cs_prototypes.h File Reference
#include "cs_domain.h"
#include "cs_mesh_bad_cells.h"
#include "cs_probe.h"
#include "cs_volume_zone.h"
+ Include dependency graph for cs_prototypes.h:
void caltri (void)
void cpthp1 (const int *mode, cs_real_t *eh, cs_real_t *xesp, cs_real_t *f1mc, cs_real_t *f2mc, cs_real_t *tp)
void csinit (const int *irgpar, const int *nrgpar)
void distpr (const int *itypfb, cs_real_t *distpa)
void dvvpst (const int *nummai, const int *numtyp, const int *nvar, const cs_lnum_t *ncelps, const cs_lnum_t *nfbrps, const cs_lnum_t lstcel[], const cs_lnum_t lstfbr[], cs_real_t tracel[], cs_real_t trafbr[])
void findpt (const cs_lnum_t *ncelet, const cs_lnum_t *ncel, const cs_real_t *xyzcen, const cs_real_t *xx, const cs_real_t *yy, const cs_real_t *zz, cs_lnum_t *node, int *ndrang)
void haltyp (const int *ivoset)
void initi1 (void)
int cs_add_model_field_indexes (int f_id)
void cs_coal_bt2h (cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t t[], cs_real_t h[])
 Convert temperature to enthalpy at boundary for coal combustion. More...
void cs_coal_thfieldconv1 (int location_id, const cs_real_t eh[], cs_real_t tp[])
 Calculation of the gas temperature Function with the gas enthalpy and concentrations. More...
void cs_fuel_bt2h (cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t t[], cs_real_t h[])
 Convert temperature to enthalpy at boundary for fuel combustion. More...
void cs_fuel_thfieldconv1 (int location_id, const cs_real_t eh[], cs_real_t tp[])
void cs_lagr_status (int *model_flag, int *restart_flag, int *frozen_flag)
void cs_user_1d_wall_thermal (int iappel, int isuit1)
void cs_user_boundary_conditions (int nvar, int icodcl[], int bc_type[], cs_real_t rcodcl[])
 User definition of boundary conditions. More...
void cs_user_extra_operations_initialize (cs_domain_t *domain)
 Initialize variables. More...
void cs_user_extra_operations (cs_domain_t *domain)
 This function is called at the end of each time step. More...
void cs_user_extra_operations_finalize (cs_domain_t *domain)
 This function is called at the end of the calculation. More...
void cs_user_head_losses (const cs_zone_t *zone, cs_real_t cku[][6])
 Compute GUI-defined head losses for a given volume zone. More...
void cs_user_initialization (cs_domain_t *domain)
 This function is called one time step to initialize problem. More...
void cs_user_internal_coupling (void)
 Define internal coupling options. More...
void cs_user_internal_coupling_add_volumes (cs_mesh_t *mesh)
 Define volumes as internal coupling zones. More...
void cs_user_internal_coupling_from_disjoint_meshes (cs_mesh_t *mesh)
 Define volumesi from separated meshes as internal coupling zones. More...
void cs_user_physical_properties (cs_domain_t *domain)
 This function is called each time step to define physical properties. More...
void cs_user_physical_properties_h_to_t (cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t h[restrict], cs_real_t t[restrict])
 User definition of enthalpy to temperature conversion. More...
void cs_user_physical_properties_t_to_h (cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t t[restrict], cs_real_t h[restrict])
 User definition of temperature to enthalpy conversion. More...
void cs_user_source_terms (cs_domain_t *domain, int f_id, cs_real_t *st_exp, cs_real_t *st_imp)
 Additional user-defined source terms for variable equations (momentum, scalars, turbulence...). More...
void cs_user_porosity (cs_domain_t *domain)
 Compute the porosity (volume factor $ \epsilon $ when the porosity model is activated. (cs_glob_porous_model > 0). More...
void cs_user_join (void)
 Define mesh joinings. More...
void cs_user_linear_solvers (void)
 Define linear solver options. More...
void cs_user_finalize_setup (cs_domain_t *domain)
 Define or modify output user parameters. For CDO schemes, specify the elements such as properties, advection fields, user-defined equations and modules which have been previously added. More...
