1 #ifndef __CS_RESTART_DEFAULT_H__ 2 #define __CS_RESTART_DEFAULT_H__
Definition: cs_restart_default.h:57
Definition: cs_restart_default.h:59
Definition: cs_restart_default.h:58
void cs_restart_write_variables(cs_restart_t *r, int t_id_flag, int write_flag[])
Write variables to checkpoint.
Definition: cs_restart_default.c:2094
void cs_restart_write_field_info(cs_restart_t *r)
Write field metadata to main checkpoint.
Definition: cs_restart_default.c:1852
Definition: cs_restart_default.h:66
struct _cs_map_name_to_id_t cs_map_name_to_id_t
Definition: cs_map.h:48
Definition: cs_restart_default.h:64
void cs_restart_read_time_step_info(cs_restart_t *r)
Read restart time step info.
Definition: cs_restart_default.c:2959
Definition: cs_restart.h:93
void cs_restart_read_variables(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[])
Read variables from checkpoint.
Definition: cs_restart_default.c:1934
int cs_restart_write_linked_fields(cs_restart_t *r, const char *key, int write_flag[])
Write fields depending on others to checkpoint.
Definition: cs_restart_default.c:2404
void cs_restart_write_bc_coeffs(cs_restart_t *r)
Write boundary condition coefficients for all fields to checkpoint.
Definition: cs_restart_default.c:2654
Definition: cs_restart_default.h:61
void cs_restart_read_bc_coeffs(cs_restart_t *r)
Read boundary condition coefficients for all fields from checkpoint.
Definition: cs_restart_default.c:2498
void cs_restart_read_linked_fields(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[])
Read fields depending on others from checkpoint.
Definition: cs_restart_default.c:2230
void cs_restart_read_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and read them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.c:3059
void cs_restart_read_field_info(cs_restart_t *r, cs_map_name_to_id_t **old_field_map)
Read field metadata from checkpoint.
Definition: cs_restart_default.c:1712
Definition: cs_restart_default.h:56
Definition: cs_restart_default.h:62
Definition: cs_restart_default.h:67
cs_restart_file_t
Definition: cs_restart_default.h:54
void cs_restart_write_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and save them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.c:3034
int cs_restart_read_field_vals(cs_restart_t *r, int f_id, int t_id)
Read field values from checkpoint.
Definition: cs_restart_default.c:2768
void cs_restart_write_field_vals(cs_restart_t *r, int f_id, int t_id)
Write field values to checkpoint.
Definition: cs_restart_default.c:2933
