| void | nbcsyr (cs_lnum_t *n_couplings) |
| void | tsursy (cs_int_t *const cplnum, cs_int_t *issurf) |
| void | tvolsy (cs_int_t *const cplnum, cs_int_t *isvol) |
| void | nbesyr (const cs_int_t *coupl_num, const cs_int_t *mode, cs_int_t *n_coupl_elts) |
| void | leltsy (const cs_int_t *coupl_num, const cs_int_t *mode, cs_lnum_t *coupl_elt_list) |
| void | varsyi (cs_int_t *numsyr, cs_int_t *mode, cs_real_t *tsolid) |
| void | varsyo (cs_int_t *numsyr, cs_int_t *mode, cs_int_t *lstelt, cs_real_t *tfluid, cs_real_t *hfluid) |
| void | ctbvsy (cs_int_t *numsyr, cs_real_t *tfluid, cs_real_t *ctbimp, cs_real_t *ctbexp) |
| void | cs_syr_coupling_define (const char *syrthes_name, const char *boundary_criteria, const char *volume_criteria, char projection_axis, bool allow_nonmatching, float tolerance, int verbosity, int visualization) |
| | Define new SYRTHES coupling. More...
| void | cs_syr_coupling_all_init (void) |
| void | cs_syr_coupling_all_finalize (void) |
| int | cs_syr_coupling_n_couplings (void) |
| void | cs_syr_coupling_set_conservativity (int flag) |
| void | cs_syr_coupling_set_explicit_treatment (void) |
| void | cs_syr_coupling_log_setup (void) |
| | Log SYRTHES coupling setup information. More...
| void | cs_syr_coupling_init_meshes (void) |
| | Create coupled meshes and setup PLE locator for Syrthes couplings. More...
| void cs_syr_coupling_define |
const char * |
syrthes_name, |
const char * |
boundary_criteria, |
const char * |
volume_criteria, |
char |
projection_axis, |
bool |
allow_nonmatching, |
float |
tolerance, |
int |
verbosity, |
int |
visualization |
The arguments to cs_syr_coupling_define are:
- Parameters
| [in] | syrthes_name | matching SYRTHES application name |
| [in] | boundary_criteria | surface selection criteria, or NULL |
| [in] | volume_criteria | volume selection criteria, or NULL |
| [in] | projection_axis | x', 'y', or 'y' for 2D projection axis (case independent), or ' ' for standard 3D coupling |
| [in] | allow_nonmatching | allow nearest-neighbor mapping where matching within tolerance is not available (useful when meshes have a different level of detail) |
| [in] | tolerance | addition to local extents of each element extent = base_extent * (1 + tolerance) |
| [in] | visualization | visualization output level (0 or 1) |
In the case of a single Code_Saturne and single SYRTHES instance, the 'syrthes_name' argument is ignored, as there is only one matching possibility.
In case of multiple couplings, a coupling will be matched with available SYRTHES instances based on the 'syrthes_name' argument.
