1#ifndef __CS_CDO_QUANTITIES_H__
2#define __CS_CDO_QUANTITIES_H__
289 const double xab[3] = {xb[0] - qa.
center[0],
292 const double cp[3] = {qa.
unitv[1]*xab[2] - qa.
unitv[2]*xab[1],
595 if (f_id < cdoq->n_i_faces)
616 if (f_id < cdoq->n_i_faces)
637 return (f_id < cdoq->n_i_faces) ?
cs_cdo_quantities_bit_t
Bit values for setting which quantities to compute.
Definition: cs_cdo_quantities.h:100
@ CS_CDO_QUANTITIES_HHO_SCHEME
Definition: cs_cdo_quantities.h:106
@ CS_CDO_QUANTITIES_VB_SCHEME
Definition: cs_cdo_quantities.h:107
@ CS_CDO_QUANTITIES_CB_SCHEME
Definition: cs_cdo_quantities.h:109
@ CS_CDO_QUANTITIES_FB_SCHEME
Definition: cs_cdo_quantities.h:105
@ CS_CDO_QUANTITIES_MAC_SCHEME
Definition: cs_cdo_quantities.h:110
@ CS_CDO_QUANTITIES_VCB_SCHEME
Definition: cs_cdo_quantities.h:108
@ CS_CDO_QUANTITIES_EB_SCHEME
Definition: cs_cdo_quantities.h:104
static cs_real_t cs_quant_get_face_surf(cs_lnum_t f_id, const cs_cdo_quantities_t *cdoq)
Retrieve the face surface for a primal face (interior or border)
Definition: cs_cdo_quantities.h:634
static const cs_real_t * cs_quant_get_face_center(cs_lnum_t f_id, const cs_cdo_quantities_t *cdoq)
Retrieve the face center for a primal face (interior or border)
Definition: cs_cdo_quantities.h:613
void cs_cdo_quantities_dump(const cs_cdo_quantities_t *cdoq)
Dump a cs_cdo_quantities_t structure (for debuggingpurpose)
Definition: cs_cdo_quantities.cpp:1361
void cs_cdo_quantities_log_summary(const cs_cdo_quantities_t *cdoq)
Summarize generic information about the cdo mesh quantities.
Definition: cs_cdo_quantities.cpp:1307
cs_quant_t cs_quant_get_edge_center(cs_lnum_t e_id, const cs_cdo_connect_t *topo, const cs_cdo_quantities_t *cdoq)
Retrieve the edge center for a primal edge (interior or border)
Definition: cs_cdo_quantities.cpp:2002
cs_quant_t cs_quant_set_face(cs_lnum_t f_id, const cs_cdo_quantities_t *cdoq)
Define a cs_quant_t structure for a primal face (interior or border)
Definition: cs_cdo_quantities.cpp:1914
const cs_real_t * cs_cdo_quantities_get_pvol_ec(const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2e)
Retrieve the portion of volume surrounding each edge of a cell. This volume corresponds to an octahed...
Definition: cs_cdo_quantities.cpp:1549
static const cs_real_t * cs_quant_get_face_vector_area(cs_lnum_t f_id, const cs_cdo_quantities_t *cdoq)
Retrieve the face vector which the face_area * face_normal for a primal face (interior or border)
Definition: cs_cdo_quantities.h:592
void cs_cdo_quantities_set_algo_ccenter(cs_cdo_quantities_cell_center_algo_t algo)
Set the type of algorithm to use for computing the cell center.
Definition: cs_cdo_quantities.cpp:1101
const cs_real_t * cs_cdo_quantities_get_dual_volumes(cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect)
Compute or retrieve the dual volume surrounding each vertex. The parallel operation (sum reduction) i...
Definition: cs_cdo_quantities.cpp:1647
cs_nvec3_t cs_quant_set_dedge_nvec(cs_lnum_t shift, const cs_cdo_quantities_t *cdoq)
Get the two normalized vector associated to a dual edge.
