1#ifndef __CS_ENFORCEMENT_H__
2#define __CS_ENFORCEMENT_H__
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t * cs_enforcement_define_at_faces(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for face-based scheme.
Definition cs_enforcement.cpp:500
void cs_enforcement_param_log(const char *eqname, const cs_enforcement_param_t *efp)
Log a cs_enforcement_param_t structure.
Definition cs_enforcement.cpp:281
cs_enforcement_selection_t
Type of entities used to define the selection where the enforcement takes place.
Definition cs_enforcement.h:63
@ CS_ENFORCEMENT_SELECTION_VERTICES
Definition cs_enforcement.h:68
@ CS_ENFORCEMENT_SELECTION_EDGES
Definition cs_enforcement.h:67
@ CS_ENFORCEMENT_SELECTION_CELLS
Definition cs_enforcement.h:65
@ CS_ENFORCEMENT_SELECTION_FACES
Definition cs_enforcement.h:66
cs_real_t * cs_enforcement_define_at_edges(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for edge-based scheme.
Definition cs_enforcement.cpp:629
cs_enforcement_param_t * cs_enforcement_param_create(cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
Create and define a cs_enforcement_param_t structure.
Definition cs_enforcement.cpp:111
void cs_enforcement_param_free(cs_enforcement_param_t **p_efp)
Free a cs_enforcement_param_t structure.
Definition cs_enforcement.cpp:254
void cs_enforcement_param_reset(cs_enforcement_param_t *efp, cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
Reset an existing cs_enforcement_param_t structure.
Definition cs_enforcement.cpp:172
cs_enforcement_param_t * cs_enforcement_param_copy(const cs_enforcement_param_t *ref)
Copy a cs_enforcement_param_t structure.
Definition cs_enforcement.cpp:228
Describe the way the values to enforce are defined.
Definition cs_enforcement.h:77
@ CS_ENFORCEMENT_BY_DOF_VALUES
Definition cs_enforcement.h:80
@ CS_ENFORCEMENT_BY_CONSTANT
Definition cs_enforcement.h:79
cs_real_t * cs_enforcement_define_at_vertices(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for vertex-based scheme.
Definition cs_enforcement.cpp:371
bool cs_enforcement_dofs_cw(const cs_real_t *forced_values, cs_cell_sys_t *csys, cs_real_t *cw_forced_values)
Build the cell-wise value to enforce.
Definition cs_enforcement.cpp:758
Definition cs_cdo_connect.h:61
Definition cs_cdo_local.h:146
Set of data defining an enforcement.
Definition cs_enforcement.h:89
int stride
Definition cs_enforcement.h:96
Definition cs_enforcement.h:92
cs_real_t * values
Definition cs_enforcement.h:97
cs_lnum_t n_elts
Definition cs_enforcement.h:94
cs_enforcement_selection_t selection_type
Definition cs_enforcement.h:91
cs_lnum_t * elt_ids
Definition cs_enforcement.h:95
