7.1
cs_mesh_cartesian.c File Reference
#include "cs_block_dist.h"
#include "cs_math.h"
#include "cs_mesh_builder.h"
#include "cs_mesh_cartesian.h"
+ Include dependency graph for cs_mesh_cartesian.c:
cs_mesh_cartesian_params_t * cs_mesh_cartesian_get_params (void)
 Return pointer to cartesian mesh parameters structure. More...
void cs_mesh_cartesian_create (void)
 Create cartesian mesh structure. More...
void cs_mesh_cartesian_define_simple (int ncells[3], cs_real_t xyz[6])
 Define a simple cartesian mesh with a constant step in all directions. More...
void cs_mesh_cartesian_define_dir_user (int idir, int ncells, cs_real_t vtx_coord[])
 Define directions parameters based on a user input. More...
void cs_mesh_cartesian_define_dir_geom_by_part (int idir, int n_parts, const cs_real_t part_coords[], const cs_lnum_t n_part_cells[], const cs_real_t amp_factors[])
 Define direction parameters based on a piecewise definition. Each part follows a geometric (or uniform) sequence. To get the uniform sequence, set the amplification factor to 1 in the wanted part. More...
void cs_mesh_cartesian_define_from_csv (const char *csv_file_name)
 Define a simple cartesian mesh based on a CSV file. CSV file needs to contain : (1) First line which is empty or contains a header (2) Second line containing number of vertices per direction: format is 'nx;ny;nz' (3) Third line is empty or contains a header (4) Fourth line and onwards contains vertices coordinates for each direction. Format is "X1[i];X2[i];X3[i]" for index i. If current vertex index is beyond max value for a given direction, an empty value is expected. For example, if for index 'j' the first direction is empty, format is : ';X2[j];X3[j]'. More...
void cs_mesh_cartesian_define_dir_params (int idim, cs_mesh_cartesian_law_t law, int ncells, cs_real_t smin, cs_real_t smax, cs_real_t progression)
 Define parameters for a given direction. More...
int cs_mesh_cartesian_need_build (void)
 Indicate if a cartesian mesh is to be built. More...
int cs_mesh_cartesian_get_ncells (int idim)
 Get number of cells in a given direction. More...
void cs_mesh_cartesian_connectivity (cs_mesh_t *m, cs_mesh_builder_t *mb, long echo)
 Build unstructured connectivity needed for partitionning. More...
void cs_mesh_cartesian_params_destroy (void)
 Destroy cartesian mesh parameters. More...
◆ cs_mesh_cartesian_connectivity()
void cs_mesh_cartesian_connectivity ( cs_mesh_t m,
cs_mesh_builder_t mb,
long  echo
[in]mpointer to cs_mesh_t structure
[in]mbpointer to cs_mesh_builder_t structure
[in]echoverbosity flag
◆ cs_mesh_cartesian_create()
void cs_mesh_cartesian_create ( void  )
◆ cs_mesh_cartesian_define_dir_geom_by_part()
void cs_mesh_cartesian_define_dir_geom_by_part ( int  idir,
int  n_parts,
A direction is split in several parts. Each part contains a number of cells, its starting and ending position (stored in a compact way) inside part_coords, the amplification factor (f) between the first and last cell size of each part. Notice that if f = 1, this leads to a uniform refinement. If f > 1, (resp f < 1) this leads to a growing (resp. decreasing) geometric progression of the cell size when moving along the direction of increasing coordinates.
[in]idirDirection index. 0->X, 1->Y, 2->Z
[in]n_partsNumber of parts to define the direction
[in]part_coordsPosition delimiting each part (size = n_parts + 1)
[in]n_part_cellsNumber of cells in each part (size = n_parts)
[in]amp_factorsAmplification factor in each part (size = n_parts)
◆ cs_mesh_cartesian_define_dir_params()
void cs_mesh_cartesian_define_dir_params ( int  idim,
int  ncells,
cs_real_t  smin,
cs_real_t  smax,
[in]idimGeometrical direction: 0->X, 1->Y, 2->Z
[in]law1D discretization law: constant, geometric or parabolic
[in]ncellsNumber of cells for this direction
[in]sminMin coordinate value for this direction
[in]smaxMax coordinate value for this direction
[in]progressionProgression value, only used for geometric or parabolic laws.
◆ cs_mesh_cartesian_define_dir_user()
void cs_mesh_cartesian_define_dir_user ( int  idir,
int  ncells,
[in]ncellsNumber of cells for the direction
[in]vtx_coordArray of size ncells+1 containing 1D coordinate values for vertices on the given direction
◆ cs_mesh_cartesian_define_from_csv()
void cs_mesh_cartesian_define_from_csv ( const char *  csv_file_name)
[in]csv_file_namename of CSV file containing mesh information.
◆ cs_mesh_cartesian_define_simple()
void cs_mesh_cartesian_define_simple ( int  ncells[3],
cs_real_t  xyz[6]
[in]ncellsArray of size 3 containing number of cells in each direction
[in]xyzArray of size 6 containing min values, followed by max values for the three directions.
◆ cs_mesh_cartesian_get_ncells()
int cs_mesh_cartesian_get_ncells ( int  idim)
[in]idimIndex of direction: 0->X, 1->Y, 2->Z
Number of cells in corresponding direction (int)
◆ cs_mesh_cartesian_get_params()
cs_mesh_cartesian_params_t* cs_mesh_cartesian_get_params ( void  )
pointer to cs_mesh_cartesian_params_t structure
◆ cs_mesh_cartesian_need_build()
int cs_mesh_cartesian_need_build ( void  )
1 if mesh needs to be built, 0 otherwise
◆ cs_mesh_cartesian_params_destroy()
void cs_mesh_cartesian_params_destroy ( void  )