void cs_user_mesh_bad_cells_tag (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
 Tag bad cells within the mesh based on user-defined geometric criteria. More...
void cs_user_mesh_input (void)
 Define mesh files to read and optional associated transformations. More...
void cs_user_mesh_modify (cs_mesh_t *mesh)
 Modify geometry and mesh. More...
void cs_user_mesh_boundary (cs_mesh_t *mesh)
 Insert boundaries into a mesh. More...
void cs_user_mesh_smoothe (cs_mesh_t *mesh)
 Mesh smoothing. More...
void cs_user_mesh_save (cs_mesh_t *mesh)
 Enable or disable mesh saving. More...
void cs_user_mesh_warping (void)
 Set options for cutting of warped faces. More...
void cs_user_mesh_modify_partial (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
 Apply partial modifications to the mesh after the preprocessing and initial postprocessing mesh building stage. More...
void cs_user_mesh_cartesian_define (void)
 Define a cartesian mesh. More...
void cs_user_model (void)
 Select physical model options, including user fields. More...
void cs_user_numbering (void)
 Define advanced mesh numbering options. More...
void cs_user_parallel_io (void)
 Define parallel IO settings. More...
void cs_user_partition (void)
 Define advanced partitioning options. More...
void cs_user_matrix_tuning (void)
 Define sparse matrix tuning options. More...
void cs_user_parameters (cs_domain_t *domain)
 Define or modify general numerical and physical user parameters. More...
void cs_user_radiative_transfer_parameters (void)
 User function for input of radiative transfer module options. More...
void cs_user_radiative_transfer_bcs (int nvar, const int bc_type[], int icodcl[], int isothp[], cs_real_t *tmin, cs_real_t *tmax, cs_real_t *tx, const cs_real_t dt[], cs_real_t rcodcl[], const cs_real_t thwall[], const cs_real_t qincid[], cs_real_t hfcnvp[], cs_real_t flcnvp[], cs_real_t xlamp[], cs_real_t epap[], cs_real_t epsp[], cs_real_t textp[])
 User definition of radiative transfer boundary conditions. More...
void cs_user_periodicity (void)
 Define periodic faces. More...
void cs_user_postprocess_writers (void)
 Define post-processing writers. More...
void cs_user_postprocess_probes (void)
 Define monitoring probes and profiles. More...
void cs_user_postprocess_meshes (void)
 Define post-processing meshes. More...
void cs_user_postprocess_values (const char *mesh_name, int mesh_id, int cat_id, cs_probe_set_t *probes, cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, cs_lnum_t n_vertices, const cs_lnum_t cell_list[], const cs_lnum_t i_face_list[], const cs_lnum_t b_face_list[], const cs_lnum_t vertex_list[], const cs_time_step_t *ts)
 User function for output of values on a post-processing mesh. More...
void cs_user_postprocess_activate (int nt_max_abs, int nt_cur_abs, double t_cur_abs)
void cs_user_rad_transfer_absorption (const int bc_type[], cs_real_t ck[])
 Absorption coefficient for radiative module. More...
void cs_user_rad_transfer_net_flux (const int itypfb[], const cs_real_t coefap[], const cs_real_t coefbp[], const cs_real_t cofafp[], const cs_real_t cofbfp[], const cs_real_t twall[], const cs_real_t qincid[], const cs_real_t xlam[], const cs_real_t epa[], const cs_real_t eps[], const cs_real_t ck[], cs_real_t net_flux[])
 Compute the net radiation flux. More...
int cs_user_solver_set (void)
 Set user solver. More...
void cs_user_solver (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
 Main call to user solver. More...
void cs_user_saturne_coupling (void)
 Define couplings with other instances of Code_Saturne. More...
void cs_user_syrthes_coupling (void)
 Define couplings with SYRTHES code. More...
void cs_user_syrthes_coupling_volume_h (int coupling_id, const char *syrthes_name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t h_vol[])
 Compute a volume exchange coefficient for SYRTHES couplings. More...
