void | cs_quadrature_setup (void) |
Compute constant weights for all quadratures used. | |
const char * | cs_quadrature_get_type_name (const cs_quadrature_type_t type) |
Return th name associated to a type of quadrature. | |
void | cs_quadrature_edge_2pts (const cs_real_3_t v1, const cs_real_3_t v2, double len, cs_real_3_t gpts[], double w[]) |
Compute quadrature points for an edge from v1 -> v2 (2 points) Exact for polynomial function up to order 3. | |
void | cs_quadrature_edge_3pts (const cs_real_3_t v1, const cs_real_3_t v2, double len, cs_real_3_t gpts[], double w[]) |
Compute quadrature points for an edge from v1 -> v2 (3 points) Exact for polynomial function up to order 5. | |
void | cs_quadrature_hex_8pts (const cs_real_3_t vb, const double hx, const double hy, const double hz, cs_real_3_t gpts[], double *w) |
Compute quadrature points for an orthogonal hexahedron Exact for polynomial function up to order 3. | |
void | cs_quadrature_hex_27pts (const cs_real_3_t vb, const double hx, const double hy, const double hz, cs_real_3_t gpts[], double w[]) |
Compute quadrature points for an orthogonal hexahedron Exact for polynomial function up to order 5. | |
void | cs_quadrature_tria_3pts (const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, double area, cs_real_3_t gpts[], double w[]) |
Compute quadrature points for a triangle (3 points) Exact for polynomial function up to order 2. | |
void | cs_quadrature_tria_4pts (const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, double area, cs_real_3_t gpts[], double w[]) |
Compute quadrature points for a triangle (4 points) Exact for polynomial function up to order 3. | |
void | cs_quadrature_tria_7pts (const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, double area, cs_real_3_t gpts[], double w[]) |
Compute quadrature points for a triangle (7 points) Exact for polynomial function up to order 5. | |
void | cs_quadrature_tet_4pts (const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, const cs_real_3_t v4, double vol, cs_real_3_t gpts[], double weights[]) |
Compute the quadrature in a tetrehedra. Exact for 2nd order polynomials (order 3). | |
void | cs_quadrature_tet_5pts (const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, const cs_real_3_t v4, double vol, cs_real_3_t gpts[], double weights[]) |
Compute the quadrature in a tetrehedra. Exact for 3rd order polynomials (order 4). | |
void | cs_quadrature_tet_15pts (const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, const cs_real_3_t v4, double vol, cs_real_3_t gpts[], double weights[]) |
Compute the quadrature in a tetrehedra. Exact for 5th order polynomials (order 6). | |
cs_eflag_t | cs_quadrature_get_flag (const cs_quadrature_type_t qtype, const cs_flag_t loc) |
Get the flags adapted to the given quadrature type qtype and the location on which the quadrature should be performed. |
static const double | _quad_25ov48 = 25./48. |
static const double | _quad_9ov16 = 9./16. |
static const double | _quad_over18 = 1./18. |
static const double | _quad_over6 = 1./6. |
static const double | _quad_over3 = 1./3. |
static const double | _quad_9ov40 = 9./40. |
static const double | _quad_31ov240 = 31./240. |
static const double | _tetr_quad15w3 = 10. / 189. |
static const double | _tetr_quad15w4 = 16. / 135. |
static double | _edge_quad2c1 |
static double | _edge_quad2c2 |
static double | _edge_quad3c1 |
static double | _edge_quad3c2 |
static double | _tria_quad7c1 |
static double | _tria_quad7c2 |
static double | _tria_quad7c3 |
static double | _tria_quad7c4 |
static double | _tetr_quad4c1 |
static double | _tetr_quad4c2 |
static double | _tetr_quad15g1 |
static double | _tetr_quad15g11 |
static double | _tetr_quad15g2 |
static double | _tetr_quad15g21 |
static double | _tetr_quad15g3 |
static double | _tetr_quad15g31 |
static double | _tetr_quad15w1 |
static double | _tetr_quad15w2 |
static const char | cs_quadrature_type_name [CS_QUADRATURE_N_TYPES][CS_BASE_STRING_LEN] |
void cs_quadrature_edge_2pts | ( | const cs_real_3_t | v1, |
const cs_real_3_t | v2, | ||
double | len, | ||
cs_real_3_t | gpts[], | ||
double | w[] ) |
[in] | v1 | first vertex |
[in] | v2 | second vertex |
[in] | len | length of edge [v1, v2] |
[in,out] | gpts | gauss points |
[in,out] | w | weight (same weight for the two points) |
void cs_quadrature_edge_3pts | ( | const cs_real_3_t | v1, |
double | len, | ||
double | w[] ) |
[in,out] | w | weights |
cs_eflag_t cs_quadrature_get_flag | ( | const cs_quadrature_type_t | qtype, |
const cs_flag_t | loc ) |
[in] | qtype | cs_quadrature_type_t |
[in] | loc | It could be CS_FLAG_CELL, CS_FLAG_FACE or CS_FLAG_EDGE plus CS_FLAG_PRIMAL or CS_FLAG_DUAL |
const char * cs_quadrature_get_type_name | ( | const cs_quadrature_type_t | type | ) |
[in] | type | cs_quadrature_type_t |
void cs_quadrature_hex_27pts | ( | const cs_real_3_t | vb, |
const double | hx, | ||
const double | hy, | ||
const double | hz, | ||
double | w[] ) |
[in] | vb | barycenter |
[in] | hx | length along x-dir |
[in] | hy | length along y-dir |
[in] | hz | length along z-dir |
void cs_quadrature_hex_8pts | ( | const cs_real_3_t | vb, |
double * | w ) |
void cs_quadrature_setup | ( | void | ) |
void cs_quadrature_tet_15pts | ( | const cs_real_3_t | v1, |
const cs_real_3_t | v3, | ||
const cs_real_3_t | v4, | ||
double | vol, | ||
double | weights[] ) |
[in] | v3 | third vertex |
[in] | v4 | fourth vertex |
[in] | vol | volume of tetrahedron {v1, v2, v3, v4} |
[in,out] | gpts | 15 Gauss points (size = 3*15) |
[in,out] | weights | 15 weigths related to each Gauss point |
void cs_quadrature_tet_4pts | ( | const cs_real_3_t | v1, |
double | vol, | ||
[in,out] | gpts | 4 Gauss points (size = 3*4) |
[in,out] | weights | weight (same value for all points) |
void cs_quadrature_tet_5pts | ( | const cs_real_3_t | v1, |
double | vol, | ||
[in,out] | gpts | 5 Gauss points (size = 3*5) |
[in,out] | weights | 5 weigths related to each Gauss point |
void cs_quadrature_tria_3pts | ( | const cs_real_3_t | v1, |
double | area, | ||
double | w[] ) |
[in] | area | area of triangle {v1, v2, v3} |
[in,out] | w | weight (same weight for the three points) |
void cs_quadrature_tria_4pts | ( | const cs_real_3_t | v1, |
double | area, | ||
double | w[] ) |
void cs_quadrature_tria_7pts | ( | const cs_real_3_t | v1, |
double | area, | ||
double | w[] ) |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
static |
