#include "base/cs_defs.h"#include <limits.h>#include <stdio.h>#include <stddef.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <ctype.h>#include <float.h>#include <assert.h>#include "bft/bft_printf.h"#include "bft/bft_mem.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "mesh/cs_mesh.h"#include "base/cs_parall.h"#include "base/cs_field.h"#include "lagr/cs_lagr.h"#include "lagr/cs_lagr_particle.h"#include "lagr/cs_lagr_tracking.h"#include "lagr/cs_lagr_post.h"#include "lagr/cs_lagr_stat.h"#include "lagr/cs_lagr_prototypes.h"#include "turb/cs_turbulence_model.h"#include "base/cs_time_step.h"#include "lagr/cs_lagr_log.h"Functions | |
| static const char * | _status (int i) |
| Return string indicating on/off depending on integer value. | |
| static const char * | _status_b (bool i) |
| Return string indicating on/off depending on boolean value. | |
| static void | _lagr_min_max_boundary_stats (int s_id, cs_lnum_t *nbrfac, cs_real_t *gmin, cs_real_t *gmax) |
| Computes min/max for boundary statistics. | |
| static void | _log_setup_injection (cs_log_t log) |
| Log Lagrangian module injection info. | |
| void | cs_lagr_log_setup (void) |
| Log Lagrangian module output in the setup file. | |
| void | cs_lagr_log_iteration (void) |
| Log Lagrangian module output in the main log file. | |
static |
Parameters:
| [in] | s_id | stat id |
| [out] | nbrfac | number of particles used for the statistics |
| [out] | gmin | min value |
| [out] | gmax | max value |
static |
| [in] | log | associated log file |
static |
| i | input integer |
static |
| b | input bool |
| void cs_lagr_log_iteration | ( | void | ) |
| void cs_lagr_log_setup | ( | void | ) |
