Include dependency graph for cs_gwf_tracer.h:Go to the source code of this file.
| struct | cs_gwf_tracer_context_t |
| struct | cs_gwf_tracer_t |
| typedef cs_flag_t | cs_gwf_tracer_model_t |
| typedef void() | cs_gwf_tracer_update_t(cs_gwf_tracer_t *tracer, cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Generic function to update the phisical properties related to a tracer modelling. More... | |
| typedef void() | cs_gwf_tracer_free_context_t(cs_gwf_tracer_t *tracer) |
| Generic function to free the input of a tracer model. More... | |
| typedef void() | cs_gwf_tracer_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, const cs_real_t *l_saturation, cs_gwf_tracer_t *tracer) |
| Generic function to set the parameters related to a tracer equation. More... | |
| typedef void() | cs_gwf_tracer_add_terms_t(cs_gwf_tracer_t *tracer) |
| Generic function to update the terms to build in the algebraic system for a tracer equation according to the settings. More... | |
Enumerations | |
| enum | cs_gwf_tracer_model_bit_t { CS_GWF_TRACER_USER = 1<< 0, CS_GWF_TRACER_SORPTION_EK_3_PARAMETERS = 1<< 1, CS_GWF_TRACER_SORPTION_EK_5_PARAMETERS = 1<< 2, CS_GWF_TRACER_PRECIPITATION = 1<< 4 } |
| Flags specifying the general behavior of a tracer associated to the groundwater flow module. More... | |
| cs_gwf_tracer_t * | cs_gwf_tracer_init (int tracer_id, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, cs_gwf_tracer_model_t model) |
| Create a new cs_gwf_tracer_t structure and initialize its members by default. Add a new equation related to the groundwater flow module. This equation is a specific transport equation. Tracer is advected thanks to the darcian velocity which is given by the resolution of the Richards equation. Diffusion/reaction parameters result from a physical modelling. More... | |
| cs_gwf_tracer_t * | cs_gwf_tracer_free (cs_gwf_tracer_t *tracer) |
| Free a cs_gwf_tracer_t structure. More... | |
| void | cs_gwf_set_main_tracer_param (cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef, double reaction_rate) |
| For a specified soil set the main parameters corresponding to a default modelling of a tracer transport. More... | |
| void | cs_gwf_set_precip_tracer_param (cs_gwf_tracer_t *tracer, const char *soil_name, double conc_w_star) |
| For a specified soil set the parameters corresponding to a precipitation modelling of a tracer transport. More... | |
| void | cs_gwf_tracer_add_terms (cs_gwf_tracer_t *tracer) |
| Add terms to the algebraic system related to a tracer equation according to the settings. Case of the standard tracer modelling Rely on the generic function: cs_gwf_tracer_add_terms_t. More... | |
| void | cs_gwf_tracer_saturated_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, const cs_real_t *l_saturation, cs_gwf_tracer_t *tracer) |
| Set the parameters related to a standard tracer equation case of a fully saturated flow model. More... | |
| void | cs_gwf_tracer_unsaturated_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, const cs_real_t *l_saturation, cs_gwf_tracer_t *tracer) |
| Set the parameters related to a standard tracer equation in case of an unsaturated flow model. More... | |
| void | cs_gwf_tracer_log_setup (const cs_gwf_tracer_t *tracer) |
| Display the main features related to a tracer. More... | |
| cs_real_t | cs_gwf_tracer_integrate (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const cs_zone_t *z) |
| Compute the integral over a given set of cells of the field related to a tracer equation. This integral turns out to be exact for linear functions. More... | |
| cs_real_t | cs_gwf_tracer_integrate_sat (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const cs_zone_t *z) |
| Compute the integral over a given set of cells of the field related to a tracer equation. This integral turns out to be exact for linear functions. Case of a fully saturated model. More... | |
| typedef void() cs_gwf_tracer_add_terms_t(cs_gwf_tracer_t *tracer) |
| [in,out] | tracer | pointer to a cs_gwf_tracer_t structure |
| typedef void() cs_gwf_tracer_free_context_t(cs_gwf_tracer_t *tracer) |
| [in,out] | tracer | pointer to a structure cs_gwf_tracer_t |
| typedef cs_flag_t cs_gwf_tracer_model_t |
| typedef void() cs_gwf_tracer_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, const cs_real_t *l_saturation, cs_gwf_tracer_t *tracer) |
| [in] | adv | pointer to an advection field structure |
| [in] | l_saturation | pointer to liquid saturation values or NULL |
| typedef void() cs_gwf_tracer_update_t(cs_gwf_tracer_t *tracer, cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| [in,out] | tracer | pointer to a cs_gwf_tracer_structure |
Elemental modelling choice either from the physical viewpoint or the numerical viewpoint for the transport of a tracer
| void cs_gwf_set_main_tracer_param | ( | cs_gwf_tracer_t * | tracer, |
| const char * | soil_name, | ||
| double | wmd, | ||
| double | alpha_l, | ||
| double | alpha_t, | ||
| double | distrib_coef, | ||
| double | reaction_rate | ||
| [in] | soil_name | name of the related soil (or NULL if all soils are selected) |
| [in] | wmd | value of the water molecular diffusivity |
| [in] | alpha_l | value of the longitudinal dispersivity |
| [in] | alpha_t | value of the transversal dispersivity |
| [in] | distrib_coef | value of the distribution coefficient |
| [in] | reaction_rate | value of the first order rate of reaction |
| void cs_gwf_set_precip_tracer_param | ( | cs_gwf_tracer_t * | tracer, |
| double | conc_w_star | ||
| [in] | conc_w_star | value of the saturated concentration in the liquid phase |
| void cs_gwf_tracer_add_terms | ( | cs_gwf_tracer_t * | tracer | ) |
| cs_gwf_tracer_t* cs_gwf_tracer_free | ( | cs_gwf_tracer_t * | tracer | ) |
| cs_gwf_tracer_t* cs_gwf_tracer_init | ( | int | tracer_id, |
| const char * | eq_name, | ||
| cs_adv_field_t * | adv_field, | ||
| cs_gwf_tracer_model_t | model | ||
| [in] | tracer_id | id number of the soil |
| [in] | eq_name | name of the tracer equation |
| [in] | var_name | name of the related variable |
| [in] | adv_field | pointer to a cs_adv_field_t structure |
| [in] | model | model related to this tracer |
| cs_real_t cs_gwf_tracer_integrate | ( | const cs_cdo_connect_t * | connect, |
| const cs_gwf_tracer_t * | tracer, | ||
| const cs_zone_t * | z | ||
| [in] | tracer | pointer to a cs_gwf_tracer_t structure |
| [in] | z | pointer to a volume zone structure |
| cs_real_t cs_gwf_tracer_integrate_sat | ( | const cs_cdo_connect_t * | connect, |
| void cs_gwf_tracer_log_setup | ( | const cs_gwf_tracer_t * | tracer | ) |
| void cs_gwf_tracer_saturated_setup | ( | const cs_cdo_connect_t * | connect, |
| const cs_adv_field_t * | adv, | ||
| const cs_real_t * | l_saturation, | ||
| cs_gwf_tracer_t * | tracer | ||
| [in] | l_saturation | pointer to the liquid saturation values |
| void cs_gwf_tracer_unsaturated_setup | ( | const cs_cdo_connect_t * | connect, |
