fvm_io_num.h
1 #ifndef __FVM_IO_NUM_H__
2 #define __FVM_IO_NUM_H__
5  * Main structure for an I/O numbering scheme associated with mesh entities
6  * (such as cells, faces, and vertices);
7  *
8  * In parallel mode, such a scheme is important so as to redistribute
9  * locally numbered entities on n processes to files written by p
10  * processes, with p <= n.
11  *
12  * Only the case where p = 1 is presently implemented, so the numbering
13  * scheme is simply based on entity's global labels.
14  *
15  * For p > 1, it would probably be necessary to extend the numbering
16  * schemes so as to account for the fact that a given entity may have
17  * a main index on its main associated domain, but may be present
18  * as a ghost entity with another index on neighboring domains.
19  *============================================================================*/
20
21 /*
22  This file is part of Code_Saturne, a general-purpose CFD tool.
23
24  Copyright (C) 1998-2019 EDF S.A.
25
26  This program is free software; you can redistribute it and/or modify it under
27  the terms of the GNU General Public License as published by the Free Software
28  Foundation; either version 2 of the License, or (at your option) any later
29  version.
30
31  This program is distributed in the hope that it will be useful, but WITHOUT
32  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
33  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
34  details.
36  You should have received a copy of the GNU General Public License along with
37  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
38  Street, Fifth Floor, Boston, MA 02110-1301, USA.
39 */
43 #include "cs_defs.h"
45 /*----------------------------------------------------------------------------
46  * Local headers
47  *----------------------------------------------------------------------------*/
48
49 #include "fvm_defs.h"
50
51 /*----------------------------------------------------------------------------*/
52
54
56  * Macro definitions
58
59 /*============================================================================
60  * Type definitions
62
63 /*----------------------------------------------------------------------------
64  * Structure defining an I/O numbering scheme
65  *----------------------------------------------------------------------------*/
66
67 /*
68  Pointer to an I/O numbering scheme structure. The structure
69  itself is private, and is defined in fvm_io_num.c
70 */
71
72 typedef struct _fvm_io_num_t fvm_io_num_t;
73
74 /* Space-filling curve types */
75
76 typedef enum {
77
78  FVM_IO_NUM_SFC_MORTON_BOX, /* Morton (Z) curve in bounding box */
79  FVM_IO_NUM_SFC_MORTON_CUBE, /* Morton (Z) curve in bounding cube */
80  FVM_IO_NUM_SFC_HILBERT_BOX, /* Peano-Hilbert curve in bounding box */
81  FVM_IO_NUM_SFC_HILBERT_CUBE, /* Peano-Hilbert curve in bounding cube */
82
84
85 /*=============================================================================
86  * Static global variables
87  *============================================================================*/
88
89 /* Names of space-filling curve types */
90
91 extern const char *fvm_io_num_sfc_type_name[];
92
93 /*=============================================================================
94  * Public function prototypes
95  *============================================================================*/
96
97 /*----------------------------------------------------------------------------
98  * Creation of an I/O numbering structure.
99  *
100  * This function is similar to fvm_io_num_create_from_select, albeit
101  * using parent entity numbers (1 to n) instead of ids (0 to n-1).
102  *
103  * parameters:
104  * parent_entity_number <-- pointer to list of selected entitie's parent's
105  * numbers, or NULL if all first nb_ent entities
106  * are used
107  * parent_global_number <-- pointer to list of global (i.e. domain splitting
108  * independent) parent entity numbers
109  * n_entities <-- number of entities considered
110  * share_parent_global <-- if non zero, try to share parent_global_number
111  * instead of using a local copy
112  *
113  * returns:
114  * pointer to I/O numbering structure
115  *----------------------------------------------------------------------------*/
116
117 fvm_io_num_t *
118 fvm_io_num_create(const cs_lnum_t parent_entity_number[],
119  const cs_gnum_t parent_global_number[],
120  const size_t n_entities,
121  const int share_parent_global);
122
123 /*----------------------------------------------------------------------------
124  * Creation of an I/O numbering structure based on a selection of entities.
