#include <stdarg.h>
| typedef int | bft_printf_proxy_t(const char *const format, va_list arg_ptr) |
| | Function pointer for printf() type functions.
| typedef int | bft_printf_flush_proxy_t(void) |
| | Function pointer for fflush(stdout) type functions.
◆ bft_printf_flush_proxy_t
| typedef int bft_printf_flush_proxy_t(void) |
◆ bft_printf_proxy_t
| typedef int bft_printf_proxy_t(const char *const format, va_list arg_ptr) |
- Parameters
| [in] | format | format string, as printf() and family. |
| [in,out] | arg_ptr | pointer to variable argument list based on format string. |
◆ bft_printf()
| int bft_printf |
const char *const | format, |
This function calls vprintf() by default, or a function with similar arguments indicated by bft_printf_proxy_set().
- Parameters
| [in] | ... | variable arguments based on format string. |
- Returns
- number of characters printed, not counting the trailing '\0' used to end output strings
◆ bft_printf_flush()
| int bft_printf_flush |
void | | ) |
Flush for output of bft_printf() with modifiable behavior.
This function calls fflush(stdout) if bft_printf()'s default behavior is used. If bft_printf's behavior is modified with bft_printf_proxy_set(), bft_printf_flush()'s behavior may have to be also adjusted with bft_printf_flush_proxy_set().
- Returns
- using the default behavior, the return value is that of fflush(stdout): O upon successful completion, EOF otherwise (with errno set to indicate the error).
◆ bft_printf_flush_proxy_get()
◆ bft_printf_flush_proxy_set()
Associates a proxy function with bft_printf_flush().
- Warning
- bft_printf() is called by the default bft_error() error handler (so as to ensure that the error text appears at the end of the program output), so a bft_print_flush replacement must not itself call (directly or indirectly) bft_error() if the default error handler is used.
- Parameters
| [in] | fct | pointer to a function similar to {return fflush(stdout)}. |
◆ bft_printf_proxy_get()
Returns function associated with the bft_printf() function.
- Returns
- pointer to the vprintf() or replacement function.
◆ bft_printf_proxy_set()
Associates a vprintf() type function with the bft_printf() function.
- Parameters
| [in] | fct | pointer to a vprintf() type function. |
