Coding style guidelines
Master rule
Keep the style consistent !
This rule should be observed above all others. The coding style in code_saturne has evolved over the years, but unless you are ready to update a whole file to a more current style (in which case the other guidelines should be followed), try to remain consistent with the style in the current file.
For new files, use recently updated or reference examples, such as src/base/cs_field.c and src/base/cs_field.h for C, src/base/cs_array.cpp, and src/base/cs_array.h for C++.
If you consider your preferred coding style is better than the one used is superior in some manner to the one used, suggestions are welcome, and may lead to evolutions in the current style if the arguments are convincing, but remember that an inconsistent style is more time-consuming and difficult to read and understand.
Developers trying to follow a consistent style should expect help and counseling when they have questions, but those whose time is too precious to observe the existing code before providing their own or requesting assistance should understand that this is also true of those whom they expect to read their code.
General rules
The following general rules are strongly recommended:
  • Except for files in which they have a special meaning (such as Makefiles), use spaces, not tabs. Absolutely avoid tabs in Python code. Most importantly, use a decent text editor that does not randomly mix spaces and tabs. The sbin/rmb script can be used to remove trailing white-space and replace tabs with spaces, but this may appear to damage indentation when it is defined with an odd mix of spaces and tabs, so using a good editor in the first place is always preferred.
  • 80 characters maximum line length; split lines longer than this to ensure readability on small screens, or (more commonly) when reading or comparing code side-by-side on wider screens. This rule is less important for LaTeX documentation, and may be difficult to follow for some Doxygen or Markdown constructs (one could argue that using one line per paragraph and relying on line wrapping would actually make revision merging simpler).
For new developments, prefer C++ to C, as the code base will be progressively migrated to C++ (though C++ features will only be introduced by small increments)..
Punctuation
Except when adding additional white space to align similar definitions or arguments on several lines, standard English punctuation rules should be followed:
  • No white space before a punctuation mark (, ; . ), one white space after a punctuation mark.
  • Use white space before an opening parenthesis, no white space after an opening parenthesis.
  • No white space before a closing parenthesis, white-space after a closing parenthesis.
C and C++ coding style
The code_saturne coding style inherits from common conventions, with a few specific additions.
General rules
The following presentation rules should be followed:
  • Indentation step: 2 characters.
  • Do not use tabulation characters, do not leave whitespace at the end of lines.
  • Always use lowercase characters for instructions and identifiers, except for enumerations and macros which should be in uppercase.
    • A mix of lowercase and uppercase characters (for example CamelCase, often encountered in C++ libraries) is allowed in sections dealing specifically with external libraries using such coding styles.
  • Header .h files should have a mechanism to prevent multiple inclusions.
The following coding rules are strongly recommended:
  • All macro parameters must be enclosed inside parentheses.
  • A function's return type must always be defined.
  • Variables should be initialized before use (pointers are set to NULL). A good compiler should issue warnings when this is not the case, and those warnings must be acted upon;
  • when a structure definition is only needed in a single file, it is preferred to define it directly in the C source file, so as to make as little visible as possible in the matching header file. structures only used through pointers may be made opaque in this manner, which ensures that their possible future modification should not require changes in other parts of the code or have unexpected side-effects.
  • When a public function is defined in a C source file, a matching header file containing its prototype must be included.
  • Usage of global variables must be kept to a minimum, though such variables may be useful to maintain state or references to mesh or variable structures in C code callable by Fortran code. If a global variable is only needed inside a single file, it should be declared static. It it is needed in other files, then it must instead be declared extern' in the matching header file.
  • A const type must not be cast into a non-const type.
  • Every switch construct should have a default clause (which may reduce to assert(0) to check code paths in debug mode, but at least this much must be ensured).
  • A const attribute should be used when an array or structure is not modified. Recall that for example const cs_mesh_t *m means that the contents of mesh structure m are not modified by the function, while cs_mesh_t *const m only means that the pointer to m is not modified; const cs_mesh_t *const m means both, but its usage in a function prototype gives no additional useful information on the function's side effects than the first form const cs_mesh_t *m, so that form is preferred, as it does not clutter the code.
  • When an array is passed to a function, describing it as array[] is preferred to *array, as the array nature of the argument is made more visible.
  • Where both a macro or an enumerated constant could be used, an enumeration is preferred, as values will appear with the enumerated value's name under a debugger, while only a macro's expanded value will appear. An additional advantage of enumerated values is that a compiler may issue a warning when a switch construct has no case for a given enumeration value.
