cs_syr4_coupling.h
1 #ifndef __CS_SYR4_COUPLING_H__
2 #define __CS_SYR4_COUPLING_H__
5  * Syrthes 4 coupling
35  * Local headers
38 #include "cs_base.h"
45  * Local Macro Definitions
49  * Structure definition
51
52 /* Structure associated to Syrthes coupling */
53
54 typedef struct _cs_syr4_coupling_t cs_syr4_coupling_t;
55
56 /*============================================================================
57  * Global variables definition
59
60 /*============================================================================
61  * Public function prototypes for Fortran API
62  *============================================================================*/
63
64 /*----------------------------------------------------------------------------
65  * Compute the implicit/explicit contribution for source terms in a SYRTHES
66  * volume coupling
67  *
68  * Fortran Interface:
69  *
70  * SUBROUTINE CTBVSY (NUMSYR, TFLUID, CTBIMP, CTBEXP)
71  * *****************
72  *
73  * INTEGER NUMSYR : --> : Number of SYRTHES coupling
74  * DOUBLE PRECISION TFLUID : --> : Fluid temperature
75  * DOUBLE PRECISION CTBIMP : --> : Implicit contribution
76  * DOUBLE PRECISION CTBEXP : --> : Explicit contribution
77  *----------------------------------------------------------------------------*/
78
79 void CS_PROCF (ctbvsy, CTBVSY)
80 (
81  cs_int_t *numsyr,
82  cs_real_t *tfluid,
83  cs_real_t *ctbimp,
84  cs_real_t *ctbexp
85 );
86
87 /*============================================================================
88  * Public function prototypes
89  *============================================================================*/
90
91 /*----------------------------------------------------------------------------
92  * Get number of SYRTHES couplings.
93  *
94  * returns:
95  * number of SYRTHES couplings
96  *----------------------------------------------------------------------------*/
97
98 int
100
101 /*----------------------------------------------------------------------------
102  * Get pointer to SYRTHES coupling.
103  *
104  * parameters:
105  * coupling_id <-- Id (0 to n-1) of SYRTHES coupling
106  *
107  * returns:
108  * pointer to SYRTHES coupling structure
109  *----------------------------------------------------------------------------*/
110
112 cs_syr4_coupling_by_id(cs_int_t coupling_id);
113
114 /*----------------------------------------------------------------------------
115  * Create a syr4_coupling_t structure.
116  *
117  * parameters:
118  * dim <-- spatial mesh dimension
119  * ref_axis <-- reference axis
120  * face_sel_criterion <-- criterion for selection of boundary faces
121  * cell_sel_criterion <-- criterion for selection of cells
122  * app_name <-- SYRTHES application name
123  * allow_nonmatching <-- nearest-neighbor search for non-matching faces flag
124  * tolerance <-- addition to local extents of each element
125  * extent = base_extent * (1 + tolerance)
126  * verbosity <-- verbosity level
127  * visualization <-- visualization output flag
128  *----------------------------------------------------------------------------*/
129
130 void
131 cs_syr4_coupling_add(int dim,
132  int ref_axis,
133  const char *face_sel_criterion,
134  const char *cell_sel_criterion,
135  const char *app_name,
136  bool allow_nonmatching,
137  float tolerance,
138  int verbosity,
139  int visualization);
140
141 /*----------------------------------------------------------------------------
142  * Destroy cs_syr4_coupling_t structures
143  *----------------------------------------------------------------------------*/
144
145 void
147
148 /*----------------------------------------------------------------------------
149  * Set conservativity forcing flag to True (1) or False (0) for all defined
150  * SYRTHES couplings
151  *
152  * parameter:
153  * flag <-- Conservativity forcing flag to set
154  *----------------------------------------------------------------------------*/
155
156 void
158
159 /*----------------------------------------------------------------------------
160  * Set explicit treatment for the source terms in SYRTHES volume couplings
161  *----------------------------------------------------------------------------*/
162
163 void
165
166 /*----------------------------------------------------------------------------
167  * Initialize communicator for SYRTHES coupling
168  *
169  * parameters:
170  * syr_coupling <-> Syrthes coupling structure
171  * coupling_id <-- id of this coupling (for log file message)
172  * syr_root_rank <-- SYRTHES root rank
173  * n_syr_ranks <-- Number of ranks associated with SYRTHES
174  *----------------------------------------------------------------------------*/
175
176 void
178  int coupling_id,
179  int syr_root_rank,
180  int n_syr_ranks);
181
182 /*----------------------------------------------------------------------------
183  * Define coupled mesh and send it to SYRTHES
184  *
185  * Optional post-processing output is also built at this stage.
