Following these steps
http://code-saturne.org/forum/viewtopic.php?f=2&t=1792
I have added a spherical obstacle and traced the streams.
Now I would like to compute the forces torsor of the fluid pressure onto the spherical surface.
Is there a way to do that ?
Gregory
surface pressure integration
Re: surface pressure integration
Hello
By default, the total stress at the boundaries should be computed and available in the postprocessing.
In addition, you can enable the postprocessing of the normal and tangential stress in the GUI (Calculation control -> Surface solution control).
You can also manipulate the values of this vector stress at the boundaries in the user subroutine cs_user_extra_operations.f90 (see example cs_user_extra_operations-global_efforts.f90).
Erwan.
Erwan.
I have checked the "stress normal" and "stress tangential" options in CODE SATURNE and can visualize them scalarly in PARAVIEW.
What I would like now is to vectorially sum the stresses on a surface to compute the global effect of stresses as one force and one moment.
The surface correspond to a separate "boundary region" type=WALL in CODE SATURNE.
Gregory
Gregory
As I said, take a look at the file cs_user_extra_operations-global_efforts.f90 in the directory SRC/EXAMPLES of your case.
In this file, first, the boundary force is retrieved in the array bfprp_for.
It is a 3*(number of boundary faces) array, since it is directly the force at the boundary which is computed.
Then the boundary faces of group 1 and 2 are selected and finally the total force exerted on this surface is computed.
The call to parrsm at the end ensures that the sum is performed on all the processors in case of parallel calculation.
To compute the moment, you just need to perform sum up a vectorial product computed at each face.
Erwan.
Erwan.
I have used cs_user_extra_operations-global_efforts.f90 to compute the front and back efforts on this object.
Radius=600
Fluid velocity : 22m/s Density 1kg/m3 Viscosity 2e-5 Pa.s
And would like to compare to a drag formula F = 0.5 x Density x Coef x Surface x (Velocity)²
With a coef between 1.2 and 1.4 for that kind of shape
cs_user_extra_operations-global_efforts.f90 gives for front face:
-325033805.78958094
5992733.2299289312
2860901.3372025760
for backface:
-816116463.33382785
8027348.1732968809
23022411.520196483
(In Salome I used radius 600 assuming millimeters. As Saturne assumes meters my efforts are 1e6 higher.)
The frontface efforts seem to correspond to the formula with a coef 1.2
But the backface efforts are more than twice !
I think I should add the front and back efforts to compute the total drag. But the result is more than x3 the formula!
Am I wrong ?
The velocity is -x direction and the shape perpendicular so there is also unexpected lateral efforts ...
Gregory
Radius=600
-325033805.78958094
5992733.2299289312
2860901.3372025760
for backface:
-816116463.33382785
8027348.1732968809
23022411.520196483
Am I wrong ?
Gregory
- (9.42 KiB) Not downloaded yet
You should integrate the (vector) over the whole obstace.
Actually, "efforts" are a stress (i.e. peru unit surface) value, and were renamed in 4.2 to make things clearer.
So you need to sum efforts.surface_norma over boundary faces of the obstacle.
