I use the group name "interface_fs" which I have defined in Salome.
This interface is the internal fluid/solid interface of the original mesh.
I don't have files in the SRC folder.
I have attached MED file exported from Mesh.
Thank you for your help.
Conjugate heat transfert - 2D - Flow past cylinder
Re: Conjugate heat transfert - 2D - Flow past cylinder
- flow_past_cyl_100mm_y1_8ms.med
- (3.55 MiB) Downloaded 693 times
- setup.xml
- (13.68 KiB) Downloaded 699 times
I try to have 2 meshes and join them.
The result is the same. I think that I don't know how to declare the interface again.
In the joining sub-menu I choose the 2 BC defined in Salome named "interface_fs" and "interface_sf" respectively the fluid/solid interface (boundary of the fluid volume) and the solid/fluid interface (boundary of the solid volume).
CS doesn't recognize these boundaries "interface_fs" and "interface_sf", I think that the joining operation failed.
The coupling is the solver.log = 0
The standard computation fails at the same stage than the cases before.
See the solver.log.file
- run_solver.log
- (36.29 KiB) Downloaded 717 times
Maybe I'm wrong but I think it's suspecious that Saturne complains on interface named selections. I used fluid-fluid coupling with non-conformal meshes and calculation was OK. Here is my joining log:
As you can see, selection criteria in log is "IFC_CELL_AIR_FRONT_1 OR IFC_AIR_CELL_FRONT_1", in Saturne GUI it's without any quotes. In your log, there are extra-quotes and "," instead of OR. Maybe try with joining criteria interface_fs OR interface_sf ? Although, according to log, 63 faces are selected for joining. Maybe the problem related particulary to internal coupling...
Boundaries themselves are recognized correctly:
63 faces are selected for each of interface sides.
I never used internal coupling in Saturne (we usually use CFX for such cases because of auto-interface feature), but I'm potentially interested in Saturne conjugated heat transfer too.
Joining number 1:
Selection criteria: "IFC_CELL_AIR_FRONT_1 OR IFC_AIR_CELL_FRONT_1"
Parameters for the joining operation:
Shortest incident edge fraction: 0.10000
Maximum angle between joined face planes: 25.00000
Advanced joining parameters:
Verbosity level: 1
Visualization level: 1
Deepest level reachable in tree building: 30
Max boxes by leaf: 25
Max ratio of linked boxes / init. boxes: 5.00000
Max ratio of boxes for distribution: 2.00000
Merge step tolerance multiplier: 1.00000
Pre-merge factor: 0.05000
Tolerance computation mode: 1
Intersection computation mode: 1
Max. number of equiv. breaks: 500
Max. number of subfaces by face: 200
Before joining
Number of cells: 4990095
Number of interior faces: 10022384
Number of boundary faces: 201992
Number of vertices: 985348
Global number of boundary faces selected for joining: 6390
Element selection successfully done.
Global min/max. tolerance:
Glob. Num. | Tolerance | Coordinates
13747 | 0.008580 | 7.4279999733e+00 1.9880037308e+00 8.1232559681e-01 | ORI
407141 | 0.022246 | 7.4279999733e+00 4.7711644173e+00 1.4988535643e+00 | ORI
Determination of possible face intersections:
bounding-box tree layout: 2D
Global number of intersections detected: 46627
Vertex-Vertex intersections: 1701
Other intersections: 44926
Joining operation is non-conforming.
Global number of new vertices to create: 22377
Equivalences broken for 3 edges.
Edge intersections and vertex creation done.
Pre-merge for 84303 global element couples.
Max size of a merge set of vertices: 9
Excessive transitivity for 0 set(s) of vertices.
Edge removed for 237 faces (global).
Join mesh cleaning done.
Edge removed for 44 faces (global).
Merge vertices and mesh update done.
Global number of faces after splitting: 13568
Global configuration after the joining operation:
Global number of border faces to add: 0
Mesh cleaning done for degenerate faces.
Global number of cleaned interior faces: 0
Global number of cleaned border faces: 0
After joining
Number of interior faces: 10035952
Number of boundary faces: 195602
Number of vertices: 991721
Joining 1 completed (1.99 s).
Boundary zone "interface_fs"
id = 2
Number of faces = 63
Surface = 0.0015701
Center of gravity = (4.3157e-18, -0.0025, 3.2368e-18)
Perimeter = -1 (not computed)
Boundary zone "interface_sl"
id = 7
Surface = 0.0015701
Center of gravity = (-4.3157e-18, -0.0025, 0)
With the syntax 'interface_fs' OR 'interface_sf' or without the punctuation interface_fs OR interface_sf
gives exactly the same result.
Maybe my boundary declaration is not appropriate, I have 2 boundaries for the interface solid/ fluid?
Maybe someone has already define a simple case of CHT with CS where I can check everything compare to my case?
Thanks for your response. I have 2 BCs also, it's not an internal boundary and it's not a conformal mesh. The difference is that there is a fluid/fluid interface in my case. Will wait what Ivan says...
Yes, the issue in you log is here:
Code_Saturne: /home/julien/Code_Saturne/code_saturne-7.2.0/src/base/cs_selector.c:111: Warning
The group "interface_sf" in the selection criteria:
"'interface_fs','interface_sf'"
does not correspond to any boundary face.
Because the selection criteria syntax seems wrong or not working.
Actually, I need to check if the "," alternative to "or" in selection criteria really works (it seems it may not; it should in theory, but most of the time, "or" is used instead, so it is not tested much).
Can you try using:
"interface_fs or interface_sl"
As a selection criteria (no quotes needed if done in the GUI).
Can you try using:
With the join definition syntax:
the join is done but a new problem appears.
Again with some interface definition, see the solver log file
- run_solver.log
- (27.34 KiB) Downloaded 701 times
If I remove from the list of BC one of the two interface BC.
I have a new error message about wall distance.
- run_solver.log
- (36.29 KiB) Downloaded 712 times
Here is the 2 meshes of the fluid and solid parts if someone wants to try the joining and coupling.
- flow_past_cyl_fluid_mesh.med
- (3.9 MiB) Downloaded 710 times
- flow_past_cyl_solid_mesh.med
- (181.17 KiB) Downloaded 706 times
