7.1
cs_crystal_router.c File Reference
#include <errno.h>
#include "cs_assert.h"
#include "cs_block_dist.h"
#include "cs_timer.h"
#include "cs_crystal_router.h"
+ Include dependency graph for cs_crystal_router.c:
cs_crystal_router_tcs_crystal_router_create_s (size_t n_elts, int stride, cs_datatype_t datatype, int flags, const void *elt, const cs_lnum_t *src_id, const cs_lnum_t *dest_id, const int dest_rank[], MPI_Comm comm)
 Create a Crystal Router for strided data. More...
cs_crystal_router_tcs_crystal_router_create_i (size_t n_elts, cs_datatype_t datatype, int flags, const cs_lnum_t *elt_idx, const void *elt, const cs_lnum_t *src_id, const cs_lnum_t *dest_id, const int dest_rank[], MPI_Comm comm)
 Create a Crystal Router for indexed data. More...
void cs_crystal_router_destroy (cs_crystal_router_t **cr)
 Destroy a Crystal Router. More...
void cs_crystal_router_exchange (cs_crystal_router_t *cr)
 Exchange data with a Crystal Router. More...
cs_lnum_t cs_crystal_router_n_elts (const cs_crystal_router_t *cr)
 Get number of elements associated with Crystal Router. More...
cs_lnum_t cs_crystal_router_n_recv_elts (const cs_crystal_router_t *cr)
 Get number of elements received with Crystal Router. More...
void cs_crystal_router_get_data (cs_crystal_router_t *cr, int **src_rank, cs_lnum_t **dest_id, cs_lnum_t **src_id, cs_lnum_t **data_index, void **data)
 Get data elements associated with a Crystal Router. More...
size_t cs_crystal_router_get_max_sizes (cs_crystal_router_t *cr, size_t *max_sizes)
 Query maximum buffer sizes reached by a Crystal Router. More...
void cs_crystal_router_log_finalize (void)
 Log performance information relative to Crystal Router exchange. More...
Crystal Router parallel exchange algorithm based operations.
The Crystal Router is described in [3] .
◆ cs_crystal_router_create_i()
cs_crystal_router_t* cs_crystal_router_create_i ( size_t  n_elts,
int  flags,
const cs_lnum_t elt_idx,
const void *  elt,
const cs_lnum_t src_id,
const cs_lnum_t dest_id,
MPI_Comm  comm
If the flags constant contains CS_CRYSTAL_ROUTER_USE_DEST_ID, data exchanged will be ordered by the array passed to the dest_id argument. For n total values received on a rank (as given by cs_crystal_router_n_elts), those destination ids must be in the range [0, n[.
If the flags bit mask matches CS_CRYSTAL_ROUTER_ADD_SRC_ID, source ids are added. If it matches CS_CRYSTAL_ROUTER_ADD_SRC_RANK, source rank metadata is added.
[in]n_eltsnumber of elements
[in]datatypetype of data considered
[in]flagsadd destination id ?
[in]elt_idxelement values start and past-the-last index
[in]eltelement values
[in]src_idoptional parent element id (indirection for elt and elt_idx arrays), or NULL
[in]dest_idelement destination id, or NULL
[in]dest_rankdestination rank for each element
[in]commassociated MPI communicator
pointer to new Crystal Router structure.
◆ cs_crystal_router_create_s()
cs_crystal_router_t* cs_crystal_router_create_s ( size_t  n_elts,
int  stride,
int  flags,
const void *  elt,
MPI_Comm  comm
[in]stridenumber of values per entity (interlaced)
[in]src_idoptional parent element id (indirection for elt array), or NULL
◆ cs_crystal_router_destroy()
void cs_crystal_router_destroy ( cs_crystal_router_t **  cr)
[in,out]crpointer to associated Crystal Router
◆ cs_crystal_router_exchange()
void cs_crystal_router_exchange ( cs_crystal_router_t cr)
Order of data from a same source rank is preserved.
◆ cs_crystal_router_get_data()
void cs_crystal_router_get_data ( cs_crystal_router_t cr,
int **  src_rank,
cs_lnum_t **  dest_id,
cs_lnum_t **  src_id,
cs_lnum_t **  data_index,
void **  data
Depending on the creation options, some elements may be available or not.
For each element type, a pointer to a pointer to a buffer is provided. If the pointer to the buffer is non-null, the buffer must be of sufficient size for the number of elements returned by cs_crystal_router_n_elts.
Note also that if the destination id is provided in the Crystal Router, it will be applied automatically to the data and data_index arrays. The dest_id array itself is always in receive order. If the Crystal Router does not contain destination id info but the dest_id argument points to a non-NULL value, the provided id will be used to order extracted data. This allows saving the destination id on the receive side, and not re-sending it (saving bandwidth) for subsequent calls with a similar Crystal Router.
If all destination ids appear only once, or the CS_CRYSTAL_ROUTER_USE_DEST_ID is not set, dest_id is also applied to src_rank and src_id. Otherwise, those arrays are kept in buffer order. This can be checked by comparing the output of cs_crystal_router_n_elts and cs_crystal_router_n_recv_elts.
With this behavior, for reverse exchange, src_id and src_rank can be used as dest_id and dest_rank respectively in the call to cs_crystal_router_create_s, while NULL is passed to elt_id with single ids, and dest_id passed in case of duplicate ids.
[in]crpointer to associated Crystal Router
[out]src_rankpointer to (pointer to) source rank array, or NULL
[in,out]dest_idpointer to (pointer to) destination id array, or NULL
[out]src_idpointer to (pointer to) source id array, or NULL
[out]data_indexpointer to (pointer to) destination index, or NULL
[out]datapointer to (pointer to) destination data, or NULL
◆ cs_crystal_router_get_max_sizes()
size_t cs_crystal_router_get_max_sizes ( cs_crystal_router_t cr,
size_t *  max_sizes
[out]max_sizespointer to maximum local/receive (max_sizes[0]) and send (max_sizes[1]) sizes, or NULL
maximum total allocated buffer memory
◆ cs_crystal_router_log_finalize()
void cs_crystal_router_log_finalize ( void  )
Call count is based on Crystal router creation calls, as the number of exchange and data access calls should be identical.
◆ cs_crystal_router_n_elts()
cs_lnum_t cs_crystal_router_n_elts ( const cs_crystal_router_t cr)
number of elements associated with distributor.
◆ cs_crystal_router_n_recv_elts()
cs_lnum_t cs_crystal_router_n_recv_elts ( const cs_crystal_router_t cr)
The number of elements is the number of elements received in the exchange. In most cases this is the same as that returned using cs_crystal_router_n_elts, but may be larger when a destination id is used and multiple elements point to a same destination (for example when distributing from partitioned data with elements duplicated on partition boundaries to blocks with a single occurence of elements).
