#include "cs_cdo_connect.h"#include "cs_cdo_local.h"#include "cs_cdo_quantities.h"#include "cs_param_cdo.h"#include "cs_property.h"#include "cs_sdm.h"
Include dependency graph for cs_hodge.h:Go to the source code of this file.
| struct | cs_hodge_param_t |
| Structure storing all metadata/parameters related to the usage of a discrete Hodge operator. More... | |
| struct | cs_hodge_t |
| Structure associated to a discrete Hodge operator *. More... | |
| typedef bool() | cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell. The discrete Hodge operator is stored in hodge->matrix whereas the associated operator is stored in cb->loc One checks if something has to be computed. One skips the computation if the value of the associated property is equal to zero. More... | |
Enumerations | |
| enum | cs_hodge_type_t { CS_HODGE_TYPE_VPCD , CS_HODGE_TYPE_EPFD , CS_HODGE_TYPE_FPED , CS_HODGE_TYPE_EDFP , CS_HODGE_TYPE_CPVD , CS_HODGE_TYPE_VDCP , CS_HODGE_TYPE_FB , CS_HODGE_TYPE_VC , CS_HODGE_N_TYPES } |
| Type of discrete Hodge operators. More... | |
| enum | cs_hodge_algo_t { CS_HODGE_ALGO_VORONOI , CS_HODGE_ALGO_WBS , CS_HODGE_ALGO_COST , CS_HODGE_ALGO_BUBBLE , CS_HODGE_ALGO_AUTO , CS_HODGE_N_ALGOS } |
| Type of algorithm to build a discrete Hodge operator. More... | |
| static bool | cs_hodge_param_is_similar (const cs_hodge_param_t h1_info, const cs_hodge_param_t h2_info) |
| Check if two sets of parameters related to how build a discrete Hodge operator are similar. More... | |
| cs_hodge_t * | cs_hodge_create (const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen) |
| Create and initialize a pointer to a cs_hodge_t structure. More... | |
| cs_hodge_t ** | cs_hodge_init_context (const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen) |
| Create and initialize an array of pointers to a cs_hodge_t structures. This array is of size the number of OpenMP threads. Only the one associated to the current thread is set. More... | |
| void | cs_hodge_free (cs_hodge_t **p_hodge) |
| Free a cs_hodge_t structure. More... | |
| void | cs_hodge_free_context (cs_hodge_t ***p_hodges) |
| Free a set of cs_hodge_t structures. More... | |
| cs_hodge_compute_t * | cs_hodge_get_func (const char *calling_func, const cs_hodge_param_t hp) |
| Retrieve a function pointer to compute a discrete Hodge operator. More... | |
| cs_hodge_algo_t | cs_hodge_set_mass_algo (const char *eqname, cs_hodge_algo_t reac_algo, cs_hodge_algo_t time_algo) |
| Check the consistency of the settings between terms related to a mass matrix and define the common algorithm to use. If a term should not be considered, set the algorithm to CS_HODGE_N_ALGOS. More... | |
| void | cs_hodge_param_log (const char *prefix, const cs_property_t *property, const cs_hodge_param_t hp) |
| Output the settings related to a cs_hodge_param_t structure. More... | |
| void | cs_hodge_copy_parameters (const cs_hodge_param_t *h_ref, cs_hodge_param_t *h_cpy) |
| Copy the set of parameters associated to a discrete Hodge operator to another one. More... | |
| void | cs_hodge_evaluate_property (const cs_lnum_t c_id, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge) |
| Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell and if needed other related quantities. More... | |
| void | cs_hodge_evaluate_property_cw (const cs_cell_mesh_t *cm, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge) |
| Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell and if needed ohter related quantities. Cell-wise variant (usage of cs_cell_mesh_t structure) More... | |
| bool | cs_hodge_fb_cost_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More... | |
| bool | cs_hodge_fb_bubble_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. with the usage of bubble stabilization. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More... | |
| bool | cs_hodge_fb_voro_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More... | |
| bool | cs_hodge_vb_cost_get_iso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and an isotropic property. More... | |
| bool | cs_hodge_vb_cost_get_aniso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and an anistropic property. More... | |
| bool | cs_hodge_vb_bubble_get_iso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and isotropic material property. More... | |
| bool | cs_hodge_vb_bubble_get_aniso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and anisotropic material property. More... | |