void cs_user_time_moments (void)
 Define time moments. More...
void cs_user_turbomachinery (void)
 Define rotor/stator model. More...
void cs_user_turbomachinery_rotor (void)
 Define rotor axes, associated cells, and rotor/stator faces. More...
void cs_user_turbomachinery_set_rotation_velocity (void)
 Define rotation velocity of rotor. More...
void cs_user_zones (void)
 Define volume and surface zones. More...
void cs_user_scaling_elec (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt)
 Define scaling parameter for electric model. More...
void cs_user_hgn_thermo_relax_time (const cs_mesh_t *mesh, const cs_real_t *alpha_eq, const cs_real_t *y_eq, const cs_real_t *z_eq, const cs_real_t *ei, const cs_real_t *v, cs_real_t *relax_tau)
 Computation of the relaxation time-scale. More...
void cs_user_gwf_setup (cs_domain_t *domain)
 Specify for each soil and tracer how is defined each term of the the tracer equation. Soils and tracer equations have to be added previously. More...
cs_real_tcs_meg_boundary_function (const cs_zone_t *zone, const char *field_name, const char *condition)
void cs_meg_volume_function (const cs_zone_t *zone, cs_field_t *f[])
 This function is used to compute user defined values for fields over a given volume zone. More...
cs_real_tcs_meg_initialization (const cs_zone_t *zone, const char *field_name)
 Evaluate GUI defined mathematical expressions over volume zones for initialization. More...
cs_real_tcs_meg_source_terms (const cs_zone_t *zone, const char *name, const char *source_type)
void cs_meg_immersed_boundaries_inout (int *ipenal, const char *object_name, cs_real_t xyz[3], cs_real_t t)
void cs_meg_fsi_struct (const char *object_type, const char *name, const cs_real_t fluid_f[], cs_real_t val[])
 This function is used to query FSI internal coupling structure values for a given boundary and structure. More...
void cs_meg_post_activate (void)
 This function is used to activate postprocessing writers. More...
void cs_meg_post_profiles (const char *name, int n_coords, cs_real_t coords[][3])
 This function is used to define profile coordinates. More...
void cs_user_paramedmem_define_couplings (void)
 Define ParaMEDMEM coupling(s) More...
void cs_user_paramedmem_define_meshes (void)
 Define coupled meshes. More...
void cs_user_paramedmem_define_fields (void)
 Define fields to couple with ParaMEDMEM. More...
◆ caltri()
void caltri ( void  )
◆ cpthp1()
void cpthp1 ( const int *  mode,
cs_real_t eh,
cs_real_t xesp,
cs_real_t f1mc,
cs_real_t f2mc,
cs_real_t tp
◆ cs_add_model_field_indexes()
int cs_add_model_field_indexes ( int  f_id)
◆ cs_coal_bt2h()
void cs_coal_bt2h ( cs_lnum_t  n_faces,
cs_real_t  h[]
[in]n_facesnumber of faces in list
[in]face_idslist of boundary faces at which conversion is requested (0-based numbering)
[in]t_btemperature at boundary
[out]h_benthalpy at boundary
◆ cs_coal_thfieldconv1()
void cs_coal_thfieldconv1 ( int  location_id,
cs_real_t  tp[]
[in]location_idmesh location id (cells or boundary faces)
[in]ehgas enthalpy ( $ j . kg $ of gaseous mixture)
[in,out]tpgas temperature (in kelvin)
◆ cs_fuel_bt2h()
void cs_fuel_bt2h ( cs_lnum_t  n_faces,
cs_real_t  h[]
◆ cs_fuel_thfieldconv1()
void cs_fuel_thfieldconv1 ( int  location_id,
cs_real_t  tp[]
◆ cs_lagr_status()
void cs_lagr_status ( int *  model_flag,
int *  restart_flag,
int *  frozen_flag
◆ cs_meg_boundary_function()
cs_real_t* cs_meg_boundary_function ( const cs_zone_t zone,
const char *  field_name,
const char *  condition
◆ cs_meg_fsi_struct()
void cs_meg_fsi_struct ( const char *  object_type,
const char *  name,
cs_real_t  val[]
[in]object_typename of object type
[in]namename of matching boundary
[in]fluid_farray of fluid forces on the object
[in,out]val[]matrix or vector coefficients
◆ cs_meg_immersed_boundaries_inout()
void cs_meg_immersed_boundaries_inout ( int *  ipenal,
const char *  object_name,
cs_real_t  xyz[3],
cs_real_t  t
◆ cs_meg_initialization()
cs_real_t* cs_meg_initialization ( const cs_zone_t zone,
[in]zonepointer to a cs_volume_zone_t structure
[in]field_namevariable name
The caller is responsible for freeing the associated array.