Definition: cs_cdo_quantities.cpp:2054
void cs_cdo_quantities_set(cs_flag_t option_flag)
Set which quantities have to be computed. Additionnal quantities are added to cs_cdo_quantities_flag ...
Definition: cs_cdo_quantities.cpp:1087
cs_nvec3_t cs_quant_set_edge_nvec(cs_lnum_t e_id, const cs_cdo_quantities_t *cdoq)
Get the normalized vector associated to a primal edge.
Definition: cs_cdo_quantities.cpp:2033
const cs_real_t * cs_cdo_quantities_get_pvol_fc(const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2f)
Retrieve the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid ...
Definition: cs_cdo_quantities.cpp:1454
void cs_cdo_quantities_compute_b_wvf(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t bf_id, cs_real_t wvf[])
Compute the weight related to each vertex of a face. This weight ensures a 2nd order approximation if...
Definition: cs_cdo_quantities.cpp:1867
cs_cdo_quantities_t * cs_cdo_quantities_free(cs_cdo_quantities_t *cdoq)
Destroy a cs_cdo_quantities_t structure.
Definition: cs_cdo_quantities.cpp:1265
long long cs_cdo_quantities_get_time_perfo(void)
Retrieve the time elapsed to build the cs_cdo_quantities_t structure.
Definition: cs_cdo_quantities.cpp:1072
void cs_cdo_quantities_compute_dual_volumes(const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect, cs_real_t **p_dual_vol)
Compute the dual volume surrounding each vertex. The parallel operation (sum reduction) is performed ...
Definition: cs_cdo_quantities.cpp:1676
void cs_cdo_quantities_compute_pvol_fc(const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2f, cs_real_t **p_pvol_fc)
Compute the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid w...
Definition: cs_cdo_quantities.cpp:1488
cs_nvec3_t cs_quant_set_face_nvec(cs_lnum_t f_id, const cs_cdo_quantities_t *cdoq)
Retrieve the face surface and its unit normal vector for a primal face (interior or border)
Definition: cs_cdo_quantities.cpp:1962
Type of algorithm used to compute the cell centers.
Definition: cs_cdo_quantities.h:67
@ CS_CDO_QUANTITIES_MEANV_CENTER
Definition: cs_cdo_quantities.h:69
@ CS_CDO_QUANTITIES_BARYC_CENTER
Definition: cs_cdo_quantities.h:70
@ CS_CDO_QUANTITIES_SATURNE_CENTER
Definition: cs_cdo_quantities.h:71
void cs_cdo_quantities_compute_i_tef(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t f_id, cs_real_t tef[])
Compute the area of the triangles with basis each edge of the face and apex the face center....
Definition: cs_cdo_quantities.cpp:1731
void cs_cdo_quantities_compute_pvol_ec(const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2e, cs_real_t **p_pvol_ec)
Compute the portion of volume surrounding each edge of a cell. The computed quantity is scanned with ...
Definition: cs_cdo_quantities.cpp:1582
void cs_quant_dump(FILE *f, cs_lnum_t num, const cs_quant_t q)
Dump a cs_quant_t structure.
Definition: cs_cdo_quantities.cpp:2074
cs_cdo_quantities_t * cs_cdo_quantities_build(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, const cs_cdo_connect_t *topo)
Build a cs_cdo_quantities_t structure. Some quantities are shared with the cs_mesh_quantities_t struc...
Definition: cs_cdo_quantities.cpp:1121
void cs_cdo_quantities_compute_b_tef(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t bf_id, cs_real_t tef[])
Definition: cs_cdo_quantities.cpp:1774
void cs_cdo_quantities_compute_i_wvf(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t f_id, cs_real_t wvf[])
Definition: cs_cdo_quantities.cpp:1817
static double cs_compute_area_from_quant(const cs_quant_t qa, const cs_real_t *xb)
Compute the area of the triangle of base given by q (related to a segment) with apex located at xa.