186  *
187  * parameters:
188  * syr_coupling <-- SYRTHES coupling structure
189  *----------------------------------------------------------------------------*/
190
191 void
193
194 /*----------------------------------------------------------------------------
195  * Return 1 if this coupling is a surface coupling else 0
196  *
197  * parameters:
198  * syr_coupling <-- SYRTHES coupling structure
199  *
200  * returns:
201  * 1 or 0
202  *----------------------------------------------------------------------------*/
203
204 int
205 cs_syr4_coupling_is_surf(const cs_syr4_coupling_t *syr_coupling);
206
207 /*----------------------------------------------------------------------------
208  * Return 1 if this coupling is a volume coupling else 0
209  *
210  * parameters:
211  * syr_coupling <-- SYRTHES coupling structure
212  *
213  * returns:
214  * 1 or 0
215  *----------------------------------------------------------------------------*/
216
217 int
218 cs_syr4_coupling_is_vol(const cs_syr4_coupling_t *syr_coupling);
219
220 /*----------------------------------------------------------------------------
221  * Get number of associated coupled elements in main mesh
222  *
223  * parameters:
224  * syr_coupling <-- SYRTHES coupling structure
225  * mode <-- 0 (surface); 1 (volume)
226  *
227  * returns:
228  * number of vertices in coupled mesh
229  *----------------------------------------------------------------------------*/
230
231 cs_lnum_t
233  int mode);
234
235 /*----------------------------------------------------------------------------
236  * Get local numbering of coupled elements
237  *
238  * parameters:
239  * syr_coupling <-- SYRTHES coupling structure
240  * cpl_elt_lst --> List of coupled elements (1 to n)
241  * mode <-- 0 (surface); 1 (volume)
242  *----------------------------------------------------------------------------*/
243
244 void
246  cs_int_t cpl_elt_lst[],
247  int mode);
248
249 /*----------------------------------------------------------------------------
250  * Receive coupling variables from SYRTHES
251  *
252  * parameters:
253  * syr_coupling <-- SYRTHES coupling structure
254  * tsolid --> solid temperature
255  * mode <-- 0: surface coupling; 1: volume coupling
256  *----------------------------------------------------------------------------*/
257
258 void
260  cs_real_t tsolid[],
261  int mode);
262
263 /*----------------------------------------------------------------------------
264  * Send coupling variables to SYRTHES
265  *
266  * parameters:
267  * syr_coupling <-- SYRTHES coupling structure
268  * cpl_elt_list <-- list of coupled boundary faces
269  * tf <-- fluid temperature
270  * hf <-- fluid heat exchange coef. (numerical or user-defined)
271  * mode <-- 0 (surface); 1 (volume)
272  *----------------------------------------------------------------------------*/
273
274 void
276  const cs_lnum_t cpl_elt_lst[],
277  cs_real_t tf[],
278  cs_real_t hf[],
279  int mode);
280
281 /*----------------------------------------------------------------------------
282  * Compute the explicit/implicit contribution to source terms in case of
283  * volume coupling with SYRTHES4
284  *
285  * parameters:
286  * syr_coupling <-- SYRTHES coupling structure
287  * tf <-- fluid temperature
288  * ctbimp <-> implicit contribution
289  * ctbexp <-> explicit contribution
290  *----------------------------------------------------------------------------*/
291
292 void
294  const cs_real_t tf[],
295  cs_real_t ctbimp[],
296  cs_real_t ctbexp[]);
297
298 /*----------------------------------------------------------------------------*/
299
301
302 #endif /* __CS_SYR4_COUPLING_H__ */
void cs_syr4_coupling_set_explicit_treatment(void)
Definition: cs_syr4_coupling.c:1488
void cs_syr4_coupling_all_destroy(void)
Definition: cs_syr4_coupling.c:1425
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
int cs_syr4_coupling_is_vol(const cs_syr4_coupling_t *syr_coupling)
Definition: cs_syr4_coupling.c:1637
void cs_syr4_coupling_recv_tsolid(cs_syr4_coupling_t *syr_coupling, cs_real_t tsolid[], int mode)
Definition: cs_syr4_coupling.c:1726
void ctbvsy(cs_int_t *numsyr, cs_real_t *tfluid, cs_real_t *ctbimp, cs_real_t *ctbexp)
Definition: cs_syr_coupling.c:745
void cs_syr4_coupling_set_conservativity(int flag)
Definition: cs_syr4_coupling.c:1478
Definition: cs_defs.h:302
cs_syr4_coupling_t * cs_syr4_coupling_by_id(cs_int_t coupling_id)
Definition: cs_syr4_coupling.c:1316
void cs_syr4_coupling_get_elt_list(const cs_syr4_coupling_t *syr_coupling, cs_int_t cpl_elt_lst[], int mode)
Definition: cs_syr4_coupling.c:1693
void cs_syr4_coupling_ts_contrib(const cs_syr4_coupling_t *syr_coupling, const cs_real_t tf[], cs_real_t ctbimp[], cs_real_t ctbexp[])
Definition: cs_syr4_coupling.c:1855
int cs_syr4_coupling_is_surf(const cs_syr4_coupling_t *syr_coupling)
Definition: cs_syr4_coupling.c:1614
int cs_syr4_coupling_n_couplings(void)
Definition: cs_syr4_coupling.c:1300
void cs_syr4_coupling_init_mesh(cs_syr4_coupling_t *syr_coupling)
Definition: cs_syr4_coupling.c:1564
Definition: cs_defs.h:298
Definition: cs_defs.h:468
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
void cs_syr4_coupling_add(int dim, int ref_axis, const char *face_sel_criterion, const char *cell_sel_criterion, const char *app_name, bool allow_nonmatching, float tolerance, int verbosity, int visualization)
Definition: cs_syr4_coupling.c:1344
void cs_syr4_coupling_send_tf_hf(cs_syr4_coupling_t *syr_coupling, const cs_lnum_t cpl_elt_lst[], cs_real_t tf[], cs_real_t hf[], int mode)
Definition: cs_syr4_coupling.c:1777
void cs_syr4_coupling_init_comm(cs_syr4_coupling_t *syr_coupling, int coupling_id, int syr_root_rank, int n_syr_ranks)
Definition: cs_syr4_coupling.c:1504
Definition: cs_syr4_coupling.h:54
cs_lnum_t cs_syr4_coupling_get_n_elts(const cs_syr4_coupling_t *syr_coupling, int mode)
Definition: cs_syr4_coupling.c:1661
