1#ifndef __CS_MACFB_VECTEQ_H__
2#define __CS_MACFB_VECTEQ_H__
337 const cs_macfb_vecteq_t *eqc,
364 const cs_macfb_vecteq_t *eqc,
386 cs_cdo_assembly_t *asb);
523 void *scheme_context);
538 void *scheme_context);
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
@ dt
Definition cs_field_pointer.h:65
void cs_macfb_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition cs_macfb_vecteq.cpp:1392
void cs_macfb_vecteq_setup(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb)
Set the boundary conditions known from the settings Define an indirection array for the enforcement o...
Definition cs_macfb_vecteq.cpp:305
void cs_macfb_vecteq_solve_steady_implicit(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector diffusion equation with a MAC-Fb scheme:
Definition cs_macfb_vecteq.cpp:817
void cs_macfb_vecteq_update_fields(cs_timer_counter_t *tce, cs_field_t *fld, bool cur2prev)
Update the variables associated to cells in case of a MAC-fb scheme. This has to be done after a reso...
Definition cs_macfb_vecteq.cpp:784
cs_real_t * cs_macfb_vecteq_get_face_values(void *context, bool previous)
Retrieve an array of values at mesh faces for the current context. The lifecycle of this array is man...
Definition cs_macfb_vecteq.cpp:1649
void cs_macfb_vecteq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition cs_macfb_vecteq.cpp:1676
void cs_macfb_vecteq_sourceterm(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_macfb_builder_t *macb, const cs_real_t t_eval, const cs_real_t coef, cs_equation_builder_t *eqb, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the source term for a vector-valued MAC scheme and add it to the local rhs.
Definition cs_macfb_vecteq.cpp:511
void cs_macfb_vecteq_init_cell_system(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_real_t val_f_n[], const cs_real_t val_f_nm1[], cs_macfb_builder_t *macb, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Initialize the local structure for the current cell The algebraic system for time t^{n+1}...
Definition cs_macfb_vecteq.cpp:348
void cs_macfb_vecteq_diffusion(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, const cs_property_t *diff_pty, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Build the local matrices arising from the diffusion term in the vector-valued MAC schemes.
Definition cs_macfb_vecteq.cpp:556
void cs_macfb_vecteq_finalize_sharing(void)
Free work buffer and general structure related to CDO face-based schemes.
Definition cs_macfb_vecteq.cpp:1074
void cs_macfb_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition cs_macfb_vecteq.cpp:1559
cs_real_t * cs_macfb_vecteq_get_cell_values(void *context, bool previous)
Get the computed values at mesh cells from the inverse operation w.r.t. the static condensation (DoF ...
Definition cs_macfb_vecteq.cpp:1620
void cs_macfb_vecteq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition cs_macfb_vecteq.cpp:1764
void cs_macfb_vecteq_solve_theta(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector diffusion equation with a MAC scheme and an i...
Definition cs_macfb_vecteq.cpp:953
bool cs_macfb_vecteq_is_initialized(void)
Check if the generic structures for building a MAC scheme are allocated.
Definition cs_macfb_vecteq.cpp:979
void cs_macfb_vecteq_advection(const cs_equation_param_t *eqp, const cs_macfb_vecteq_t *eqc, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Build the local matrices arising from the convection term in the vector-valued MAC-Fb schemes.
Definition cs_macfb_vecteq.cpp:595
void cs_macfb_vecteq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition cs_macfb_vecteq.cpp:1528
void * cs_macfb_vecteq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_macfb_vecteq_t structure storing data useful for building and managing such a scheme.
Definition cs_macfb_vecteq.cpp:1110
void cs_macfb_vecteq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to CDO vector-valued face-based schemes....
Definition cs_macfb_vecteq.cpp:1000
void * cs_macfb_vecteq_free_context(void *data)
Destroy a cs_macfb_vecteq_t structure.
Definition cs_macfb_vecteq.cpp:1355
void cs_macfb_vecteq_conv_diff_reac(const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_macfb_vecteq_t *eqc, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, const cs_property_data_t *diff_pty, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Build the local matrices arising from the convection, diffusion, reaction terms in vector-valued MAC-...
Definition cs_macfb_vecteq.cpp:647
void cs_macfb_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition cs_macfb_vecteq.cpp:1058
void cs_macfb_vecteq_init_build(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_lnum_t c_id, const cs_real_t vel_f_n[], cs_cell_mesh_t *cm, cs_macfb_builder_t *macb, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Initialize stuctures for a gven cell.
Definition cs_macfb_vecteq.cpp:443
void cs_macfb_vecteq_assembly(const cs_cell_sys_t *csys, cs_cdo_system_block_t *block, cs_real_t *rhs, cs_cdo_assembly_t *asb)
Perform the assembly stage for a vector-valued system obtained with MAC scheme.
Definition cs_macfb_vecteq.cpp:749
void cs_macfb_vecteq_euler_implicit_term(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, const cs_cell_builder_t *cb, const cs_real_t dt, cs_cell_sys_t *csys)
Compute the matrix and rhs for a vector-valued MAC scheme and Euler implicit. Values are added in pla...
Definition cs_macfb_vecteq.cpp:696
Definition cs_restart.h:95
Definition cs_macfb_priv.h:51
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
Definition cs_cdo_system.h:335
Definition cs_cdo_local.h:60
Definition cs_cdo_local.h:202
Definition cs_cdo_local.h:146
Definition cs_equation_param.h:193
Definition cs_field.h:158
Definition cs_macfb_builder.h:54
Structure storing the evaluation of a property and its related data.
Definition cs_property.h:223
time step descriptor
Definition cs_time_step.h:64