| bool | cs_hodge_vb_cost_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes. More... | |
| bool | cs_hodge_vb_voro_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes. More... | |
| bool | cs_hodge_vb_wbs_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic WBS algo. WBS means for Whitney Barycentric Subdivision (WBS) algo. The computed matrix is stored in cb->loc. More... | |
| bool | cs_hodge_vcb_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic WBS algo. WBS means Whitney Barycentric Subdivision (WBS) algo. The computed matrix is stored in cb->loc. More... | |
| bool | cs_hodge_fb_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator on a given cell which is equivalent of a mass matrix. It relies on a CO+ST algo. and is specific to CDO-Fb schemes. The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vcb_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the Voronoi algo. This leads to a diagonal operator. This function is specific for vertex+cell-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vcb_wbs_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the WBS algo. This function is specific for vertex+cell-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vpcd_wbs_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using WBS algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vpcd_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_epfd_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal edges to dual faces. The discrete Hodge operator is stored in hodge->matrix This function is specific for vertex-based schemes. More... | |
| bool | cs_hodge_epfd_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal edges to dual faces. The discrete Hodge operator is stored in hodge->matrix This function is specific for vertex-based schemes. More... | |
| bool | cs_hodge_epfd_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. with a bubble stabilization. The discrete Hodge operator is stored in hodge->matrix Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes. More... | |
| bool | cs_hodge_fped_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More... | |
| bool | cs_hodge_fped_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More... | |
| bool | cs_hodge_fped_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More... | |
| bool | cs_hodge_edfp_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from dual edges to primal faces. The discrete Hodge operator is stored in hodge->matrix This function is related to face-based schemes. More... | |
| bool | cs_hodge_edfp_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from dual edges to primal faces. This function is related to face-based schemes. More... | |
| bool | cs_hodge_edfp_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from dual edges to primal faces. The discrete Hodge operator is stored in hodge->matrix This function is related to face-based schemes. More... | |
| bool | cs_hodge_edfp_cost_get_opt (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| void | cs_hodge_matvec (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t in_vals[], cs_real_t t_eval, cs_real_t result[]) |
| Compute cellwise a discrete hodge operator and multiple it with a vector. More... | |
| void | cs_hodge_circulation_from_flux (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t flux[], cs_real_t circul[]) |
| Compute cellwise a discrete hodge operator in order to define a circulation array from a flux array. More... | |
| void | cs_hodge_compute_wbs_surfacic (const cs_face_mesh_t *fm, cs_sdm_t *hf) |
| Compute the hodge operator related to a face (i.e. a mass matrix with unity property) using a Whitney Barycentric Subdivision (WBS) algorithm. More... | |
| typedef bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| [in] | cm | pointer to a cs_cell_mesh_t struct. |
| [in,out] | hodge | pointer to a cs_hodge_t structure |
| enum cs_hodge_algo_t |
| enum cs_hodge_type_t |
| void cs_hodge_circulation_from_flux | ( | const cs_cdo_connect_t * | connect, |
| cs_real_t | t_eval, | ||
| const cs_hodge_param_t | hodgep, | ||
| const cs_property_t * | pty, | ||
| const cs_real_t | flux[], | ||
| cs_real_t | circul[] | ||
| [in] | hodgep | cs_hodge_param_t structure |
| [in] | pty | pointer to a cs_property_t structure or null |
| [in] | flux | vector to multiply with the discrete Hodge op. |