[in]zonepointer to associated volume zone
[in,out]field_nameassociated field name
pointer to allocated initialization values.
◆ cs_meg_post_activate()
void cs_meg_post_activate ( void  )
◆ cs_meg_post_profiles()
void cs_meg_post_profiles ( const char *  name,
int  n_coords,
[in]namename of matching profile
[in]n_coordsnumber of point coordinates
[in,out]coordspoint coordinates
◆ cs_meg_source_terms()
cs_real_t* cs_meg_source_terms ( const cs_zone_t zone,
const char *  name,
const char *  source_type
◆ cs_meg_volume_function()
void cs_meg_volume_function ( const cs_zone_t zone,
cs_field_t f[]
[in]zonepointer to cs_zone_t structure related to a volume
[in,out]f[]array of pointers to cs_field_t
◆ cs_user_1d_wall_thermal()
void cs_user_1d_wall_thermal ( int  iappel,
int  isuit1
◆ cs_user_boundary_conditions()
void cs_user_boundary_conditions ( int  nvar,
int  bc_type[],
int  icodcl[],
cs_real_t  rcodcl[]
[in]nvartotal number of variable BC's
[in]bc_typeboundary face types
[in]icodclboundary face code
  • 1 -> Dirichlet
  • 2 -> convective outlet
  • 3 -> flux density
  • 4 -> sliding wall and u.n=0 (velocity)
  • 5 -> friction and u.n=0 (velocity)
  • 6 -> roughness and u.n=0 (velocity)
  • 9 -> free inlet/outlet (velocity) inflowing possibly blocked
[in]rcodclboundary condition values rcodcl(3) = flux density value (negative for gain) in W/m2
◆ cs_user_extra_operations()
void cs_user_extra_operations ( cs_domain_t domain)
It has a very general purpose, although it is recommended to handle mainly postprocessing or data-extraction type operations.
◆ cs_user_extra_operations_finalize()
void cs_user_extra_operations_finalize ( cs_domain_t domain)
◆ cs_user_extra_operations_initialize()
void cs_user_extra_operations_initialize ( cs_domain_t domain)
This function is called at beginning of the computation (restart or not) before the time step loop.
This is intended to initialize or modify (when restarted) variable and time step values.
◆ cs_user_finalize_setup()
void cs_user_finalize_setup ( cs_domain_t domain)
For CDO schemes, this function concludes the setup of properties, equations, source terms...
◆ cs_user_gwf_setup()
void cs_user_gwf_setup ( cs_domain_t domain)
◆ cs_user_head_losses()
void cs_user_head_losses ( const cs_zone_t zone,
cs_real_t  cku[][6]
Head loss tensor coefficients for each cell are organized as follows: cku11, cku22, cku33, cku12, cku13, cku23.
[in]zonepointer to zone structure
[in,out]ckuhead loss coefficients
Head loss tensor coefficients for each cell are organized as follows: ck11, ck22, ck33, ck12, ck13, ck23.
Diagonal coefficients must be positive; the calculation may diverge if this is not the case.
◆ cs_user_hgn_thermo_relax_time()
void cs_user_hgn_thermo_relax_time ( const cs_mesh_t mesh,
const cs_real_t alpha_eq,
const cs_real_t y_eq,
const cs_real_t z_eq,
const cs_real_t ei,
const cs_real_t v,
cs_real_t relax_tau
This function computes the value of the relaxation time-scale (for the return to equilibrium).
