cs_physical_properties.h File Reference
+ Include dependency graph for cs_physical_properties.h:
Enumerations
enum  cs_phys_prop_thermo_plane_type_t {
  CS_PHYS_PROP_PLANE_PH, CS_PHYS_PROP_PLANE_PT, CS_PHYS_PROP_PLANE_PS, CS_PHYS_PROP_PLANE_PU,
  CS_PHYS_PROP_PLANE_PV, CS_PHYS_PROP_PLANE_TS, CS_PHYS_PROP_PLANE_TX
enum  cs_phys_prop_type_t {
  CS_PHYS_PROP_PRESSURE, CS_PHYS_PROP_TEMPERATURE, CS_PHYS_PROP_ENTHALPY, CS_PHYS_PROP_ENTROPY,
  CS_PHYS_PROP_ISOBARIC_HEAT_CAPACITY, CS_PHYS_PROP_ISOCHORIC_HEAT_CAPACITY, CS_PHYS_PROP_SPECIFIC_VOLUME, CS_PHYS_PROP_DENSITY,
  CS_PHYS_PROP_INTERNAL_ENERGY, CS_PHYS_PROP_QUALITY, CS_PHYS_PROP_THERMAL_CONDUCTIVITY, CS_PHYS_PROP_DYNAMIC_VISCOSITY,
  CS_PHYS_PROP_SPEED_OF_SOUND
void cs_thermal_table_set (const char *material, const char *method, const char *reference, cs_phys_prop_thermo_plane_type_t thermo_plane, int temp_scale)
 Define thermal table. More...
void cs_thermal_table_finalize (void)
 finalize thermal table. More...
void cs_phys_prop_compute (cs_phys_prop_type_t property, cs_lnum_t n_vals, cs_lnum_t var1_stride, cs_lnum_t var2_stride, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
 Compute a physical property. More...
void cs_phys_prop_freesteam (cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
 Compute properties with Freesteam in a defined thermal plane. More...
cs_real_t cs_physical_property_get_ref_value (const char *name)
 Get reference value of a physical property. More...
void cs_physical_property_set_ref_value (const char *name, const cs_real_t val)
 Set reference value for a physical property. More...
void cs_physical_property_get_zone_values (const char *name, const char *zname, cs_real_t retval[])
 Get property reference values for a given zone. More...
void cs_physical_property_create (const char *name, const int dim, const cs_real_t refval)
 Create a physical property. More...
void cs_physical_property_define_from_value (const char *name, const char *zname, const int dim, const cs_real_t val)
 Add a property definition on a given zone using a single value. More...
void cs_physical_property_define_from_values (const char *name, const char *zname, const int dim, cs_real_t vals[])
 Add a property multi-diemnsional definition on a given zone. More...
void cs_physical_property_define_from_field (const char *name, int type_flag, int location_id, int dim, bool has_previous)
 Add a property definition based on a cs_field_t. More...
int cs_physical_property_field_id_by_name (const char *name)
 Return id of field associated to property. More...
void cs_physical_property_update_zone_values (const char *name, const char *zname, const cs_real_t vals[])
 Update reference values for a property on a given zone. More...
◆ cs_phys_prop_thermo_plane_type_t
Enumerator
◆ cs_phys_prop_type_t
Enumerator
◆ cs_phys_prop_compute()
void cs_phys_prop_compute ( cs_phys_prop_type_t  property,
cs_lnum_t  n_vals,
cs_real_t  val[]
For values var1 and var2, we can use a stride so that accesses for a given element with id i will be of the form: var[i*stride]; this allows regular access with stride 1, and access to constant variables stored as a single-valued array with a stride of 0.
[in]propertyproperty queried
[in]n_valsnumber of values
[in]var1_stridestride between successive values of var1
[in]var2_stridestride between successive values of var2
[in]var1values on first plane axis
[in]var2values on second plane axis
[out]valresulting property values
◆ cs_phys_prop_freesteam()
void cs_phys_prop_freesteam ( cs_phys_prop_thermo_plane_type_t  thermo_plane,
cs_real_t  val[]
[in]thermo_planethermodynamic plane
◆ cs_physical_property_create()
void cs_physical_property_create ( const char *  name,
const int  dim,
[in]nameproperty name
[in]dimproperty dimension
[in]refvalreference value
◆ cs_physical_property_define_from_field()
void cs_physical_property_define_from_field ( const char *  name,
int  type_flag,
int  location_id,
int  dim,
bool  has_previous
The field is created if needed
[in]type_flagfield type flag
[in]location_idlocation id flag
[in]dimfield dimension
[in]has_previousdoes the field has val_pre
◆ cs_physical_property_define_from_value()
void cs_physical_property_define_from_value ( const char *  name,
const char *  zname,
const int  dim,
const cs_real_t  val
[in]znamezone name
[in]valreference value for the zone
◆ cs_physical_property_define_from_values()
void cs_physical_property_define_from_values ( const char *  name,
const char *  zname,
const int  dim,
cs_real_t  vals[]
[in]znamezone name
[in]dimproperty dimension (>1)
[in]valsarray of values to set
◆ cs_physical_property_field_id_by_name()
int cs_physical_property_field_id_by_name ( const char *  name)
field id (int)
◆ cs_physical_property_get_ref_value()
cs_real_t cs_physical_property_get_ref_value ( const char *  name)
reference value (cs_real_t)
◆ cs_physical_property_get_zone_values()
void cs_physical_property_get_zone_values ( const char *  name,
const char *  zname,
cs_real_t  retval[]
[in]znamezone name
[in]retvalarray of values to return
◆ cs_physical_property_set_ref_value()
void cs_physical_property_set_ref_value ( const char *  name,
const cs_real_t  val
[in]valnew value to set
◆ cs_physical_property_update_zone_values()
void cs_physical_property_update_zone_values ( const char *  name,
const char *  zname,
[in]znamezone name
◆ cs_thermal_table_finalize()
void cs_thermal_table_finalize ( void  )
◆ cs_thermal_table_set()
void cs_thermal_table_set ( const char *  material,
const char *  method,
const char *  reference,
int  temp_scale