| [in,out] | circul | array storing the resulting matrix-vector product |
| [in] | pty | pointer to a cs_property_t structure or nullptr |
| void cs_hodge_compute_wbs_surfacic | ( | const cs_face_mesh_t * | fm, |
| cs_sdm_t * | hf | ||
| [in] | fm | pointer to a cs_face_mesh_t structure |
| [in,out] | hf | pointer to a cs_sdm_t structure to define |
| void cs_hodge_copy_parameters | ( | const cs_hodge_param_t * | h_ref, |
| cs_hodge_param_t * | h_cpy | ||
| [in] | h_ref | reference set of parameters |
| [in,out] | h_cpy | set of parameters to update |
| cs_hodge_t * cs_hodge_create | ( | const cs_cdo_connect_t * | connect, |
| const cs_property_t * | property, | ||
| const cs_hodge_param_t * | hp, | ||
| bool | need_tensor, | ||
| bool | need_eigen | ||
| [in] | connect | pointer to cs_cdo_connect_t structure |
| [in] | property | pointer to a property structure |
| [in] | hp | pointer to a cs_hodge_param_t structure |
| [in] | need_tensor | true if one needs a tensor otherwise false |
| [in] | need_eigen | true if one needs to compute eigen valuese |
| bool cs_hodge_edfp_bubble_get | ( | const cs_cell_mesh_t * | cm, |
| cs_hodge_t * | hodge, | ||
| bool cs_hodge_edfp_cost_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_edfp_cost_get_opt | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_edfp_voro_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_epfd_bubble_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_epfd_cost_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_epfd_voro_get | ( | const cs_cell_mesh_t * | cm, |
| void cs_hodge_evaluate_property | ( | const cs_lnum_t | c_id, |
| const cs_flag_t | c_flag, | ||
| cs_hodge_t * | hodge | ||
| [in] | c_id | id of the cell to deal with |
| [in] | c_flag | flag related to this cell |
| void cs_hodge_evaluate_property_cw | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_bubble_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_cost_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_voro_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fped_bubble_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fped_cost_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fped_voro_get | ( | const cs_cell_mesh_t * | cm, |
| void cs_hodge_free | ( | cs_hodge_t ** | p_hodge | ) |
| [in,out] | p_hodge | double pointer to a cs_hodge_t structure |
| void cs_hodge_free_context | ( | cs_hodge_t *** | p_hodges | ) |
| [in,out] | p_hodges | triple pointer to cs_hodge_t structures |
| cs_hodge_compute_t * cs_hodge_get_func | ( | const char * | calling_func, |
| const cs_hodge_param_t | hp | ||
| [in] | calling_func | name of the calling function |
| [in] | hp | a cs_hodge_param_t structure |
| cs_hodge_t ** cs_hodge_init_context | ( | const cs_cdo_connect_t * | connect, |
| void cs_hodge_matvec | ( | const cs_cdo_connect_t * | connect, |
| const cs_real_t | in_vals[], | ||
| cs_real_t | result[] | ||
| [in] | in_vals | vector to multiply with the discrete Hodge op. |
| [in,out] | result | array storing the resulting matrix-vector product |
inlinestatic |
| [in] | h1_info | pointer to a first cs_hodge_param_t structure |
| [in] | h2_info | pointer to a second cs_hodge_param_t structure |
| void cs_hodge_param_log | ( | const char * | prefix, |
| [in] | prefix | optional string |
| [in] | property | optional pointer to a property structure |
| cs_hodge_algo_t cs_hodge_set_mass_algo | ( | const char * | eqname, |
| cs_hodge_algo_t | reac_algo, | ||
| cs_hodge_algo_t | time_algo | ||
| [in] | eqname | name of the equation to check |
| [in] | reac_algo | optional algo. used for the reaction term |
| [in] | time_algo | optional algo. used for the unsteady term |
| bool cs_hodge_vb_bubble_get_aniso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_bubble_get_iso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_cost_get_aniso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_cost_get_iso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_cost_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_voro_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_wbs_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vcb_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vcb_voro_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vcb_wbs_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vpcd_voro_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vpcd_wbs_get | ( | const cs_cell_mesh_t * | cm, |