[in]meshpointer to mesh
[in]alpha_eqequilibrium volume fraction
[in]y_eqequilibrium mass fraction
[in]z_eqequilibrium energy fraction
[in]eispecific internal energy
[in]vspecific volume
[in]relax_taurelaxation time scale towards equilibrium
◆ cs_user_initialization()
void cs_user_initialization ( cs_domain_t domain)
◆ cs_user_internal_coupling()
void cs_user_internal_coupling ( void  )
Options are usually defined using cs_internal_coupling_add_entity.
◆ cs_user_internal_coupling_add_volumes()
void cs_user_internal_coupling_add_volumes ( cs_mesh_t mesh)
These zones will be separated from the rest of the domain using automatically defined thin walls.
[in,out]meshpointer to a cs_mesh_t structure
Deprecated:
move contents tocs_user_internal_coupling instead.
◆ cs_user_internal_coupling_from_disjoint_meshes()
void cs_user_internal_coupling_from_disjoint_meshes ( cs_mesh_t mesh)
These zones must be disjoint and the face selection criteria must be specified.
Deprecated:
◆ cs_user_join()
void cs_user_join ( void  )
◆ cs_user_linear_solvers()
void cs_user_linear_solvers ( void  )
This function is called at the setup stage, once user and most model-based fields are defined.
Available native iterative linear solvers include conjugate gradient, Jacobi, BiCGStab, BiCGStab2, and GMRES. For symmetric linear systems, an algebraic multigrid solver is available (and recommended).
External solvers may also be setup using this function, the cs_sles_t mechanism allowing such through user-define functions.
◆ cs_user_matrix_tuning()
void cs_user_matrix_tuning ( void  )
◆ cs_user_mesh_bad_cells_tag()
void cs_user_mesh_bad_cells_tag ( cs_mesh_t mesh,
cs_mesh_quantities_t mesh_quantities
[in,out]mesh_quantitiespointer to a cs_mesh_quantities_t structure
◆ cs_user_mesh_boundary()
void cs_user_mesh_boundary ( cs_mesh_t mesh)
◆ cs_user_mesh_cartesian_define()
void cs_user_mesh_cartesian_define ( void  )
◆ cs_user_mesh_input()
void cs_user_mesh_input ( void  )
◆ cs_user_mesh_modify()
void cs_user_mesh_modify ( cs_mesh_t mesh)
◆ cs_user_mesh_modify_partial()
void cs_user_mesh_modify_partial ( cs_mesh_t mesh,
◆ cs_user_mesh_save()
void cs_user_mesh_save ( cs_mesh_t mesh)
By default, mesh is saved when modified.
◆ cs_user_mesh_smoothe()
void cs_user_mesh_smoothe ( cs_mesh_t mesh)
Mesh smoothing.
◆ cs_user_mesh_warping()
void cs_user_mesh_warping ( void  )
◆ cs_user_model()
void cs_user_model ( void  )
This function is called at the earliest stages of the data setup, so field ids are not available yet.
◆ cs_user_numbering()
void cs_user_numbering ( void  )
◆ cs_user_parallel_io()
void cs_user_parallel_io ( void  )
◆ cs_user_paramedmem_define_couplings()
void cs_user_paramedmem_define_couplings ( void  )
◆ cs_user_paramedmem_define_fields()
void cs_user_paramedmem_define_fields ( void  )
◆ cs_user_paramedmem_define_meshes()
void cs_user_paramedmem_define_meshes ( void  )
◆ cs_user_parameters()
void cs_user_parameters ( cs_domain_t domain)
At the calling point of this function, most model-related most variables and other fields have been defined, so specific settings related to those fields may be set here.
At this stage, the mesh is not built or read yet, so associated data such as field values are not accessible yet, though pending mesh operations and some fields may have been defined.
◆ cs_user_partition()
void cs_user_partition ( void  )
◆ cs_user_periodicity()
void cs_user_periodicity ( void  )
◆ cs_user_physical_properties()
void cs_user_physical_properties ( cs_domain_t domain)
◆ cs_user_physical_properties_h_to_t()
void cs_user_physical_properties_h_to_t ( cs_domain_t domain,
const cs_zone_t z,
bool  z_local,
This allows overwriting the solver defaults if necessary.
