#include "base/cs_defs.h"#include <assert.h>#include <stdlib.h>#include <string.h>#include <float.h>#include "bft/bft_error.h"#include "base/cs_fp_exception.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "alge/cs_multigrid.h"#include "alge/cs_sles.h"#include "alge/cs_param_sles_setup.h"Functions | |
| int | cs_param_sles_setup (bool use_field_id, cs_param_sles_t *slesp) |
| Define a cs_sles_t structure in accordance with the settings in a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver) | |
| void | cs_param_sles_setup_cvg_param (bool use_field_id, const cs_param_sles_t *slesp) |
| Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param_sles_t structure. This function is used only when a first setup has been performed. | |
| int cs_param_sles_setup | ( | bool | use_field_id, |
| cs_param_sles_t * | slesp ) |
Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver)
| [in] | use_field_id | if false use system name to define a SLES |
| [in,out] | slesp | pointer to a cs_param_sles_t structure |
| void cs_param_sles_setup_cvg_param | ( | bool | use_field_id, |
| const cs_param_sles_t * | slesp ) |
One modifies only some specific options like the max. number of iterations or the relative tolerance
| [in] | use_field_id | if false use a name to retrieve the cs_sles_t struc. |
| [in] | slesp | pointer to a cs_param_sles_t structure |
