#include "cs_base.h"#include "cs_field.h"#include "cs_volume_zone.h"#include "cs_boundary_zone.h"
Include dependency graph for cs_meg_prototypes.h:Go to the source code of this file.
| void | cs_meg_boundary_function (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *field_name, const char *condition, cs_real_t *retvals) |
| void | cs_meg_volume_function (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *fields_names, cs_real_t *fvals[]) |
| void | cs_meg_initialization (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *field_name, cs_real_t *retvals) |
| void | cs_meg_source_terms (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *name, const char *source_type, cs_real_t *retvals) |
| void | cs_meg_immersed_boundaries_inout (int *ipenal, const char *object_name, cs_real_t xyz[3], cs_real_t t) |
| void | cs_meg_fsi_struct (const char *object_type, const char *name, const cs_real_t fluid_f[], cs_real_t val[]) |
| This function is used to query FSI internal coupling structure values for a given boundary and structure. More... | |
| void | cs_meg_post_activate (void) |
| This function is used to activate postprocessing writers. More... | |
| void | cs_meg_post_profiles (const char *name, int n_coords, cs_real_t coords[][3]) |
| This function is used to define profile coordinates. More... | |
| void | cs_meg_post_calculator (const char *name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], cs_real_t *retvals) |
| This function is used to compute user defined calculator formulae. The mathematical expression is defined in the GUI. More... | |
| void cs_meg_boundary_function | ( | const char * | zone_name, |
| const cs_lnum_t | n_elts, | ||
| const cs_real_t | xyz[][3], | ||
| const char * | field_name, | ||
| const char * | condition, | ||
| cs_real_t * | retvals | ||
| void cs_meg_fsi_struct | ( | const char * | object_type, |
| const char * | name, | ||
| const cs_real_t | fluid_f[], | ||
| cs_real_t | val[] | ||
| [in] | object_type | name of object type |
| [in] | name | name of matching boundary |
| [in] | fluid_f | array of fluid forces on the object |
| [in,out] | val[] | matrix or vector coefficients |
| void cs_meg_immersed_boundaries_inout | ( | int * | ipenal, |
| const char * | object_name, | ||
| cs_real_t | xyz[3], | ||
| cs_real_t | t | ||
| void cs_meg_initialization | ( | const char * | zone_name, |
| void cs_meg_post_activate | ( | void | ) |
| void cs_meg_post_calculator | ( | const char * | name, |
| [in] | field_name | function name |
| [in] | n_elts | number of elements related to the zone |
| [in] | elt_ids | list of element ids related to the zone |
| [in] | xyz | list of coordinates related to the zone |
| [out] | retvals | array of computed values |
| void cs_meg_post_profiles | ( | const char * | name, |
| int | n_coords, | ||
| cs_real_t | coords[][3] | ||
| [in] | name | name of matching profile |
| [in] | n_coords | number of point coordinates |
| [in,out] | coords | point coordinates |
| void cs_meg_source_terms | ( | const char * | zone_name, |
| const char * | source_type, | ||
