2D turbulent channel flow: pb with TKE results
gina
Re: 2D turbulent channel flow: pb with TKE results
Post by gina »
yes Mickaël i have use your xml file which i have send you Friday 01:54.
you can find as attached his listing file and my comparison with DNS.
thanks
listing.txt
(334.76 KiB) Downloaded 613 times
(5.82 KiB) Not downloaded yet
Mickael Hassanaly
Post by Mickael Hassanaly »
You use a Rc version of Code_Saturne which is not the final one. Could you download the latest version 2.0.1 and try again?
gina
Post by gina »
why is the results change between two different versions !! ?
Mickael Hassanaly
Probably because it was remaining some bug but here, it's not the case because i tested it with the version you use. My tke.dat is hereafter. So last point to check, you have to run into debug version.
Mickael
tke.dat
(4.38 KiB) Downloaded 523 times
gina
Post by gina »
here the comparison with your tke.dat file.
(6.83 KiB) Not downloaded yet
Mickael Hassanaly
you assume a u_tau=1.00005m/s but in the listing file u_tau which i suppose to be uk for Code_Saturne is about 1.77m/s in my case and in your listing, it's 3.37m/s. Could you confirm that u_tau is turbulent friction velocity in your case?
gina
Post by gina »
Hi Mickael,
exactly my turbulent friction velocity u_tau= 1,00005 m/s, my Re_tau=590
but how to introduce these values in saturne GUI?
in saturne GUI i have introduce nu= 0.001695 m²/s  where u_tau= (Re_tau*nu)/h  , h=1
and i have introduce ref velocity=18.4539 m/s
