#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_halo.h"#include "cs_halo_perio.h"#include "cs_log.h"#include "cs_matrix.h"#include "cs_matrix_default.h"#include "cs_matrix_tuning.h"#include "cs_matrix_util.h"#include "cs_order.h"#include "cs_prototypes.h"#include "cs_sles.h"#include "cs_sort.h"#include "fvm_defs.h"#include "cs_grid.h"
| void | cs_grid_get_merge_options (int *rank_stride, int *cells_mean_threshold, cs_gnum_t *cells_glob_threshold, int *min_ranks) |
| Query the global multigrid parameters for parallel grid merging. More... | |
| void | cs_grid_set_merge_options (int rank_stride, int cells_mean_threshold, cs_gnum_t cells_glob_threshold, int min_ranks) |
| Set global multigrid parameters for parallel grid merging behavior. More... | |
| void | cs_grid_set_matrix_tuning (cs_matrix_fill_type_t fill_type, int max_level) |
| Set matrix tuning behavior for multigrid coarse meshes. More... | |
| void | cs_grid_set_matrix_variant (cs_matrix_fill_type_t fill_type, int level, const cs_matrix_variant_t *mv) |
| Force matrix variant selection for multigrid coarse meshes. More... | |
| void | cs_grid_log_merge_options (void) |
| Log the current settings for multigrid parallel merging. More... | |
| void cs_grid_get_merge_options | ( | int * | rank_stride, |
| int * | cells_mean_threshold, | ||
| cs_gnum_t * | cells_glob_threshold, | ||
| int * | min_ranks | ||
| [out] | rank_stride | number of ranks over which merging takes place, or NULL |
| [out] | cells_mean_threshold | mean number of cells under which merging should be applied, or NULL |
| [out] | cells_glob_threshold | global number of cells under which merging should be applied, or NULL |
| [out] | min_ranks | number of active ranks under which no merging takes place, or NULL |
| void cs_grid_log_merge_options | ( | void | ) |
| void cs_grid_set_matrix_tuning | ( | cs_matrix_fill_type_t | fill_type, |
| int | max_level | ||
The finest mesh (level 0) is handled by the default tuning options, so only coarser meshes are considered here.
| [in] | fill_type | associated matrix fill type |
| [in] | max_level | maximum level for which tuning is active |
| void cs_grid_set_matrix_variant | ( | cs_matrix_fill_type_t | fill_type, |
| int | level, | ||
| const cs_matrix_variant_t * | mv | ||
| [in] | level | level for which variant is assiged |
| [in] | mv | matrix variant to assign (NULL to unassign) |
| void cs_grid_set_merge_options | ( | int | rank_stride, |
| int | cells_mean_threshold, | ||
| cs_gnum_t | cells_glob_threshold, | ||
| int | min_ranks | ||
| [in] | rank_stride | number of ranks over which merging takes place |
| [in] | cells_mean_threshold | mean number of cells under which merging should be applied |
| [in] | cells_glob_threshold | global number of cells under which merging should be applied |
| [in] | min_ranks | number of active ranks under which no merging takes place |
