#include "base/cs_defs.h"#include <assert.h>#include <string.h>#include <math.h>#include <float.h>#include "bft/bft_printf.h"#include "fvm/fvm_io_num.h"#include "fvm/fvm_nodal.h"#include "fvm/fvm_nodal_from_desc.h"#include "fvm/fvm_nodal_order.h"#include "base/cs_all_to_all.h"#include "base/cs_mem.h"#include "base/cs_order.h"#include "base/cs_search.h"#include "mesh/cs_join_post.h"#include "mesh/cs_join_set.h"#include "mesh/cs_join_util.h"#include "base/cs_parall.h"#include "mesh/cs_join_mesh.h"Functions | |
| cs_join_mesh_t * | cs_join_mesh_create (const char *name) |
| cs_join_mesh_t * | cs_join_mesh_create_from_glob_sel (const char *mesh_name, cs_lnum_t n_elts, const cs_gnum_t glob_sel[], const cs_gnum_t gnum_rank_index[], const cs_join_mesh_t *local_mesh) |
| cs_join_mesh_t * | cs_join_mesh_create_from_subset (const char *mesh_name, cs_lnum_t subset_size, const cs_lnum_t selection[], const cs_join_mesh_t *parent_mesh) |
| cs_join_mesh_t * | cs_join_mesh_create_from_select (const char *name, const cs_join_param_t param, cs_join_select_t *selection, const cs_lnum_t b_f2v_idx[], const cs_lnum_t b_f2v_lst[], const cs_lnum_t i_f2v_idx[], const cs_lnum_t i_f2v_lst[], const cs_lnum_t n_vertices, const cs_real_t vtx_coord[], const cs_gnum_t vtx_gnum[]) |
| void | cs_join_mesh_destroy (cs_join_mesh_t **mesh) |
| void | cs_join_mesh_reset (cs_join_mesh_t *mesh) |
| void | cs_join_mesh_copy (cs_join_mesh_t **mesh, const cs_join_mesh_t *ref_mesh) |
| void | cs_join_mesh_minmax_tol (cs_join_param_t param, cs_join_mesh_t *mesh) |
| void | cs_join_mesh_destroy_edges (cs_join_edges_t **edges) |
| void | cs_join_mesh_face_order (cs_join_mesh_t *mesh) |
| void | cs_join_mesh_vertex_clean (cs_join_mesh_t *mesh) |
| void | cs_join_mesh_clean (cs_join_mesh_t *mesh, int verbosity) |
| cs_join_edges_t * | cs_join_mesh_define_edges (const cs_join_mesh_t *mesh) |
| cs_lnum_t | cs_join_mesh_get_edge (cs_lnum_t v1_num, cs_lnum_t v2_num, const cs_join_edges_t *edges) |
| void | cs_join_mesh_update (cs_join_mesh_t *mesh, const cs_join_edges_t *edges, const cs_lnum_t edge_index[], const cs_lnum_t edge_new_vtx_lst[], cs_lnum_t n_new_vertices, const cs_lnum_t old2new[]) |
| cs_real_t * | cs_join_mesh_get_face_normal (const cs_join_mesh_t *mesh) |
| void | cs_join_mesh_get_edge_face_adj (const cs_join_mesh_t *mesh, const cs_join_edges_t *edges, cs_lnum_t *edge_face_idx[], cs_lnum_t *edge_face_lst[]) |
| void | cs_join_mesh_dump_vertex (FILE *f, const cs_join_vertex_t vertex) |
| void | cs_join_mesh_dump (FILE *f, const cs_join_mesh_t *mesh) |
| void | cs_join_mesh_dump_edges (FILE *f, const cs_join_edges_t *edges, const cs_join_mesh_t *mesh) |
| void cs_join_mesh_clean | ( | cs_join_mesh_t * | mesh, |
| int | verbosity ) |
| void cs_join_mesh_copy | ( | cs_join_mesh_t ** | mesh, |
| const cs_join_mesh_t * | ref_mesh ) |
| cs_join_mesh_t * cs_join_mesh_create | ( | const char * | name | ) |
| cs_join_mesh_t * cs_join_mesh_create_from_glob_sel | ( | const char * | mesh_name, |
| cs_lnum_t | n_elts, | ||
| const cs_gnum_t | glob_sel[], | ||
| const cs_gnum_t | gnum_rank_index[], | ||
| const cs_join_mesh_t * | local_mesh ) |
| cs_join_mesh_t * cs_join_mesh_create_from_select | ( | const char * | name, |
| const cs_join_param_t | param, | ||
| cs_join_select_t * | selection, | ||
| const cs_lnum_t | b_f2v_idx[], | ||
| const cs_lnum_t | b_f2v_lst[], | ||
| const cs_lnum_t | i_f2v_idx[], | ||
| const cs_lnum_t | i_f2v_lst[], | ||
| const cs_lnum_t | n_vertices, | ||
| const cs_real_t | vtx_coord[], | ||
| const cs_gnum_t | vtx_gnum[] ) |
| cs_join_mesh_t * cs_join_mesh_create_from_subset | ( | const char * | mesh_name, |
| cs_lnum_t | subset_size, | ||
| const cs_lnum_t | selection[], | ||
| const cs_join_mesh_t * | parent_mesh ) |
| cs_join_edges_t * cs_join_mesh_define_edges | ( | const cs_join_mesh_t * | mesh | ) |
| void cs_join_mesh_destroy | ( | cs_join_mesh_t ** | mesh | ) |
| void cs_join_mesh_destroy_edges | ( | cs_join_edges_t ** | edges | ) |
| void cs_join_mesh_dump | ( | FILE * | f, |
| const cs_join_mesh_t * | mesh ) |
| void cs_join_mesh_dump_edges | ( | FILE * | f, |
| const cs_join_edges_t * | edges, | ||
| void cs_join_mesh_dump_vertex | ( | FILE * | f, |
| const cs_join_vertex_t | vertex ) |
| void cs_join_mesh_face_order | ( | cs_join_mesh_t * | mesh | ) |
| cs_lnum_t cs_join_mesh_get_edge | ( | cs_lnum_t | v1_num, |
| cs_lnum_t | v2_num, | ||
| const cs_join_edges_t * | edges ) |
| void cs_join_mesh_get_edge_face_adj | ( | const cs_join_mesh_t * | mesh, |
| cs_lnum_t * | edge_face_idx[], | ||
| cs_lnum_t * | edge_face_lst[] ) |
| cs_real_t * cs_join_mesh_get_face_normal | ( | const cs_join_mesh_t * | mesh | ) |
| void cs_join_mesh_minmax_tol | ( | cs_join_param_t | param, |
| void cs_join_mesh_reset | ( | cs_join_mesh_t * | mesh | ) |
| void cs_join_mesh_update | ( | cs_join_mesh_t * | mesh, |
| const cs_lnum_t | edge_index[], | ||
| const cs_lnum_t | edge_new_vtx_lst[], | ||
| cs_lnum_t | n_new_vertices, | ||
| const cs_lnum_t | old2new[] ) |
| void cs_join_mesh_vertex_clean | ( | cs_join_mesh_t * | mesh | ) |