This function may be called on a per-zone basis, so as to allow different conversion relations in zones representing solids or different fluids.
[in]zzone (volume or boundary) applying to current call
[in]z_localif true, h and t arrays are defined in a compact (contiguous) manner for this zone only; if false, h and t are defined on the zone's parent location (usually all cells or boundary faces)
[in]henthalpy values
[in,out]ttemperature values
◆ cs_user_physical_properties_t_to_h()
void cs_user_physical_properties_t_to_h ( cs_domain_t domain,
const cs_zone_t z,
bool  z_local,
[in]htemperature values
[in,out]tenthalpy values
◆ cs_user_porosity()
void cs_user_porosity ( cs_domain_t domain)
This function is called at the begin of the simulation only.
◆ cs_user_postprocess_activate()
void cs_user_postprocess_activate ( int  nt_max_abs,
int  nt_cur_abs,
double  t_cur_abs
Override default frequency or calculation end based output.
This allows fine-grained control of activation or deactivation,
nt_max_absmaximum time step number
nt_cur_abscurrent time step number
t_cur_absabsolute time at the current time step
◆ cs_user_postprocess_meshes()
void cs_user_postprocess_meshes ( void  )
The main post-processing meshes may be configured, and additional post-processing meshes may be defined as a subset of the main mesh's cells or faces (both interior and boundary).
◆ cs_user_postprocess_probes()
void cs_user_postprocess_probes ( void  )
Profiles are defined as sets of probes.
◆ cs_user_postprocess_values()
void cs_user_postprocess_values ( const char *  mesh_name,
int  mesh_id,
int  cat_id,
cs_probe_set_t probes,
cs_lnum_t  n_cells,
const cs_time_step_t ts
[in]mesh_namename of the output mesh for the current call
[in]mesh_idid of the output mesh for the current call
[in]cat_idcategory id of the output mesh for the current call
[in]probespointer to associated probe set structure if the mesh is a probe set, NULL otherwise
[in]n_cellslocal number of cells of post_mesh
[in]n_i_faceslocal number of interior faces of post_mesh
[in]n_b_faceslocal number of boundary faces of post_mesh
[in]n_verticeslocal number of vertices faces of post_mesh
[in]cell_listlist of cells (0 to n-1) of post-processing mesh
[in]i_face_listlist of interior faces (0 to n-1) of post-processing mesh
[in]b_face_listlist of boundary faces (0 to n-1) of post-processing mesh
[in]vertex_listlist of vertices (0 to n-1) of post-processing mesh
[in]tstime step status structure, or NULL
◆ cs_user_postprocess_writers()
void cs_user_postprocess_writers ( void  )
The default output format and frequency may be configured, and additional post-processing writers allowing outputs in different formats or with different format options and output frequency than the main writer may be defined.
◆ cs_user_rad_transfer_absorption()
void cs_user_rad_transfer_absorption ( const int  bc_type[],
cs_real_t  ck[]
It is necessary to define the value of the fluid's absorption coefficient Ck.
This value is defined automatically for specific physical models, such as gas and coal combustion, so this function should not be used with these models.
For a transparent medium, the coefficient should be set to 0.
In the case of the P-1 model, we check that the optical length is at least of the order of 1.
[out]ckmedium's absorption coefficient (zero if transparent)
◆ cs_user_rad_transfer_net_flux()
void cs_user_rad_transfer_net_flux ( const int  bc_type[],
The density of net radiation flux must be calculated consistently with the boundary conditions of the intensity. The density of net flux is the balance between the radiative emiting part of a boundary face (and not the reflecting one) and the radiative absorbing part.