Line spacing
Try to be consistent regarding line spacing. Use 1 separation line to highlight code blocks, but no more (i.e. avoid 2 successive blank lines). Make the code symmetric also: when a blank line follows an opening brace {, a similar line should precede the matching closing brace }. When no such line is used after an opening brace, none should be used either before the closing brace.
Automatic formatting
A .clang-format configuration file is available in the top-level source directory, so the clang-format tool may be used to obtain an acceptable presentation. Automated formatting does not exactly follow the above recommendations, but is as close as possible using the available parameters, so can provide a good starting point, though it is not activated automatically to allow for manual fine-tuning.
Language
ANSI C11 or above is required, so C11-specific constructs are allowed. C99 variable-length arrays should be avoided, as it is not always clear whether they are allocated on the stack or heap, and are an optional feature only (though we could expect that support for those constructs will remain available on general-purpose architectures, and removed only in the embedded space).
For C++, at least C++14 is assumed.
Assertions
Assertions are conditions which must always be verified. Several expanded macro libraries may be available, but a standard C language assertion has the following properties:
  • It is only compiled in debug mode (and so incur no run-time performance penalty in production code, where the NDEBUG macro is defined).
  • When its predicate is not verified, it causes a core dump; when running under a debugger, the code is stopped inside the assertion, but does not exit, which simplifies debugging.
Assertions are thus very useful to ensure that conditions which are always expected (and not dependent on program input) are met. They also make code more readable, in the sense that it is made clear that conditions checked by an assertion are always expected, and that not handling other cases is not an programming error or omission.
If a condition may not be met for some program inputs, and not just in case of programmer error, a more complete test and call to an error handler (such as bft_error) is preferred.
Naming conventions
The following rules should be followed:
  • Identifier names are in lowercase, except for macro or enumeration definitions, which are in uppercase; words in an identifier are separated by an underscore character (for example, n_elt_groups_.
  • Global identifier names are prefixed by the matching library prefix, such as cs_= or BFT_.
  • Local (static) variable and function should be prefixed by an underscore character.
  • Index arrays used with 0 to n-1 (zero-based) numbering should be named using a idx_ or index_ prefix or suffix, while similar arrays using a 1 to n numbering (usually those that were also used in prior Fortran code) are named using a pos_ prefix or suffix.
  • In a similar manner, element identifiers should in general use a 0 to n-1 (zero-based) numbering and be named using a id_ prefix or suffix, while identifiers using a 1 to n numbering (usually those that were be also used in Fortran code) are named using a num_ prefix or suffix.
Naming of enumerations
The following form is preferred for enumerations:
typedef myclass { CS_MYCLASS_ENUM1,
CS_MYCLASS_ENUM2,
/* etc. */
} cs_myclass_t;
Naming of structures and associated functions
Macros and enumerations related to myclass structures are prefixed by CS_MYCLASS_.
Public functions implementing methods are named cs_*class_method*, while private functions are simply named: class_method and are declared static.
Files containing these functions are named class.c.
Integer types
Several integer types are found in code_saturne:
  • cs_lnum_t should be used for local entity (i.e. vertex, face, cell) numbers or connectivity. It is a signed integer, normally identical to int, but a larger size could be used in the future for very large meshes on shared memory machines.
  • cs_gnum_t should be used for global entity numbers, usually necessary only for I/O aspects. It is an unsigned 32 or 64-bit integer, depending on whether the code was configured with the --enable-long-gnum option. Global numbers should always use this type, as for very large meshes, they may exceed the maximum size of a 32-bit integer (2 147 483 648). The choice of unsigned integers is two-fold: it doubles the range of available values, and good compilers will issue warnings when this type is mixed without precaution with the usual integer types. These warnings should be heeded, as they may avoid many hours of debugging.
  • In all other cases, the standard C types int and size_t should be preferred (for example for loops over variables, probes, or any entity independent of mesh size.
Base functions and types
In the code_saturne kernel, it is preferable to use base functions provided by the BFT subsystem to the usual C functions, as those logging, exit and error-handling functions will work correctly when running in parallel, and the memory management macros ensure return value checking and allow additional logging.
The array below summarizes the replacements for usual functions:
Standard C function code_saturne macro or function Header
exit cs_exit cs_base.h
exit on error bft_error bft_error.h
printf bft_printf bft_printf.h
printf (to standard logs) cs_log_printf cs_log.h
malloc BFT_MALLOC bft_mem.h
CS_MALLOC_HD cs_base_accel.h
realloc BFT_REALLOC bft_mem.h
CS_REALLOC_HD cs_base_accel.h
free BFT_FREE bft_mem.h
CS_FREE_HD cs_base_accel.h
Internationalization
Messages for the user should always be defined in US English in the source code (which avoids using extended characters and the accompanying text encoding issues in source code).
