cs_gwf_soil.c File Reference
Main functions dedicated to soil management in groundwater flows when using CDO schemes. More...
#include <ctype.h>
#include <float.h>
#include <bft_mem.h>
#include "cs_hodge.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_param_types.h"
#include "cs_post.h"
#include "cs_prototypes.h"
#include "cs_reco.h"
#include "cs_volume_zone.h"
#include "cs_gwf_soil.h"
+ Include dependency graph for cs_gwf_soil.c:
Macros
#define CS_GWF_SOIL_DBG   0
cs_gwf_soil_tcs_gwf_soil_add (const char *z_name, cs_gwf_soil_hydraulic_model_t model)
 Create and add a new cs_gwf_soil_t structure. A first initialization of all members by default is performed. More...
void cs_gwf_soil_free_all (void)
 Free all cs_gwf_soil_t structures. More...
int cs_gwf_get_n_soils (void)
 Get the number of allocated soils. More...
cs_gwf_soil_tcs_gwf_soil_by_id (int id)
 Retrieve a soil structure from its id. More...
cs_gwf_soil_tcs_gwf_soil_by_name (const char *name)
 Retrieve a soil structure from its name. More...
cs_real_t cs_gwf_soil_get_bulk_density (const cs_gwf_soil_t *soil)
 Retrieve the bulk density associated to the given soil structure. More...
void cs_gwf_set_iso_saturated_soil (cs_gwf_soil_t *soil, double k_s, double theta_s, double rho)
 Set a soil defined by a saturated hydraulic model and attached to an isotropic permeability. More...
void cs_gwf_set_aniso_saturated_soil (cs_gwf_soil_t *soil, double *k_s, double theta_s, double rho)
void cs_gwf_set_iso_genuchten_soil (cs_gwf_soil_t *soil, double k_s, double theta_s, double theta_r, double rho)
 Set a soil defined by a Van Genuchten hydraulic model and attached to an anisotropic permeability. More...
void cs_gwf_set_aniso_genuchten_soil (cs_gwf_soil_t *soil, double *k_s, double theta_s, double theta_r, double rho)
void cs_gwf_set_user_soil (cs_gwf_soil_t *soil, void *input, cs_gwf_soil_update_t *update_func, cs_gwf_soil_finalize_t *free_func)
 Set a soil defined by a user-defined hydraulic model and attached to an anisotropic permeability. More...
void cs_gwf_soil_set_all_saturated (cs_property_t *permeability, cs_property_t *moisture_content, cs_field_t *moisture_field)
 Set the properties of the groundwater flow module all soils are considered as saturated. More...
void cs_gwf_build_cell2soil (cs_lnum_t n_cells)
 Build an array storing the associated soil for each cell. More...
const short int * cs_gwf_get_cell2soil (void)
 Get the array storing the associated soil for each cell. More...
void cs_gwf_soil_set_by_field (cs_property_t *permeability, cs_field_t *permea_field, cs_property_t *moisture_content, cs_field_t *moisture_field, cs_property_t *soil_capacity, cs_field_t *capacity_field)
 Set the properties of the groundwater flow module thanks to cs_field_t structure. The consequence is that the related cs_property_t structure relies on only one definition (i.e. for the whole mesh). Fields are updated by using the update function pointer associated to each soil. More...
void cs_gwf_soil_log_setup (void)
 Summary of the settings related to all cs_gwf_soil_t structures. More...
◆ CS_GWF_SOIL_DBG
◆ cs_gwf_build_cell2soil()
void cs_gwf_build_cell2soil ( cs_lnum_t  n_cells)
[in]n_cellsnumber of cells
◆ cs_gwf_get_cell2soil()
const short int* cs_gwf_get_cell2soil ( void  )
◆ cs_gwf_get_n_soils()
int cs_gwf_get_n_soils ( void  )
◆ cs_gwf_set_aniso_genuchten_soil()
void cs_gwf_set_aniso_genuchten_soil ( cs_gwf_soil_t soil,
double *  k_s,
double  theta_s,
double  theta_r,
double  rho
[in,out]soilpointer to a cs_gwf_soil_t structure
[in]k_svalue of the anisotropic saturated permeability
[in]theta_ssaturated moisture
[in]theta_rresidual moisture
[in]rhobulk density
◆ cs_gwf_set_aniso_saturated_soil()
void cs_gwf_set_aniso_saturated_soil ( cs_gwf_soil_t soil,
double *  k_s,
double  theta_s,
double  rho
[in]rhobulk density
◆ cs_gwf_set_iso_genuchten_soil()
void cs_gwf_set_iso_genuchten_soil ( cs_gwf_soil_t soil,
double  k_s,
double  theta_s,
double  theta_r,
double  rho
[in]k_svalue of the isotropic saturated permeability
[in]rhobulk density
◆ cs_gwf_set_iso_saturated_soil()
void cs_gwf_set_iso_saturated_soil ( cs_gwf_soil_t soil,
double  k_s,
double  theta_s,
double  rho
[in]k_svalue of the saturated permeability
[in]rhobulk density
◆ cs_gwf_set_user_soil()
void cs_gwf_set_user_soil ( cs_gwf_soil_t soil,
void *  input,
cs_gwf_soil_update_t update_func,
cs_gwf_soil_finalize_t free_func
[in]inputpointer to a structure cast on-the-fly
[in]update_funcpointer to the function used for updating
[in]free_funcpointer to the function used for finalizing
◆ cs_gwf_soil_add()
cs_gwf_soil_t* cs_gwf_soil_add ( const char *  z_name,
[in]z_namename of the volume zone corresponding to the soil
[in]modeltype of modeling for the hydraulic behavior
a pointer to the new allocated structure
◆ cs_gwf_soil_by_id()
cs_gwf_soil_t* cs_gwf_soil_by_id ( int  id)
[in]idid to look for
a pointer to a cs_gwf_soil_t structure
◆ cs_gwf_soil_by_name()
cs_gwf_soil_t* cs_gwf_soil_by_name ( const char *  name)
[in]namename to look for
◆ cs_gwf_soil_free_all()
void cs_gwf_soil_free_all ( void  )
◆ cs_gwf_soil_get_bulk_density()
cs_real_t cs_gwf_soil_get_bulk_density ( const cs_gwf_soil_t soil)
[in]soilpointer to a cs_gwf_soil_t structure
◆ cs_gwf_soil_log_setup()
void cs_gwf_soil_log_setup ( void  )
◆ cs_gwf_soil_set_all_saturated()
void cs_gwf_soil_set_all_saturated ( cs_property_t permeability,
cs_property_t moisture_content,
cs_field_t moisture_field
[in,out]permeabilitypointer to a cs_property_t structure
[in,out]moisture_contentpointer to a cs_property_t structure
[in,out]moisture_fieldpointer to a cs_field_t structure
◆ cs_gwf_soil_set_by_field()
void cs_gwf_soil_set_by_field ( cs_property_t permeability,
cs_field_t permea_field,
cs_field_t moisture_field,
cs_property_t soil_capacity,
cs_field_t capacity_field
[in]permea_fieldpointer to a cs_field_t structure
[in]moisture_fieldpointer to a cs_field_t structure
[in,out]soil_capacitypointer to a cs_property_t structure
[in]capacity_fieldpointer to a cs_field_t structure