125  *
126  * parameters:
127  * parent_entity_id <-- pointer to list of selected entitie's parent's
128  * ids, or NULL if all first n_ent entities
129  * are used
130  * parent_global_number <-- pointer to list of global (i.e. domain splitting
131  * independent) parent entity numbers
132  * n_entities <-- number of entities considered
133  * share_parent_global <-- if non zero, try to share parent_global_number
134  * instead of using a local copy
135  *
136  * returns:
137  * pointer to I/O numbering structure
138  *----------------------------------------------------------------------------*/
139
140 fvm_io_num_t *
141 fvm_io_num_create_from_select(const cs_lnum_t parent_entity_id[],
142  const cs_gnum_t parent_global_number[],
143  size_t n_entities,
144  int share_parent_global);
145
146 /*----------------------------------------------------------------------------
147  * Creation of an I/O numbering structure,
148  * sharing a given global numbering array.
149  *
150  * parameters:
151  * global_number <-- pointer to list of global (i.e. domain splitting
152  * independent) entity numbers
153  * global_count <-- global number of entities
154  * n_entities <-- number of local entities considered
155  *
156  * returns:
157  * pointer to I/O numbering structure
158  *----------------------------------------------------------------------------*/
159
160 fvm_io_num_t *
161 fvm_io_num_create_shared(const cs_gnum_t global_number[],
162  cs_gnum_t global_count,
163  size_t n_entities);
164
165 /*----------------------------------------------------------------------------
166  * Creation of an I/O numbering structure based on an an initial
167  * I/O numbering and a number of new entities per base entity.
168  *
169  * This is useful for example to create an I/O numbering for
170  * triangles based on split polygons, whose I/O numbering is defined.
171  *
172  * parameters:
173  * base_io_num <-- pointer to base I/O numbering structure
174  * n_sub_entities <-- number of new entities per base entity
175  *
176  * returns:
177  * pointer to I/O numbering structure
178  *----------------------------------------------------------------------------*/
179
180 fvm_io_num_t *
181 fvm_io_num_create_from_sub(const fvm_io_num_t *base_io_num,
182  const cs_lnum_t n_sub_entities[]);
183
184 /*----------------------------------------------------------------------------
185  * Creation of an I/O numbering structure based on a strided adjacency.
186  *
187  * The corresponding entities must be locally ordered.
188  *
189  * parameters:
190  * parent_entity_id <-- pointer to list of selected entitie's parent's ids,
191  * or NULL if all first n_ent entities are used
192  * adjacency <-- entity adjacency (1 to n global numbering)
193  * n_entities <-- number of entities considered
194  * stride <-- values per entity
195  *
196  * returns:
197  * pointer to I/O numbering structure
198  *----------------------------------------------------------------------------*/
199
200 fvm_io_num_t *
201 fvm_io_num_create_from_adj_s(const cs_lnum_t parent_entity_id[],
202  const cs_gnum_t adjacency[],
203  size_t n_entities,
204  size_t stride);
205
206 /*----------------------------------------------------------------------------
207  * Creation of an I/O numbering structure based on an indexed adjacency.
208  *
209  * The corresponding entities do not need to be locally ordered.
210  *
211  * parameters:
212  * parent_entity_id <-- pointer to list of selected entitie's parent's ids,
213  * or NULL if all first n_ent entities are used
214  * index <-- index on entities for adjacency
215  * adjacency <-- entity adjacency (1 to n global numbering)
216  * n_entities <-- number of entities considered
217  *
218  * returns:
219  * pointer to I/O numbering structure
220  *----------------------------------------------------------------------------*/
221
222 fvm_io_num_t *
223 fvm_io_num_create_from_adj_i(const cs_lnum_t parent_entity_id[],
224  const cs_lnum_t index[],
225  const cs_gnum_t adjacency[],
226  cs_lnum_t n_entities);
227
228 /*----------------------------------------------------------------------------
229  * Creation of an I/O numbering structure based on a space-filling curve.
