#include "cs_field_pointer.h"
#include "cs_map.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_turbulence_bc.h"
void | cs_turbulence_model_init_bc_ids (void) |
Initialize turbulence model boundary condition ids. More... | |
void | cs_turbulence_model_free_bc_ids (void) |
Free memory allocations for turbulence boundary conditions ids. More... | |
void | cs_turbulence_bc_ke_hyd_diam (double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps) |
Calculation of ![]() ![]() ![]() ![]() ![]() | |
void | cs_turbulence_bc_ke_turb_intensity (double uref2, double t_intensity, double dh, double *k, double *eps) |
void | cs_turbulence_bc_inlet_hyd_diam (cs_lnum_t face_id, double uref2, double dh, double rho, double mu, double *rcodcl) |
Set inlet boundary condition values for turbulence variables based on a diameter ![]() ![]() | |
void | cs_turbulence_bc_inlet_turb_intensity (cs_lnum_t face_id, double uref2, double t_intensity, double dh, double *rcodcl) |
Set inlet boundary condition values for turbulence variables based on a diameter ![]() ![]() ![]() | |
void | cs_turbulence_bc_inlet_k_eps (cs_lnum_t face_id, double k, double eps, double *rcodcl) |
Set inlet boundary condition values for turbulence variables based on given k and epsilon values. More... | |
void | cs_turbulence_bc_set_uninit_inlet_k_eps (cs_lnum_t face_id, double k, double eps, double *rcodcl) |
Set inlet boundary condition values for turbulence variables based on given k and epsilon values only if not already initialized. More... | |
void | cs_turbulence_bc_rij_transform (int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[6][6]) |
Compute matrix ![]() | |
Base turbulence boundary conditions.
void cs_turbulence_bc_inlet_hyd_diam | ( | cs_lnum_t | face_id, |
double | uref2, | ||
double | dh, | ||
double | rho, | ||
double | mu, | ||
double * | rcodcl | ||
Set inlet boundary condition values for turbulence variables based on a diameter and the reference velocity
for a circular duct flow with smooth wall.
for a circular duct flow with smooth wall (use for inlet boundary conditions).
We use the laws from Idel'Cik, i.e. the head loss coefficient is defined by:
then the relation reads .
depends on the hydraulic Reynolds number
and is given by:
From , we can estimate
and
from the well known formulae of developped turbulence
[in] | face_id | boundary face id |
[in] | uref2 | square of the reference flow velocity |
[in] | dh | hydraulic diameter ![]() |
[in] | rho | mass density ![]() |
[in] | mu | dynamic viscosity ![]() |
[out] | rcodcl | boundary condition values |
void cs_turbulence_bc_inlet_k_eps | ( | cs_lnum_t | face_id, |
double | k, | ||
double | eps, | ||
[in] | k | turbulent kinetic energy |
[in] | eps | turbulent dissipation |
void cs_turbulence_bc_inlet_turb_intensity | ( | cs_lnum_t | face_id, |
double | t_intensity, | ||
double | dh, | ||
Set inlet boundary condition values for turbulence variables based on a diameter , a turbulent intensity
[in] | t_intensity | turbulent intensity ![]() |
void cs_turbulence_bc_ke_hyd_diam | ( | double | uref2, |
double | dh, | ||
double | rho, | ||
double | mu, | ||
double * | ustar2, | ||
double * | k, | ||
double * | eps | ||
Calculation of ,
and
from a diameter
Both and
are returned, so that the user may compute other values of
and
with
and is given by:
and
[out] | ustar2 | square of friction speed |
[out] | k | calculated turbulent intensity ![]() |
[out] | eps | calculated turbulent dissipation ![]() |
void cs_turbulence_bc_ke_turb_intensity | ( | double | uref2, |
double | dh, | ||
double * | k, | ||
double * | eps | ||
Calculation of and
from a diameter
for a circular duct flow with smooth wall (for inlet boundary conditions).
Compute matrix used in the computation of the Reynolds stress tensor boundary conditions.
We note the Reynolds Stress tensor in the global reference frame (mesh reference frame) and
the Reynolds stress tensor in the local reference frame (reference frame associated to the boundary face).
is the change of basis orthogonal matrix from local to global reference frame.
is a 6 by 6 matrix defined such that:
where symetric tensors have been unfolded as follows:
should be computed as a function of
as follows:
with
and .
Constant c is chosen depending on the type of the boundary face: at a wall face,
at a symmetry face.
[in] | is_sym | Constant c in description above (1 at a symmetry face, 0 at a wall face) |
[in] | p_lg | change of basis matrix (local to global) |
[out] | alpha | transformation matrix |
void cs_turbulence_bc_set_uninit_inlet_k_eps | ( | cs_lnum_t | face_id, |
double | k, | ||
double | eps, | ||
void cs_turbulence_model_free_bc_ids | ( | void | ) |
void cs_turbulence_model_init_bc_ids | ( | void | ) |
