Structure and functions handling the way to enforce interior degrees of freedom. More...
#include "base/cs_defs.h"#include <assert.h>#include <string.h>#include <float.h>#include "bft/bft_mem.h"#include "base/cs_array.h"#include "cdo/cs_cdo_bc.h"#include "base/cs_parall.h"#include "cdo/cs_enforcement.h"Macros | |
| #define | CS_ENFORCEMENT_DBG 0 |
| #define CS_ENFORCEMENT_DBG 0 |
| cs_real_t * cs_enforcement_define_at_edges | ( | const cs_cdo_connect_t * | connect, |
| int | n_params, | ||
| cs_enforcement_param_t ** | efp_array ) |
Build a cs_enforcement_t structure for edge-based scheme.
| [in] | connect | pointer to a cs_cdo_connect_t |
| [in] | n_params | number of enforcement parameters |
| [in] | efp_array | array of parameter structures defining the enforcement |
| cs_real_t * cs_enforcement_define_at_faces | ( | const cs_cdo_connect_t * | connect, |
Build a cs_enforcement_t structure for face-based scheme.
| cs_real_t * cs_enforcement_define_at_vertices | ( | const cs_cdo_connect_t * | connect, |
Build a cs_enforcement_t structure for vertex-based scheme.
| bool cs_enforcement_dofs_cw | ( | const cs_real_t * | forced_values, |
| cs_real_t * | cw_forced_values ) |
Build the cell-wise value to enforce.
| [in] | forced_values | values to enforce or FLT_MAX |
| [in,out] | cw_forced_values | local values to enforce |
| cs_enforcement_param_t * cs_enforcement_param_copy | ( | const cs_enforcement_param_t * | ref | ) |
Copy a cs_enforcement_param_t structure.
| [in] | ref | reference structure to copy |
| cs_enforcement_param_t * cs_enforcement_param_create | ( | cs_enforcement_selection_t | sel_type, |
| cs_enforcement_type_t | type, | ||
| int | stride, | ||
| cs_lnum_t | n_elts, | ||
| const cs_real_t * | values ) |
Create and define a cs_enforcement_param_t structure.
| [in] | sel_type | type of elements which have been selected |
| [in] | type | way to set values for the selected elements |
| [in] | stride | number of values to enforce by element |
| [in] | n_elts | number of selected elements locally |
| [in] | elt_ids | list of element ids |
| [in] | values | array of values to enforce |
| void cs_enforcement_param_free | ( | cs_enforcement_param_t ** | p_efp | ) |
Free a cs_enforcement_param_t structure.
| [in,out] | p_efp | double pointer to the structure to free |
| void cs_enforcement_param_log | ( | const char * | eqname, |
| const cs_enforcement_param_t * | efp ) |
Log a cs_enforcement_param_t structure.
| [in] | efp | pointer to a cs_enforcement_param_t structure |
| void cs_enforcement_param_reset | ( | cs_enforcement_param_t * | efp, |
| cs_enforcement_selection_t | sel_type, | ||
| int | stride, | ||
Reset an existing cs_enforcement_param_t structure.
| [in,out] | efp | pointer to a cs_enforcement_param_t structure |
