cs_param_sles_setup.h
1#ifndef __CS_PARAM_SLES_SETUP_H__
2#define __CS_PARAM_SLES_SETUP_H__
5 * Routines to handle the SLES settings relying on a cs_param_sles_t
31 * Local headers
34#include "alge/cs_param_sles.h"
46
48 * Macro definitions
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
55/*============================================================================
56 * Global variables
58
59/*============================================================================
60 * Public function prototypes
61 *============================================================================*/
62
63/*----------------------------------------------------------------------------*/
73/*----------------------------------------------------------------------------*/
74
75int
76cs_param_sles_setup(bool use_field_id,
77 cs_param_sles_t *slesp);
78
79/*----------------------------------------------------------------------------*/
91/*----------------------------------------------------------------------------*/
92
93void
94cs_param_sles_setup_cvg_param(bool use_field_id,
95 const cs_param_sles_t *slesp);
96
97#if defined(HAVE_PETSC)
98/*----------------------------------------------------------------------------*/
107/*----------------------------------------------------------------------------*/
108
109void
110cs_param_sles_setup_petsc_cmd(bool use_prefix,
111 const char *prefix,
112 const char *keyword,
113 const char *keyval);
114
115/*----------------------------------------------------------------------------*/
124/*----------------------------------------------------------------------------*/
125
126void
127cs_param_sles_setup_petsc_ksp(const char *label,
128 cs_param_sles_t *slesp,
129 void *p_ksp);
130
131/*----------------------------------------------------------------------------*/
139/*----------------------------------------------------------------------------*/
140
141void
142cs_param_sles_setup_petsc_pc_amg(const char *prefix,
143 cs_param_sles_t *slesp,
144 void *p_pc);
145#endif
146
147/*----------------------------------------------------------------------------*/
148
150
151#endif /* __CS_PARAM_SLES_SETUP_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
void cs_param_sles_setup_cvg_param(bool use_field_id, const cs_param_sles_t *slesp)
Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param...
Definition cs_param_sles_setup.cpp:3326
int cs_param_sles_setup(bool use_field_id, cs_param_sles_t *slesp)
Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Spa...
Definition cs_param_sles_setup.cpp:3249
char * label
Definition keywords.h:58
Definition cs_param_sles.h:64