[in]coefapboundary condition work array for the luminance (explicit part)
[in]coefbpboundary condition work array for the luminance (implicit part)
[in]cofafpboundary condition work array for the diffusion of the luminance (explicit part)
[in]cofbfpboundary condition work array for the diffusion of the luminance (implicit part)
[in]twallinside current wall temperature (K)
[in]qincidradiative incident flux (W/m2)
[in]xlamconductivity (W/m/K)
[in]epathickness (m)
[in]epsemissivity (>0)
[in]ckabsorption coefficient
[out]net_fluxnet flux (W/m2)
◆ cs_user_radiative_transfer_bcs()
void cs_user_radiative_transfer_bcs ( int  nvar,
int  icodcl[],
int  isothp[],
cs_real_t tmin,
cs_real_t tmax,
cs_real_t tx,
cs_real_t  rcodcl[],
cs_real_t  hfcnvp[],
cs_real_t  flcnvp[],
cs_real_t  xlamp[],
cs_real_t  epap[],
cs_real_t  epsp[],
cs_real_t  textp[]
See Examples of data settings for radiative transfers for examples.
Warning
the temperature unit here is the Kelvin
Zone definitions
For each boundary face face_id, a specific output (logging and postprocessing) class id may be assigned. This allows realizing balance sheets by treating them separately for each zone. By default, the output class id is set to the general (input) zone id associated to a face.
To access output class ids (both for reading and modifying), use the cs_boundary_zone_face_class_id function. The zone id values are arbitrarily chosen by the user, but must be positive integers; very high numbers may also lead to higher memory consumption.
Wall characteristics
The following face characteristics must be set:
  • isothp(face_id) boundary face type
    • CS_BOUNDARY_RAD_WALL_GRAY: Gray wall with temperature based on fluid BCs
    • CS_BOUNDARY_RAD_WALL_GRAY_EXTERIOR_T: Gray wall with fixed outside temperature
    • CS_BOUNDARY_RAD_WALL_REFL_EXTERIOR_T: Reflecting wall with fixed outside temperature
    • CS_BOUNDARY_RAD_WALL_GRAY_COND_FLUX: Gray wall with fixed conduction flux
    • CS_BOUNDARY_RAD_WALL_REFL_COND_FLUX: Reflecting wall with fixed conduction flux
Depending on the value of isothp, other values may also need to be set:
  • rcodcl = conduction flux
  • epsp = emissivity
  • xlamp = conductivity (W/m/K)
  • epap = thickness (m)
  • textp = outside temperature (K)
[in]isothpboundary face type for radiative transfer
[out]tminmin allowed value of the wall temperature
[out]tmaxmax allowed value of the wall temperature
[in]txrelaxation coefficient (0 < tx < 1)
[in]dttime step (per cell)
[in]thwallinside current wall temperature (K)
[in]hfcnvpconvective exchange coefficient (W/m2/K)
[in]flcnvpconvective flux (W/m2)
[out]xlampconductivity (W/m/K)
[out]epapthickness (m)
[out]epspemissivity (>0)
[out]textpoutside temperature (K)
◆ cs_user_radiative_transfer_parameters()
void cs_user_radiative_transfer_parameters ( void  )
◆ cs_user_saturne_coupling()
void cs_user_saturne_coupling ( void  )
This is done by calling the cs_sat_coupling_define function for each coupling to add.
◆ cs_user_scaling_elec()
void cs_user_scaling_elec ( const cs_mesh_t mesh,
const cs_mesh_quantities_t mesh_quantities,
cs_real_t dt
[in]dtpointer to a cs_real_t
These options allow defining the time step synchronization policy, as well as a time step multiplier.
◆ cs_user_solver()
void cs_user_solver ( const cs_mesh_t mesh,
◆ cs_user_solver_set()
int cs_user_solver_set ( void  )
Set user solver.
1 if user solver is called, 0 otherwise
◆ cs_user_source_terms()
void cs_user_source_terms ( cs_domain_t domain,
int  f_id,
cs_real_t st_exp,
cs_real_t st_imp
[in]f_idfield id of the variable
[out]st_expexplicit source term
[out]st_impimplicit part of the source term
This function is called at each time step, for each relevant field. It is therefore necessary to test the value of the field id or name to separate the treatments of the different variables.
