#include "cs_defs.h"#include <assert.h>#include <string.h>#include <bft_mem.h>#include "cs_advection_field.h"#include "cs_array_reduce.h"#include "cs_cdo_quantities.h"#include "cs_equation.h"#include "cs_equation_param.h"#include "cs_gwf.h"#include "cs_log.h"#include "cs_log_iteration.h"#include "cs_maxwell.h"#include "cs_navsto_system.h"#include "cs_parall.h"#include "cs_post.h"#include "cs_property.h"#include "cs_prototypes.h"#include "cs_restart.h"#include "cs_restart_default.h"#include "cs_solidification.h"#include "cs_walldistance.h"#include "cs_domain_op.h"
Include dependency graph for cs_domain_op.c:Functions | |
| void | cs_f_cdo_post_domain (void) |
| Solve only steady-state equations. More... | |
| static bool | _needs_adimensional_numbers (void) |
| Check if one needs to compute at least one adimensional number. More... | |
| static void | _analyze_cell_array (const cs_cdo_quantities_t *cdoq, const char basename[], const cs_real_t array[]) |
| Compute very simple statistic for an array with values located at cells (scalar-valued) More... | |
| static void | _post_courant_number (const cs_adv_field_t *adv, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step) |
| Predefined Courant number post-processing for advection fields. More... | |
| static void | _post_peclet_number (const cs_equation_t *eq, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step) |
| Predefined Peclet number post-processing for an equation. More... | |
| static void | _post_fourier_number (const cs_property_t *pty, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step) |
| Predefined Fourier number post-processing for a property. More... | |
| static void | _domain_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step) |
| Predefined post-processing output for the computational domain The prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More... | |
| void | cs_domain_post_init (cs_domain_t *domain) |
| Initialize the generic post-processing related to a domain. More... | |
| void | cs_domain_post (cs_domain_t *domain) |
| Post-processing of the computational domain after a resolution. More... | |
| void | cs_domain_read_restart (cs_domain_t *domain) |
| Read a restart file for the CDO/HHO module. More... | |
| void | cs_domain_write_restart (const cs_domain_t *domain) |
| Write a restart file for the CDO/HHO module. More... | |
static |
| [in] | cdoq | pointer to a cs_cdo_quantities_t struct. |
| [in] | basename | label for output in the log |
| [in] | array | pointer to the array to analyze |
static |
static |
static |
| [in] | adv | pointer to a cs_adv_field_t structure |
static |
| [in] | pty | pointer to a cs_property_t structure |
static |
| [in] | eq | pointer to a cs_equation_t structure |
| void cs_domain_post | ( | cs_domain_t * | domain | ) |
| [in] | domain | pointer to a cs_domain_t structure |
| void cs_domain_post_init | ( | cs_domain_t * | domain | ) |
| void cs_domain_read_restart | ( | cs_domain_t * | domain | ) |
| void cs_domain_write_restart | ( | const cs_domain_t * | domain | ) |
| void cs_f_cdo_post_domain | ( | void | ) |
