The Examples function is required to compute a volume exchange coefficient for SYRTHES coupling.
Examples
The following code blocks show two examples of computation of a volume exchange coefficient.
Example 1
The first example corresponds to a constant volume exchange coefficient:
h_vol[i] = hvol_cst;
Definition: cs_defs.h:342
Definition: cs_defs.h:335
Example 2
The second example corresponds to a variable volume exchange coefficient defined as follows :
with S is the surface area where exchanges take place by unit of volume and
First, the values of the different fields that will be needed for the computation of the volume exchange coefficient are retrieved.
const cs_real_t *cpro_cp =
nullptr, *cpro_viscls =
nullptr;
cp_step = 1;
else {
if (viscl_id > -1) {
viscls_step = 1;
else {
cpro_viscls = &visls_0;
const int is_temperature
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_field.cpp:3275
Definition: cs_field.cpp:2465
double cs_field_get_key_double(const cs_field_t *f, int key_id)
Return a floating point value for a given key associated with a field.
Definition: cs_field.cpp:3455
Definition: cs_field.cpp:2781
@ mu
Definition: cs_field_pointer.h:105
@ vel
@ cp
Definition: cs_field_pointer.h:102
@ rho
Definition: cs_field_pointer.h:99
#define CS_F_(e)
Definition: cs_physical_constants.cpp:465
cs_field_t * cs_thermal_model_field(void)
Definition: cs_thermal_model.cpp:216
real(c_double), pointer, save cp0
reference specific heat.
Definition: cstphy.f90:236
Definition: cs_field.h:131
cs_real_t * val
Definition: cs_field.h:152
double cp0
Definition: cs_physical_constants.h:83
Then the coefficient can be computed and assigned to all cells.
if (is_temperature) {
lambda = cpro_viscls[c_id*viscls_step];
else {
lambda_over_cp = cpro_viscls[c_id*viscls_step];
cs_real_t nu = 0.023 * pow(re, 0.8) * pow(pr, 1./3.);
h_vol[i] = h_corr * sexcvo;
@ lambda
Definition: cs_field_pointer.h:108
static CS_F_HOST_DEVICE cs_real_t cs_math_3_norm(const cs_real_t v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:765
real(c_double), pointer, save fmax
Definition: coincl.f90:185
Not that in this example, no test is done on the coupling id or Syrthes instance name. The corresponding arguments can be used to apply specific computations in cas of multiple couplings.
Also, although a test is done to check if the scalar behaves as a temperature regarding multiplication by Cp for more generality, the Syrthes volume coupling currently only handles the temperature variable.
