cs_thermal_system.h
1 #ifndef __CS_THERMAL_SYSTEM_H__
2 #define __CS_THERMAL_SYSTEM_H__
5  * Routines to handle cs_thermal_system_t structure
29  * Local headers
32 #include "cs_advection_field.h"
33 #include "cs_equation.h"
34 #include "cs_field.h"
35 #include "cs_property.h"
36 #include "cs_mesh.h"
37 #include "cs_source_term.h"
38 #include "cs_time_step.h"
39 #include "cs_xdef.h"
59  * Macro definitions
61
62 /* Generic name given to fields and equations related to this module */
63
64 #define CS_THERMAL_EQNAME "thermal_equation"
65 #define CS_THERMAL_CP_NAME "thermal_capacity"
66 #define CS_THERMAL_LAMBDA_NAME "thermal_conductivity"
67
79 #define CS_THERMAL_POST_ENTHALPY (1 << 0) /* 1 */
80
85 /*=============================================================================
86  * Structure and type definitions
87  *============================================================================*/
88
90
119 typedef enum {
120
121  CS_THERMAL_MODEL_STEADY = 1<<0, /* = 1 */
123
124  /* Main variable to consider (by default the temperature in Kelvin)
125  ---------------------------------------------------------------- */
126
130
131  /* Treatment of the diffusion term
132  ------------------------------- */
133
135
136  /* Additional bit settings
137  ----------------------- */
138
139  CS_THERMAL_MODEL_IN_CELSIUS = 1<<7 /* = 128 */
140
142
143 /* Set of parameters related to the thermal module */
144
145 typedef struct {
146
147  cs_flag_t model; /* Choice of modelling */
148  cs_flag_t numeric; /* General numerical options */
149  cs_flag_t post; /* Post-processing options */
150
151  /* Equation associated to this module */
152  /* ---------------------------------- */
153
155
156  /* Properties associated to this module */
157  /* ------------------------------------ */
158
159  cs_property_t *unsteady_property; /* Property of the unsteady term: rho.cp */
160  cs_property_t *lambda; /* Thermal conductivity */
161  cs_property_t *cp; /* Heat capacity */
162  cs_property_t *rho; /* Mass density (may be shared) */
163  cs_property_t *kappa; /* lambda/cp may be NULL*/
164
165  /* value of lambda/cp in each cell (allocated if the related property kappa
166  * is not NULL and defined by array) */
168
169  /* Fields associated to this module */
170  /* -------------------------------- */
171
175
176  /* Additional members */
177  /* ------------------ */
178
181
182  /* Structure used for the definition of the boussinesq source term */
184
185  /* N.B.: Other reference values for properties are stored within each
186  * property structure */
187
189
190 /*============================================================================
191  * Public function prototypes
192  *============================================================================*/
193
194 /*----------------------------------------------------------------------------*/
201 /*----------------------------------------------------------------------------*/
202
203 cs_real_t
205
206 /*----------------------------------------------------------------------------*/
212 /*----------------------------------------------------------------------------*/
213
214 cs_flag_t
216
217 /*----------------------------------------------------------------------------*/
224 /*----------------------------------------------------------------------------*/
225
226 bool
228
229 /*----------------------------------------------------------------------------*/
235 /*----------------------------------------------------------------------------*/
236
237 bool
239
240 /*----------------------------------------------------------------------------*/
250 /*----------------------------------------------------------------------------*/
251
254  cs_flag_t numeric,
255  cs_flag_t post);
256
257 /*----------------------------------------------------------------------------*/
261 /*----------------------------------------------------------------------------*/
262
263 void
265
266 /*----------------------------------------------------------------------------*/
273 /*----------------------------------------------------------------------------*/
274
275 void
277  cs_real_t beta0);
278
279 /*----------------------------------------------------------------------------*/
288 /*----------------------------------------------------------------------------*/
289
292  cs_real_t rho0);
293
294 /*----------------------------------------------------------------------------*/
298 /*----------------------------------------------------------------------------*/
299
302
303 /*----------------------------------------------------------------------------*/
309 /*----------------------------------------------------------------------------*/
310
311 void
313
314 /*----------------------------------------------------------------------------*/
322 /*----------------------------------------------------------------------------*/
323
324 void
326  const cs_cdo_quantities_t *quant,
327  const cs_time_step_t *time_step);
328
329 /*----------------------------------------------------------------------------*/
338 /*----------------------------------------------------------------------------*/
339
340 void
342  const cs_time_step_t *time_step,
343  const cs_cdo_connect_t *connect,
344  const cs_cdo_quantities_t *quant);
345
346 /*----------------------------------------------------------------------------*/
356 /*----------------------------------------------------------------------------*/
357
358 void
359 cs_thermal_system_compute(bool cur2prev,
360  const cs_mesh_t *mesh,
361  const cs_time_step_t *time_step,
362  const cs_cdo_connect_t *connect,
363  const cs_cdo_quantities_t *quant);
364
365 /*----------------------------------------------------------------------------*/
375 /*----------------------------------------------------------------------------*/
376
377 void
379  const cs_cdo_connect_t *connect,
380  const cs_cdo_quantities_t *quant,
381  const cs_time_step_t *ts,
382  bool cur2prev);
383
384 /*----------------------------------------------------------------------------*/
391 /*----------------------------------------------------------------------------*/
392
393 void
395  const cs_cdo_quantities_t *cdoq);
396
397 /*----------------------------------------------------------------------------*/
419 /*----------------------------------------------------------------------------*/
420
421 void
422 cs_thermal_system_extra_post(void *input,
423  int mesh_id,
424  int cat_id,
425  int ent_flag[5],
426  cs_lnum_t n_cells,
427  cs_lnum_t n_i_faces,
428  cs_lnum_t n_b_faces,
429  const cs_lnum_t cell_ids[],
430  const cs_lnum_t i_face_ids[],
431  const cs_lnum_t b_face_ids[],
432  const cs_time_step_t *time_step);
433
434 /*----------------------------------------------------------------------------*/
438 /*----------------------------------------------------------------------------*/
439
440 void
442
443 /*----------------------------------------------------------------------------*/
444
446
447 #endif /* __CS_THERMAL_SYSTEM_H__ */
time step descriptor
Definition: cs_time_step.h:64
cs_equation_t * thermal_eq
Definition: cs_thermal_system.h:154
Definition: cs_thermal_system.h:121
cs_flag_t cs_thermal_model_type_t
Definition: cs_thermal_system.h:89
cs_field_t * total_energy
Definition: cs_thermal_system.h:174
Definition: cs_field.h:125
cs_flag_t model
Definition: cs_thermal_system.h:147
cs_equation_t * cs_thermal_system_get_equation(void)
Retrieve the main equation related to the thermal system.