230  *
231  * It is expected that entities are unique (i.e. not duplicated on 2 or
232  * more ranks). If 2 entities have a same Morton codeor Hilbert, their global
233  * number will be determined by lexicographical ordering of coordinates.
234  *
235  * parameters:
236  * coords <-- pointer to entity coordinates (interlaced)
237  * dim <-- spatial dimension
238  * n_entities <-- number of entities considered
239  * sfc_type <-- type of space-filling curve (Morton or Hilbert)
240  *
241  * returns:
242  * pointer to I/O numbering structure
243  *----------------------------------------------------------------------------*/
244
245 fvm_io_num_t *
247  int dim,
248  size_t n_entities,
249  fvm_io_num_sfc_t sfc_type);
250
251 /*----------------------------------------------------------------------------
252  * Creation of an I/O numbering structure based on real values, assuming
253  * ordering by increasing values.
254  *
255  * It is expected that entities are unique (i.e. not duplicated on 2 or
256  * more ranks). If 2 entities have a same value, their global
257  * number will be determined by their initial order.
258  *
259  * parameters:
260  * val <-- pointer to real values
261  * n_entities <-- number of entities considered
262  *
263  * returns:
264  * pointer to I/O numbering structure
265  *----------------------------------------------------------------------------*/
266
267 fvm_io_num_t *
269  size_t n_entities);
270
271 /*----------------------------------------------------------------------------
272  * Creation of an I/O numbering structure based on a simple accumulation
273  * (i.e. scan) of counts on successive ranks.
274  *
275  * parameters:
276  * n_entities <-- number of entities considered
277  *
278  * returns:
279  * pointer to I/O numbering structure
280  *----------------------------------------------------------------------------*/
281
282 fvm_io_num_t *
283 fvm_io_num_create_from_scan(size_t n_entities);
284
285 /*----------------------------------------------------------------------------
286  * Destruction of a I/O numbering structure.
287  *
288  * parameters:
289  * this_io_num <-- pointer to structure that should be destroyed
290  *
291  * returns:
292  * NULL pointer
293  *----------------------------------------------------------------------------*/
294
295 fvm_io_num_t *
296 fvm_io_num_destroy(fvm_io_num_t * this_io_num);
297
298 /*----------------------------------------------------------------------------
299  * Transfer ownership of global numbering array from IO numbering structure.
300  *
301  * parameters:
302  * this_io_num <-> pointer to structure transferring array ownership.
303  *
304  * returns:
305  * pointer to transferred array
306  *----------------------------------------------------------------------------*/
307
308 cs_gnum_t *
310
311 /*----------------------------------------------------------------------------
312  * Return local number of entities associated with an I/O numbering
313  * structure.
314  *
315  * parameters:
316  * this_io_num <-- pointer to I/O/ numbering structure
317  *
318  * returns:
319  * local number of associated entities
320  *----------------------------------------------------------------------------*/
321
322 cs_lnum_t
323 fvm_io_num_get_local_count(const fvm_io_num_t *const this_io_num);
324
325 /*----------------------------------------------------------------------------
326  * Return global number of entities associated with an I/O numbering
327  * structure.
328  *
329  * parameters:
330  * this_io_num <-- pointer to I/O/ numbering structure
331  *
332  * returns:
333  * global number of associated entities
334  *----------------------------------------------------------------------------*/
335
336 cs_gnum_t
337 fvm_io_num_get_global_count(const fvm_io_num_t *const this_io_num);
338
339 /*----------------------------------------------------------------------------
340  * Return global numbering associated with an I/O numbering structure.
341  *
342  * parameters:
343  * this_io_num <-- pointer to I/O/ numbering structure
344  *
345  * returns:
346  * pointer to array of global numbers associated with local entities
347  * (1 to n numbering)
348  *----------------------------------------------------------------------------*/
349
350 const cs_gnum_t *
351 fvm_io_num_get_global_num(const fvm_io_num_t *const this_io_num);
352
353 /*----------------------------------------------------------------------------
354  * Return the global number of sub-entities associated with an initial
355  * entity whose global numbering is known, given the number of
356  * sub-entities per initial entity.
