteq.c:591
Definition: cs_restart.h:93
void * cs_hho_vecteq_free_context(void *data)
Destroy a cs_hho_vecteq_t structure.
Definition: cs_hho_vecteq.c:931
void cs_hho_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
Definition: cs_hho_vecteq.c:693
Definition: cs_cdo_local.h:60
void cs_hho_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_hho_vecteq.c:1729
void * cs_hho_vecteq_init_context(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_hho_vecteq_t structure storing data useful for managing such a scheme.
Definition: cs_hho_vecteq.c:755
double precision, dimension(:,:), allocatable solu
Definition: atincl.f90:321
void cs_hho_vecteq_compute_source(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Compute the contributions of source terms (store inside builder)
Definition: cs_hho_vecteq.c:1015
unsigned short int cs_flag_t
Definition: cs_defs.h:324
void cs_hho_vecteq_build_system(const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme...
Definition: cs_hho_vecteq.c:1111