To make future internationalization using a mechanism such as gettext() possible, translatable strings should be encased in a _( ) macro (actually an abbreviation for a call to gettext() if available, which reverts to an empty (identity) macro is internationalization is unavailable or disabled). Strings assigned to variables must be encased in a N_( ) macro (which is an `‘empty’' macro, used by the gettext toolchain to determine that those strings should appear in the translation dictionary), and the variable to which such a string is assigned should be encased in the _( ) macro where used.
Note that with UTF-8 type character strings, accented or otherwise extended characters are represented on multiple bytes. The strlen C function will return the string's real size, which may be greater than the number of output columns it uses. The cs_log_strlen function may be used to compute the printable width of a character string, while and cs_log_strpad and cs_log_strpadl may be use to pad a string.
C++ coding style
Most rules applicable to C apply here also. Note that standard C++ stream output (using std::cout ) may be practical for temporary debugging code, but should not be used instead of bft_printf or cs_log for production code.
Fortran coding style
Migration from Fortran to C
It is imperative that new code be written in C or C++ rather than in Fortran. Fortran continues to be one of the best supported languages in HPC (with C++ and C), and has some interesting features such as Co-Array Fortran (starting with in Fortran 2008), but...
  • Many free tools were available for Fortran 77, few have been extended to modern Fortran.
  • Available tools are often linked to a few major editors (Intel, NVIDIA, ...)
  • No or few "community" tools aside from PHOTRAN (for Eclipse)
    • sign of a more reduced user base;
    • compilers are not as user tested as for C and C++;
  • This is one of the main reasons for focusing more on C, less on Fortran.
    • The other being that many features we need are available in Fortran compilers only since 5 or so years, while equivalent (less complete, but sufficient) features existed in C 20 years ago (i.e. Fortran 95 and 2003 were too little, too late).
  • The lack of local variable scopes in Fortran makes it much more bug-prone than C when using OpenMP loop-based constructs.
  • C has its limitations, but is in general simpler to code for, and can interoperate easily with C++.
  • Performance of C and Fortran is similar when both are used correctly, so is not a discriminating factor.
Python coding style
The core python scripts use a coding style similar to PEP-8 PEP-8. PEP-257 (docstring conventions) is also recommended.
Other parts of the code tend to use a camelCase naming, but should otherwise adhere to the same standards. Moving the to PEP-8 style would be ideal, though to avoid confusion, this should be done in an atomic step for each module.
Documentation
Documentation of the main code is based on the Doxygen tool, whose documentation may be found on its web site.
Additional pages for the documentation may be found in the source tree, under docs/doxygen. Files containing mostly examples may use the .h or .dox extension (with .dox preferred for easier identification), and pages which describe general aspects instead of code are preferably written in Doxygen Markdown (.md extension), as this allows better readability and interoperation with some editors (such as preview, syntax highlighting, ...).
When building the code, remember to often use make html and check the docs/doxygen/doxygen_warn.log file in the build directory for errors and warnings.
When modifying arguments to a function or modifying structures, make sure the special Doxygen comments are kept up to date. Using Doxygen comments in the C code and simplified comments in the headers (see cs_medcoupling_postprocess.cxx and cs_medcoupling_postprocess.h for example) is recommended, but as this adds to the coding effort, duplicating the headers from the reference C code to the headers is not recommended since recent versions of Doxygen complain about this, so avoiding duplicates is the preferred way. For inlined functions or structures the documentation should be available in the .h files since that is where the function or structure are defined.
For functions the following structure is advised (example extracted from cs_medcoupling_postprocess.cxx):
cs_real_t
cs_medcoupling_slice_scalar_mean_weighted
const char *name, /*!<[in] name of the slice */
const cs_real_t *scalar, /*!<[in] array of scalar values (size n_cells) */
const cs_real_t *weight_s, /*!<[in] scalar weight array (n_cells) */
const cs_real_3_t *weight_v /*!<[in] vectorial weight array (n_cells) */
<Function code>
Private functions or structures should not appear in the documentation (though their arguments should be documented in the source code), so in most source files,
/*! \cond DOXYGEN_SHOULD_SKIP_THIS */
is used to mark the beginning of a section which should be ignored by Doxygen, and
/*! (DOXYGEN_SHOULD_SKIP_THIS) \endcond */
used to mark the end of that section. In most cases, this includes private structures and functions in C code, but could be extended to public function definitions if the .h file header already contains the same Doxygen-formated comments.