357  *
358  * parameters:
359  * this_io_num <-- pointer to base io numbering
360  * n_sub_entities <-- number of sub-entities per initial entity
361  * comm <-- associated MPI communicator
362  *
363  * returns:
364  * global number of sub-entities
365  *----------------------------------------------------------------------------*/
366
367 cs_gnum_t
368 fvm_io_num_global_sub_size(const fvm_io_num_t *this_io_num,
369  const cs_lnum_t n_sub_entities[]);
370
371 /*----------------------------------------------------------------------------
372  * Dump printout of a I/O numbering structure.
373  *
374  * parameters:
375  * this_io_num <-- pointer to structure that should be dumped
376  *----------------------------------------------------------------------------*/
377
378 void
379 fvm_io_num_dump(const fvm_io_num_t *const this_io_num);
380
381 /*----------------------------------------------------------------------------*/
382
384
385 #endif /* __FVM_IO_NUM_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
fvm_io_num_t * fvm_io_num_create_from_scan(size_t n_entities)
Definition: fvm_io_num.c:2623
cs_gnum_t fvm_io_num_global_sub_size(const fvm_io_num_t *this_io_num, const cs_lnum_t n_sub_entities[])
Definition: fvm_io_num.c:2784
Definition: cs_defs.h:467
fvm_io_num_t * fvm_io_num_create_from_select(const cs_lnum_t parent_entity_id[], const cs_gnum_t parent_global_number[], size_t n_entities, int share_parent_global)
Definition: fvm_io_num.c:1971
cs_gnum_t fvm_io_num_get_global_count(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2743
fvm_io_num_sfc_t
Definition: fvm_io_num.h:76
double cs_coord_t
Definition: cs_defs.h:299
Definition: cs_defs.h:302
void fvm_io_num_dump(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2829
fvm_io_num_t * fvm_io_num_create_shared(const cs_gnum_t global_number[], cs_gnum_t global_count, size_t n_entities)
Definition: fvm_io_num.c:2074
fvm_io_num_t * fvm_io_num_create_from_adj_s(const cs_lnum_t parent_entity_id[], const cs_gnum_t adjacency[], size_t n_entities, size_t stride)
Definition: fvm_io_num.c:2174
fvm_io_num_t * fvm_io_num_create_from_real(const cs_real_t val[], size_t n_entities)
Definition: fvm_io_num.c:2435
fvm_io_num_t * fvm_io_num_destroy(fvm_io_num_t *this_io_num)
Definition: fvm_io_num.c:2679
const char * fvm_io_num_sfc_type_name[]
Definition: fvm_io_num.h:80
fvm_io_num_t * fvm_io_num_create_from_sfc(const cs_coord_t coords[], int dim, size_t n_entities, fvm_io_num_sfc_t sfc_type)
Definition: fvm_io_num.c:2391
Definition: fvm_io_num.h:78
Definition: cs_defs.h:298
fvm_io_num_t * fvm_io_num_create_from_sub(const fvm_io_num_t *base_io_num, const cs_lnum_t n_sub_entities[])
Definition: fvm_io_num.c:2109
Definition: fvm_io_num.h:72
Definition: cs_defs.h:468
fvm_io_num_t * fvm_io_num_create_from_adj_i(const cs_lnum_t parent_entity_id[], const cs_lnum_t index[], const cs_gnum_t adjacency[], cs_lnum_t n_entities)
Definition: fvm_io_num.c:2257
cs_gnum_t * fvm_io_num_transfer_global_num(fvm_io_num_t *this_io_num)
Definition: fvm_io_num.c:2700
const cs_gnum_t * fvm_io_num_get_global_num(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2762
cs_lnum_t fvm_io_num_get_local_count(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2724
fvm_io_num_t * fvm_io_num_create(const cs_lnum_t parent_entity_number[], const cs_gnum_t parent_global_number[], const size_t n_entities, const int share_parent_global)
Definition: fvm_io_num.c:1929
Definition: fvm_io_num.h:81
Definition: fvm_io_num.h:79
