#include "fvm_defs.h"
| fvm_io_num_t * | fvm_io_num_create (const cs_lnum_t parent_entity_number[], const cs_gnum_t parent_global_number[], const size_t n_entities, const int share_parent_global) |
| fvm_io_num_t * | fvm_io_num_create_from_select (const cs_lnum_t parent_entity_id[], const cs_gnum_t parent_global_number[], size_t n_entities, int share_parent_global) |
| fvm_io_num_t * | fvm_io_num_create_shared (const cs_gnum_t global_number[], cs_gnum_t global_count, size_t n_entities) |
| fvm_io_num_t * | fvm_io_num_create_from_sub (const fvm_io_num_t *base_io_num, const cs_lnum_t n_sub_entities[]) |
| fvm_io_num_t * | fvm_io_num_create_from_adj_s (const cs_lnum_t parent_entity_id[], const cs_gnum_t adjacency[], size_t n_entities, size_t stride) |
| fvm_io_num_t * | fvm_io_num_create_from_adj_i (const cs_lnum_t parent_entity_id[], const cs_lnum_t index[], const cs_gnum_t adjacency[], cs_lnum_t n_entities) |
| fvm_io_num_t * | fvm_io_num_create_from_sfc (const cs_coord_t coords[], int dim, size_t n_entities, fvm_io_num_sfc_t sfc_type) |
| fvm_io_num_t * | fvm_io_num_create_from_real (const cs_real_t val[], size_t n_entities) |
| fvm_io_num_t * | fvm_io_num_create_from_scan (size_t n_entities) |
| fvm_io_num_t * | fvm_io_num_destroy (fvm_io_num_t *this_io_num) |
| cs_gnum_t * | fvm_io_num_transfer_global_num (fvm_io_num_t *this_io_num) |
| cs_lnum_t | fvm_io_num_get_local_count (const fvm_io_num_t *const this_io_num) |
| cs_gnum_t | fvm_io_num_get_global_count (const fvm_io_num_t *const this_io_num) |
| const cs_gnum_t * | fvm_io_num_get_global_num (const fvm_io_num_t *const this_io_num) |
| cs_gnum_t | fvm_io_num_global_sub_size (const fvm_io_num_t *this_io_num, const cs_lnum_t n_sub_entities[]) |
| void | fvm_io_num_dump (const fvm_io_num_t *const this_io_num) |
◆ fvm_io_num_t
◆ fvm_io_num_sfc_t
| Enumerator |
| FVM_IO_NUM_SFC_MORTON_BOX | |
| FVM_IO_NUM_SFC_MORTON_CUBE | |
| FVM_IO_NUM_SFC_HILBERT_BOX | |
| FVM_IO_NUM_SFC_HILBERT_CUBE | |
◆ fvm_io_num_create()
| fvm_io_num_t* fvm_io_num_create |
const cs_lnum_t |
parent_entity_number[], |
const cs_gnum_t |
parent_global_number[], |
const size_t |
n_entities, |
const int |
share_parent_global |
◆ fvm_io_num_create_from_adj_i()
◆ fvm_io_num_create_from_adj_s()
◆ fvm_io_num_create_from_real()
◆ fvm_io_num_create_from_scan()
| fvm_io_num_t* fvm_io_num_create_from_scan |
size_t |
n_entities | ) |
◆ fvm_io_num_create_from_select()
| fvm_io_num_t* fvm_io_num_create_from_select |
const cs_lnum_t |
parent_entity_id[], |
const cs_gnum_t |
size_t |
n_entities, |
int |
◆ fvm_io_num_create_from_sfc()
◆ fvm_io_num_create_from_sub()
◆ fvm_io_num_create_shared()
◆ fvm_io_num_destroy()
◆ fvm_io_num_dump()
| void fvm_io_num_dump |
const fvm_io_num_t *const |
this_io_num | ) |
◆ fvm_io_num_get_global_count()
◆ fvm_io_num_get_global_num()
◆ fvm_io_num_get_local_count()
◆ fvm_io_num_global_sub_size()
◆ fvm_io_num_transfer_global_num()
◆ fvm_io_num_sfc_type_name
| const char* fvm_io_num_sfc_type_name[] |