Definition: cs_thermal_system.c:591
cs_real_t thermal_dilatation_coef
Definition: cs_thermal_system.h:180
cs_property_t * unsteady_property
Definition: cs_thermal_system.h:159
cs_source_term_boussinesq_t * boussinesq
Definition: cs_thermal_system.h:183
Definition: cs_defs.h:495
cs_flag_t numeric
Definition: cs_thermal_system.h:148
Definition: cs_thermal_system.h:139
cs_real_t cs_thermal_system_get_reference_temperature(void)
Retrieve the value of the reference temperature associated to a thermal system.
Definition: cs_thermal_system.c:279
void cs_thermal_system_destroy(void)
Free the main structure related to the thermal system.
Definition: cs_thermal_system.c:499
void cs_thermal_system_update(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, bool cur2prev)
Update/initialize the thermal module according to the settings.
Definition: cs_thermal_system.c:785
Definition: cs_thermal_system.h:129
Definition: cs_defs.h:307
cs_field_t * enthalpy
Definition: cs_thermal_system.h:173
Definition: cs_thermal_system.h:128
Definition: cs_mesh.h:84
cs_property_t * kappa
Definition: cs_thermal_system.h:163
Definition: cs_thermal_system.h:127
bool cs_thermal_system_is_activated(void)
Check if the resolution of the thermal system has been activated.
Definition: cs_thermal_system.c:337
cs_real_t ref_temperature
Definition: cs_thermal_system.h:179
Definition: cs_thermal_system.h:122
cs_flag_t cs_thermal_system_get_model(void)
Retrieve the model flag related to a thermal system.
Definition: cs_thermal_system.c:299
Structure storing the parameters related to the Boussinesq source term.
Definition: cs_source_term.h:60
cs_thermal_model_type_bit_t
Bit values for physical modelling related to thermal system.
Definition: cs_thermal_system.h:119
cs_thermal_system_t * cs_thermal_system_activate(cs_flag_t model, cs_flag_t numeric, cs_flag_t post)
Allocate and initialize the thermal system.
Definition: cs_thermal_system.c:358
void cs_thermal_system_compute(bool cur2prev, const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Build and solve the thermal system.
Definition: cs_thermal_system.c:753
cs_property_t * lambda
Definition: cs_thermal_system.h:160
cs_field_t * temperature
Definition: cs_thermal_system.h:172
void cs_thermal_system_compute_steady_state(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Build and solve a steady-state thermal system.
Definition: cs_thermal_system.c:721
void cs_thermal_system_set_reference_parameters(cs_real_t temp0, cs_real_t beta0)
Set the reference temperature and the thermal dilatation coefficient.
Definition: cs_thermal_system.c:530
cs_source_term_boussinesq_t * cs_thermal_system_add_boussinesq_term(const cs_real_t *gravity, cs_real_t rho0)
Define a structure to compute the Boussinesq source term.
Definition: cs_thermal_system.c:556
Definition: cs_defs.h:301
bool cs_thermal_system_needs_navsto(void)
Does the thermal system rely on the advection field associated to the Navier-Stokes equations ...
Definition: cs_thermal_system.c:317
cs_property_t * cp
Definition: cs_thermal_system.h:161
cs_real_t * kappa_array
Definition: cs_thermal_system.h:167
void cs_thermal_system_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Last step of the setup of the thermal system.
Definition: cs_thermal_system.c:693
void cs_thermal_system_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the thermal system. The prototype of this function is fixed sin...
Definition: cs_thermal_system.c:852
Definition: cs_defs.h:496
cs_property_t * rho
Definition: cs_thermal_system.h:162
unsigned short int cs_flag_t
Definition: cs_defs.h:309
void cs_thermal_system_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Predefined extra-operations for the thermal system.
Definition: cs_thermal_system.c:815
Definition: cs_thermal_system.h:134
Definition: cs_thermal_system.h:145
void cs_thermal_system_log_setup(void)
Summary of the main options related to cs_thermal_system_t structure.
Definition: cs_thermal_system.c:889
Definition: post.f90:26
void cs_thermal_system_init_setup(void)
Start setting-up the thermal system At this stage, numerical settings should be completely determined...
Definition: cs_thermal_system.c:610
Definition: mesh.f90:26
cs_flag_t post
Definition: cs_thermal_system.h:149
