struct | cs_navsto_ac_t |
Set of parameters specific for solving the Navier-Stokes system with the "artificial compressibility" algorithm. More... | |
struct | cs_navsto_monolithic_t |
Set of parameters specific for solving the Navier-Stokes system with a fully coupled monolithic algorithm. More... | |
struct | cs_navsto_projection_t |
Set of parameters specific for solving the Navier-Stokes system with an incremental projection algorithm. More... |
cs_equation_param_t * | cs_navsto_coupling_get_momentum_eqp (const cs_navsto_param_t *nsp, void *context) |
Retrieve the cs_equation_param_t structure related to the momentum equation according to the type of coupling. | |
void * | cs_navsto_ac_create_context (cs_param_bc_type_t bc, cs_navsto_param_t *nsp) |
Allocate and initialize a context structure when the Navier-Stokes system is coupled using an Artificial Compressibility approach. | |
void * | cs_navsto_ac_free_context (void *context) |
Free the context structure related to an Artificial Compressibility approach. | |
void | cs_navsto_ac_init_setup (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, void *context) |
Start setting-up the Navier-Stokes equations when an Artificial Compressibility algorithm is used to coupled the system. No mesh information is available at this stage. | |
void | cs_navsto_ac_last_setup (const cs_navsto_param_t *nsp, void *context) |
Finalize the setup for the Navier-Stokes equations when an Artificial Compressibility algorithm is used to coupled the system. | |
cs_equation_t * | cs_navsto_ac_get_momentum_eq (void *context) |
Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of artificial compressibility coupling. | |
void * | cs_navsto_monolithic_create_context (cs_param_bc_type_t bc, cs_navsto_param_t *nsp) |
Allocate and initialize a context structure when the Navier-Stokes system is coupled using a monolithic approach. | |
void * | cs_navsto_monolithic_free_context (void *context) |
Free the context structure related to a monolithic approach. | |
void | cs_navsto_monolithic_init_setup (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, void *context) |
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to coupled the system. No mesh information is available at this stage. | |
void | cs_navsto_monolithic_last_setup (const cs_navsto_param_t *nsp, void *context) |
Finalize the setup for the Navier-Stokes equations when a monolithic algorithm is used to coupled the system. | |
cs_equation_t * | cs_navsto_monolithic_get_momentum_eq (void *context) |
Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of a monolithic coupling. | |
void * | cs_navsto_projection_create_context (cs_param_bc_type_t bc, cs_navsto_param_t *nsp) |
Allocate and initialize a context structure when the Navier-Stokes system is coupled using an incremental Projection approach in the the rotational form (see Minev & Guermond, 2006, JCP) | |
void * | cs_navsto_projection_free_context (void *context) |
Free the context structure related to a Projection approach. | |
void | cs_navsto_projection_init_setup (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, bool has_previous, void *context) |
Start setting-up the Navier-Stokes equations when a projection algorithm is used to coupled the system. No mesh information is available at this stage. | |
void | cs_navsto_projection_last_setup (const cs_cdo_quantities_t *quant, const cs_navsto_param_t *nsp, void *context) |
Finalize the setup for the Navier-Stokes equations when a projection algorithm is used to coupled the system. Connectivity and geometric quantities are available at this stage. | |
cs_equation_t * | cs_navsto_projection_get_momentum_eq (void *context) |
Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of a projection coupling. |
void * cs_navsto_ac_create_context | ( | cs_param_bc_type_t | bc, |
cs_navsto_param_t * | nsp ) |
[in] | bc | default cs_param_bc_type_t for the equation |
[in] | nsp | pointer to a cs_navsto_param_t structure |
void * cs_navsto_ac_free_context | ( | void * | context | ) |
[in,out] | context | pointer to a context structure cast on-the-fly |
cs_equation_t * cs_navsto_ac_get_momentum_eq | ( | void * | context | ) |
[in] | context | pointer to a context structure cast on-the-fly |
void cs_navsto_ac_init_setup | ( | const cs_navsto_param_t * | nsp, |
cs_adv_field_t * | adv_field, | ||
void * | context ) |
[in] | adv_field | pointer to a cs_adv_field_t structure |
void cs_navsto_ac_last_setup | ( | const cs_navsto_param_t * | nsp, |
cs_equation_param_t * cs_navsto_coupling_get_momentum_eqp | ( | const cs_navsto_param_t * | nsp, |
[in] | context | pointer to a coupling context structure |
void * cs_navsto_monolithic_create_context | ( | cs_param_bc_type_t | bc, |
[in,out] | nsp | pointer to a cs_navsto_param_t structure |
void * cs_navsto_monolithic_free_context | ( | void * | context | ) |
cs_equation_t * cs_navsto_monolithic_get_momentum_eq | ( | void * | context | ) |
void cs_navsto_monolithic_init_setup | ( | const cs_navsto_param_t * | nsp, |
void cs_navsto_monolithic_last_setup | ( | const cs_navsto_param_t * | nsp, |
void * cs_navsto_projection_create_context | ( | cs_param_bc_type_t | bc, |
void * cs_navsto_projection_free_context | ( | void * | context | ) |
cs_equation_t * cs_navsto_projection_get_momentum_eq | ( | void * | context | ) |
void cs_navsto_projection_init_setup | ( | const cs_navsto_param_t * | nsp, |
bool | has_previous, | ||
[in] | has_previous | values at different time steps (true/false) |
void cs_navsto_projection_last_setup | ( | const cs_cdo_quantities_t * | quant, |
const cs_navsto_param_t * | nsp, | ||
[in] | quant | pointer to a cs_cdo_quantities_t structure |