The additional source term is decomposed into an explicit part (st_exp) and an implicit part (st_imp) that must be provided here. The resulting equation solved by the code for a scalar f is:
\[ \rho*volume*\frac{df}{dt} + .... = st\_imp*f + st\_exp \]
Note that st_exp and st_imp are defined after the Finite Volume integration over the cells, so they include the "volume" term. More precisely:
  • st_exp is expressed in kg.[var]/s, where [var] is the unit of the variable. Its dimension is the one of the variable (3 for vectors)
  • st_imp is expressed in kg/s. Its dimension is 1 for scalars, 3x3 for vectors.
The st_exp and st_imp arrays are already initialized to 0 (or a value defined through the GUI or defined by a model) before entering the function. It is generally not useful to reset them here.
For stability reasons, Code_Saturne will not add -st_imp directly to the diagonal of the matrix, but Max(-st_imp,0). This way, the st_imp term is treated implicitely only if it strengthens the diagonal of the matrix. However, when using the second-order in time scheme, this limitation cannot be done anymore and -st_imp is added directly. The user should therefore check for the negativity of st_imp.
When using the second-order in time scheme, one should supply:
  • st_exp at time n
  • st_imp at time n+1/2
Warning
If the variable is a temperature, the resulting equation solved is:
rho*Cp*volume*dT/dt + .... = st_imp*T + st_exp
  • st_exp is expressed in W
  • st_imp is expressed in W/K
Steep source terms
In case of a complex, non-linear source term, say F(f), for variable f, the easiest method is to implement the source term explicitly.
df/dt = .... + F(f(n)) where f(n) is the value of f at time tn, the beginning of the time step.
This yields: st_exp = volume*F(f(n)) st_imp = 0
However, if the source term is potentially steep, this fully explicit method will probably generate instabilities. It is therefore wiser to partially implicit the term by writing:
df/dt = .... + dF/df*f(n+1) - dF/df*f(n) + F(f(n))
This yields: st_exp = volume*( F(f(n)) - dF/df*f(n) ) st_imp = volume*dF/df
◆ cs_user_syrthes_coupling()
void cs_user_syrthes_coupling ( void  )
This is done by calling the cs_syr_coupling_define function for each coupling to add.
◆ cs_user_syrthes_coupling_volume_h()
void cs_user_syrthes_coupling_volume_h ( int  coupling_id,
const char *  syrthes_name,
cs_lnum_t  n_elts,
cs_real_t  h_vol[]
[in]coupling_idSyrthes coupling id
[in]syrthes_namename of associated Syrthes instance
[in]n_eltsnumber of associated cells
[in]elt_idsassociated cell ids
[out]h_volassociated exchange coefficient (size: n_elts)
◆ cs_user_time_moments()
void cs_user_time_moments ( void  )
This function is called at the setup stage, once user and most model-based fields are defined, and before fine control of field output options is defined.
◆ cs_user_turbomachinery()
void cs_user_turbomachinery ( void  )
◆ cs_user_turbomachinery_rotor()
void cs_user_turbomachinery_rotor ( void  )
◆ cs_user_turbomachinery_set_rotation_velocity()
void cs_user_turbomachinery_set_rotation_velocity ( void  )
◆ cs_user_zones()
void cs_user_zones ( void  )
See Element selection criteria for details on selection criteria.
◆ csinit()
void csinit ( const int *  irgpar,
const int *  nrgpar
◆ distpr()
void distpr ( const int *  itypfb,
cs_real_t distpa
◆ dvvpst()
void dvvpst ( const int *  nummai,
const int *  numtyp,
const int *  nvar,
const cs_lnum_t ncelps,
const cs_lnum_t nfbrps,
cs_real_t  tracel[],
cs_real_t  trafbr[]
◆ findpt()
void findpt ( const cs_lnum_t ncelet,
const cs_lnum_t ncel,
const cs_real_t xyzcen,
const cs_real_t xx,
const cs_real_t yy,
const cs_real_t zz,
cs_lnum_t node,
int *  ndrang
◆ haltyp()
void haltyp ( const int *  ivoset)
◆ initi1()
void initi1 ( void  )
