#include "cs_defs.h"#include <assert.h>#include <float.h>#include <math.h>#include <stdio.h>#include <string.h>#include "bft_mem.h"#include "bft_printf.h"#include "fvm_hilbert.h"#include "fvm_morton.h"#include "cs_all_to_all.h"#include "cs_order.h"#include "cs_parall.h"#include "cs_sort_partition.h"#include "fvm_io_num.h"
| fvm_io_num_t * | fvm_io_num_create (const cs_lnum_t parent_entity_number[], const cs_gnum_t parent_global_number[], size_t n_entities, int share_parent_global) |
| fvm_io_num_t * | fvm_io_num_create_from_select (const cs_lnum_t parent_entity_id[], const cs_gnum_t parent_global_number[], size_t n_entities, int share_parent_global) |
| fvm_io_num_t * | fvm_io_num_create_shared (const cs_gnum_t global_number[], cs_gnum_t global_count, size_t n_entities) |
| fvm_io_num_t * | fvm_io_num_create_from_sub (const fvm_io_num_t *base_io_num, const cs_lnum_t n_sub_entities[]) |
| fvm_io_num_t * | fvm_io_num_create_from_adj_s (const cs_lnum_t parent_entity_id[], const cs_gnum_t adjacency[], size_t n_entities, size_t stride) |
| fvm_io_num_t * | fvm_io_num_create_from_adj_i (const cs_lnum_t parent_entity_id[], const cs_lnum_t index[], const cs_gnum_t adjacency[], cs_lnum_t n_entities) |
| fvm_io_num_t * | fvm_io_num_create_from_sfc (const cs_coord_t coords[], int dim, size_t n_entities, fvm_io_num_sfc_t sfc_type) |
| fvm_io_num_t * | fvm_io_num_create_from_real (const cs_real_t val[], size_t n_entities) |
| fvm_io_num_t * | fvm_io_num_create_from_scan (size_t n_entities) |
| fvm_io_num_t * | fvm_io_num_destroy (fvm_io_num_t *this_io_num) |
| cs_gnum_t * | fvm_io_num_transfer_global_num (fvm_io_num_t *this_io_num) |
| cs_lnum_t | fvm_io_num_get_local_count (const fvm_io_num_t *const this_io_num) |
| cs_gnum_t | fvm_io_num_get_global_count (const fvm_io_num_t *const this_io_num) |
| const cs_gnum_t * | fvm_io_num_get_global_num (const fvm_io_num_t *const this_io_num) |
| cs_gnum_t | fvm_io_num_global_sub_size (const fvm_io_num_t *this_io_num, const cs_lnum_t n_sub_entities[]) |
| void | fvm_io_num_dump (const fvm_io_num_t *const this_io_num) |
| fvm_io_num_t* fvm_io_num_create | ( | const cs_lnum_t | parent_entity_number[], |
| const cs_gnum_t | parent_global_number[], | ||
| size_t | n_entities, | ||
| int | share_parent_global | ||
| fvm_io_num_t* fvm_io_num_create_from_adj_i | ( | const cs_lnum_t | parent_entity_id[], |
| const cs_lnum_t | index[], | ||
| const cs_gnum_t | adjacency[], | ||
| cs_lnum_t | n_entities | ||
| fvm_io_num_t* fvm_io_num_create_from_adj_s | ( | const cs_lnum_t | parent_entity_id[], |
| size_t | stride | ||
| fvm_io_num_t* fvm_io_num_create_from_real | ( | const cs_real_t | val[], |
| size_t | n_entities | ||
| fvm_io_num_t* fvm_io_num_create_from_scan | ( | size_t | n_entities | ) |
| fvm_io_num_t* fvm_io_num_create_from_select | ( | const cs_lnum_t | parent_entity_id[], |
| fvm_io_num_t* fvm_io_num_create_from_sfc | ( | const cs_coord_t | coords[], |
| int | dim, | ||
| fvm_io_num_sfc_t | sfc_type | ||
| fvm_io_num_t* fvm_io_num_create_from_sub | ( | const fvm_io_num_t * | base_io_num, |
| const cs_lnum_t | n_sub_entities[] | ||
| fvm_io_num_t* fvm_io_num_create_shared | ( | const cs_gnum_t | global_number[], |
| cs_gnum_t | global_count, | ||
| fvm_io_num_t* fvm_io_num_destroy | ( | fvm_io_num_t * | this_io_num | ) |
| void fvm_io_num_dump | ( | const fvm_io_num_t *const | this_io_num | ) |
| cs_gnum_t fvm_io_num_get_global_count | ( | const fvm_io_num_t *const | this_io_num | ) |
| const cs_gnum_t* fvm_io_num_get_global_num | ( | const fvm_io_num_t *const | this_io_num | ) |
| cs_lnum_t fvm_io_num_get_local_count | ( | const fvm_io_num_t *const | this_io_num | ) |
| cs_gnum_t fvm_io_num_global_sub_size | ( | const fvm_io_num_t * | this_io_num, |
| cs_gnum_t* fvm_io_num_transfer_global_num | ( | fvm_io_num_t * | this_io_num | ) |
