cs_equation_bc.c File Reference
#include <bft_mem.h>
#include "cs_boundary_zone.h"
#include "cs_equation_common.h"
#include "cs_evaluate.h"
#include "cs_xdef.h"
#include "cs_equation_bc.h"
+ Include dependency graph for cs_equation_bc.c:
Macros
#define CS_EQUATION_BC_DBG   0
void cs_equation_init_boundary_flux_from_bc (cs_real_t t_eval, const cs_cdo_quantities_t *cdoq, const cs_equation_param_t *eqp, cs_real_t *values)
 Set the values for the normal boundary flux stemming from the Neumann boundary conditions (zero is left where a Dirichlet is set. This can be updated later on) More...
void cs_equation_vb_set_cell_bc (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_flag_t vtx_bc_flag[], const cs_real_t dir_values[], cs_real_t t_eval, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of vertex-based schemes. More...
void cs_equation_eb_set_cell_bc (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of edge-based schemes. More...
void cs_equation_fb_set_cell_bc (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of Face-based schemes. More...
void cs_equation_compute_dirichlet_vb (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_cell_builder_t *cb, cs_flag_t *bcflag, cs_real_t *values)
 Compute the values of the Dirichlet BCs when DoFs are attached to vertices. More...
void cs_equation_compute_dirichlet_fb (const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_real_t t_eval, cs_cell_builder_t *cb, cs_real_t *values)
 Compute the values of the Dirichlet BCs when DoFs are attached to CDO face-based schemes. More...
void cs_equation_set_vertex_bc_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *vflag)
 Define an array of flags for each vertex collecting the flags of associated boundary faces. More...
void cs_equation_set_edge_bc_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *edge_flag)
 Define an array of flags for each edge collecting the flags of associated boundary faces. More...
void cs_equation_compute_neumann_sv (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to vertices. More...
void cs_equation_compute_neumann_fb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are attached to faces. More...
void cs_equation_compute_robin (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *rob_values)
 Compute the values of the Robin BCs. More...
void cs_equation_compute_circulation_eb (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, cs_real_t *values)
 Compute the values of the tangential component lying on the domain boundary. Kind of BCs used when DoFs are attached to CDO (primal) edge-based schemes. One sets the values of the circulation. More...
◆ CS_EQUATION_BC_DBG
◆ cs_equation_compute_circulation_eb()
void cs_equation_compute_circulation_eb ( cs_real_t  t_eval,
const cs_mesh_t mesh,
const cs_equation_param_t eqp,
cs_real_t values
[in]t_evaltime at which one evaluates the boundary cond.
[in]eqppointer to a cs_equation_param_t
[in,out]valuespointer to the array of values to set
◆ cs_equation_compute_dirichlet_fb()
void cs_equation_compute_dirichlet_fb ( const cs_mesh_t mesh,
const cs_cdo_bc_face_t face_bc,
cs_real_t  t_eval,
cs_cell_builder_t cb,
cs_real_t values
[in]face_bcpointer to a cs_cdo_bc_face_t structure
◆ cs_equation_compute_dirichlet_vb()
void cs_equation_compute_dirichlet_vb ( cs_real_t  t_eval,
cs_flag_t bcflag,
cs_real_t values
[in,out]bcflagpointer to an array storing type of BC
◆ cs_equation_compute_neumann_fb()
void cs_equation_compute_neumann_fb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
const cs_cell_mesh_t cm,
double *  neu_values
[in]def_idid of the definition for setting the Neumann BC
[in]flocal face number in the cs_cell_mesh_t
[in,out]neu_valuesarray storing Neumann values to use
◆ cs_equation_compute_neumann_sv()
void cs_equation_compute_neumann_sv ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
[in,out]neu_valuesarray storing the Neumann values
◆ cs_equation_compute_robin()
void cs_equation_compute_robin ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  rob_values
[in,out]rob_valuesarray storing Robin values to use
◆ cs_equation_eb_set_cell_bc()
void cs_equation_eb_set_cell_bc ( const cs_cell_mesh_t cm,
cs_cell_sys_t csys,
[in]cmpointer to a cellwise view of the mesh
[in]dir_valuesDirichlet values associated to each vertex
◆ cs_equation_fb_set_cell_bc()
void cs_equation_fb_set_cell_bc ( const cs_cell_mesh_t cm,
cs_cell_sys_t csys,
◆ cs_equation_init_boundary_flux_from_bc()
void cs_equation_init_boundary_flux_from_bc ( cs_real_t  t_eval,
const cs_cdo_quantities_t cdoq,
cs_real_t values
Set the values for the normal boundary flux stemming from the Neumann boundary conditions (zero is left where a Dirichlet is set. This can be updated later one)
◆ cs_equation_set_edge_bc_flag()
void cs_equation_set_edge_bc_flag ( const cs_cdo_connect_t connect,
cs_flag_t edge_flag
[in]face_bcpointer to a structure collecting boundary conditions applied to faces
[in,out]edge_flagBC flag on edges to define
◆ cs_equation_set_vertex_bc_flag()
void cs_equation_set_vertex_bc_flag ( const cs_cdo_connect_t connect,
cs_flag_t vflag
[in,out]vflagBC flag on vertices to define
◆ cs_equation_vb_set_cell_bc()
void cs_equation_vb_set_cell_bc ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
cs_cell_sys_t csys,
[in]vtx_bc_flagBC flags associated to vertices
