cs_physical_properties.h
1 #ifndef __CS_PHYSICAL_PROPERTIES_H__
2 #define __CS_PHYSICAL_PROPERTIES_H__
5  * Physical properties computation and management.
31  * Local headers
34 #include "cs_defs.h"
40 typedef enum {
49
51
52 typedef enum {
53
67
69
70 /*=============================================================================
71  * Public function prototypes
72  *============================================================================*/
73
74 /*----------------------------------------------------------------------------
75  * Define thermal table.
76  *----------------------------------------------------------------------------*/
77
78 void
79 cs_thermal_table_set(const char *material,
80  const char *method,
81  const char *reference,
83  int temp_scale);
84
85 /*----------------------------------------------------------------------------
86  * Finalize thermal table
87  *----------------------------------------------------------------------------*/
88
89 void
91
92 /*----------------------------------------------------------------------------
93  * Compute a physical property.
94  *
95  * For values var1 and var2, we can use a stride so that accesses for a given
96  * element with id i will be of the form: var[i*stride]; this allows regular
97  * access with stride 1, and access to constant variables stored as a
98  * single-valued array with a stride of 0.
99  *
100  * parameters:
101  * property <-- property queried
102  * n_vals <-- number of values
103  * var1_stride <-- stride between successive values of var1
104  * var2_stride <-- stride between successive values of var2
105  * var1 <-- values on first plane axis
106  * var2 <-- values on second plane axis
107  * val --> resulting property values
108  *----------------------------------------------------------------------------*/
109
110 void
112  cs_lnum_t n_vals,
113  cs_lnum_t var1_stride,
114  cs_lnum_t var2_stride,
115  const cs_real_t var1[],
116  const cs_real_t var2[],
117  cs_real_t val[]);
118
119 /*----------------------------------------------------------------------------
120  * Compute properties with Freesteam in a defined thermal plane.
121  *
122  * parameters:
123  * thermo_plane <-- thermodynamic plane
124  * property <-- property queried
125  * n_vals <-- number of values
126  * var1 <-- values on first plane axis
127  * var2 <-- values on second plane axis
128  * val --> resulting property values
129  *
130  * returns:
131  * floating point value associated with the key id for this field
132  *----------------------------------------------------------------------------*/
133
134 void
136  cs_phys_prop_type_t property,
137  const cs_lnum_t n_vals,
138  const cs_real_t var1[],
139  const cs_real_t var2[],
140  cs_real_t val[]);
141
142 /*----------------------------------------------------------------------------*/
150 /*----------------------------------------------------------------------------*/
151
152 cs_real_t
153 cs_physical_property_get_ref_value(const char *name);
154
155 /*----------------------------------------------------------------------------*/
162 /*----------------------------------------------------------------------------*/
163
164 void
165 cs_physical_property_set_ref_value(const char *name,
166  const cs_real_t val);
167
168 /*----------------------------------------------------------------------------*/
176 /*----------------------------------------------------------------------------*/
177
178 void
179 cs_physical_property_get_zone_values(const char *name,
180  const char *zname,
181  cs_real_t retval[]);
182
183 /*----------------------------------------------------------------------------*/
191 /*----------------------------------------------------------------------------*/
192
193 void
194 cs_physical_property_create(const char *name,
195  const int dim,
196  const cs_real_t refval);
197
198 /*----------------------------------------------------------------------------*/
207 /*----------------------------------------------------------------------------*/
208
209 void
211  const char *zname,
212  const int dim,
213  const cs_real_t val);
214
224 /*----------------------------------------------------------------------------*/
225
226 void
228  const char *zname,
229  const int dim,
230  cs_real_t vals[]);
231
232 /*----------------------------------------------------------------------------*/
244 /*----------------------------------------------------------------------------*/
245
246 void
248  int type_flag,
249  int location_id,
250  int dim,
251  bool has_previous);
252
253 /*----------------------------------------------------------------------------*/
261 /*----------------------------------------------------------------------------*/
262
263 int
264 cs_physical_property_field_id_by_name(const char *name);
265
266 /*----------------------------------------------------------------------------*/
274 /*----------------------------------------------------------------------------*/
275
276 void
278  const char *zname,
279  const cs_real_t vals[]);
280
281 /*----------------------------------------------------------------------------*/
282
284
285 #endif /* __CS_PHYSICAL_PROPERTIES_H__ */
Definition: cs_physical_properties.h:57
Definition: cs_physical_properties.h:61
void cs_physical_property_create(const char *name, const int dim, const cs_real_t refval)
Create a physical property.
Definition: cs_physical_properties.c:1007
cs_phys_prop_type_t
Definition: cs_physical_properties.h:52
void cs_thermal_table_set(const char *material, const char *method, const char *reference, cs_phys_prop_thermo_plane_type_t thermo_plane, int temp_scale)
Definition: cs_physical_properties.c:300
Definition: cs_physical_properties.h:45
Definition: cs_defs.h:495
void cs_physical_property_get_zone_values(const char *name, const char *zname, cs_real_t retval[])
Get property reference values for a given zone.
Definition: cs_physical_properties.c:954
void cs_phys_prop_compute(cs_phys_prop_type_t property, cs_lnum_t n_vals, cs_lnum_t var1_stride, cs_lnum_t var2_stride, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Definition: cs_physical_properties.c:432
Definition: cs_physical_properties.h:59
void cs_physical_property_define_from_value(const char *name, const char *zname, const int dim, const cs_real_t val)
Add a property definition on a given zone using a single value.
Definition: cs_physical_properties.c:1026
Definition: cs_defs.h:307
Definition: cs_physical_properties.h:63
void cs_physical_property_set_ref_value(const char *name, const cs_real_t val)
Set reference value for a physical property.
Definition: cs_physical_properties.c:931
Definition: cs_physical_properties.h:65
Definition: cs_physical_properties.h:60
Definition: cs_physical_properties.h:40
Definition: cs_physical_properties.h:44
Definition: cs_physical_properties.h:56
Definition: cs_physical_properties.h:64
void cs_phys_prop_freesteam(cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Definition: cs_physical_properties.c:538
Definition: cs_defs.h:301
Definition: cs_defs.h:496
Definition: cs_physical_properties.h:62
void cs_physical_property_update_zone_values(const char *name, const char *zname, const cs_real_t vals[])
Update reference values for a property on a given zone.
Definition: cs_physical_properties.c:1153
cs_real_t cs_physical_property_get_ref_value(const char *name)
Get reference value of a physical property.
Definition: cs_physical_properties.c:907
Definition: cs_physical_properties.h:46
int cs_physical_property_field_id_by_name(const char *name)
Return id of field associated to property.
Definition: cs_physical_properties.c:1130
void cs_physical_property_define_from_field(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Add a property definition based on a cs_field_t.
Definition: cs_physical_properties.c:1102
Definition: cs_physical_properties.h:43
Definition: cs_physical_properties.h:48
void cs_physical_property_define_from_values(const char *name, const char *zname, const int dim, cs_real_t vals[])
Add a property multi-diemnsional definition on a given zone.
Definition: cs_physical_properties.c:1065
Definition: cs_physical_properties.h:42
Definition: cs_physical_properties.h:47
void cs_thermal_table_finalize(void)
finalize thermal table.
Definition: cs_physical_properties.c:388
Definition: cs_physical_properties.h:55
Definition: cs_physical_properties.h:66
Definition: cs_physical_properties.h:54
Definition: cs_physical_properties.h:58