Definition: cs_cdo_quantities.h:286
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_nreal_t cs_nreal_3_t[3]
Definition: cs_defs.h:385
uint64_t cs_gnum_t
global mesh entity number
Definition: cs_defs.h:325
Definition: cs_defs.h:543
Definition: cs_defs.h:335
unsigned short int cs_flag_t
Definition: cs_defs.h:344
@ cp
Definition: cs_field_pointer.h:102
cs_flag_cartesian_axis_t
Definition: cs_flag.h:307
static CS_F_HOST_DEVICE cs_real_t cs_math_3_norm(const cs_real_t v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:765
char * algo
Definition: field_names.h:100
Definition: cs_cdo_quantities.h:139
const cs_nreal_3_t * b_face_u_normal
Definition: cs_cdo_quantities.h:188
cs_gnum_t n_g_edges
Definition: cs_cdo_quantities.h:221
const cs_real_t * b_face_surf
Definition: cs_cdo_quantities.h:191
const cs_real_t * i_face_center
Definition: cs_cdo_quantities.h:184
const cs_real_t * b_face_center
Definition: cs_cdo_quantities.h:190
cs_lnum_t n_i_faces
Definition: cs_cdo_quantities.h:164
const cs_real_t * b_dist
Definition: cs_cdo_quantities.h:192
cs_lnum_t n_faces
Definition: cs_cdo_quantities.h:163
cs_lnum_t n_b_faces
Definition: cs_cdo_quantities.h:165
cs_quant_info_t edge_info
Definition: cs_cdo_quantities.h:241
cs_real_t * dual_vol
Definition: cs_cdo_quantities.h:261
cs_gnum_t n_g_vertices
Definition: cs_cdo_quantities.h:247
const cs_real_t * i_dist
Definition: cs_cdo_quantities.h:186
cs_lnum_t n_cells
Definition: cs_cdo_quantities.h:153
cs_real_t * pvol_ec
Definition: cs_cdo_quantities.h:236
cs_quant_info_t face_info
Definition: cs_cdo_quantities.h:215
const cs_real_t * i_face_normal
Definition: cs_cdo_quantities.h:183
const cs_real_t * b_face_normal
Definition: cs_cdo_quantities.h:189
cs_gnum_t n_g_cells
Definition: cs_cdo_quantities.h:154
double vol_tot
Definition: cs_cdo_quantities.h:148
const cs_real_t * vtx_coord
Definition: cs_cdo_quantities.h:254
cs_lnum_t n_vertices
Definition: cs_cdo_quantities.h:246
cs_gnum_t n_g_faces
Definition: cs_cdo_quantities.h:166
cs_real_t * cell_centers
Definition: cs_cdo_quantities.h:155
cs_lnum_t n_edges
Definition: cs_cdo_quantities.h:220
cs_real_t * pvol_fc
Definition: cs_cdo_quantities.h:209
cs_real_t * pvol_vc
Definition: cs_cdo_quantities.h:249
const cs_real_t * cell_vol
Definition: cs_cdo_quantities.h:156
cs_quant_info_t cell_info
Definition: cs_cdo_quantities.h:158
cs_real_t * dface_normal
Definition: cs_cdo_quantities.h:234
bool remove_boundary_faces
Definition: cs_cdo_quantities.h:144
const cs_real_t * i_face_surf
Definition: cs_cdo_quantities.h:185
cs_real_t * edge_vector
Definition: cs_cdo_quantities.h:223
const cs_nreal_3_t * i_face_u_normal
Definition: cs_cdo_quantities.h:182
cs_flag_cartesian_axis_t * face_axis
Definition: cs_cdo_quantities.h:194
cs_real_t * dedge_vector
Definition: cs_cdo_quantities.h:207
Definition: cs_defs.h:400
Definition: cs_cdo_quantities.h:117
double meas_max
Definition: cs_cdo_quantities.h:123
double meas_min
Definition: cs_cdo_quantities.h:122
double h_min
double h_max
Definition: cs_cdo_quantities.h:125
Definition: cs_cdo_quantities.h:131
double meas
Definition: cs_cdo_quantities.h:133
double center[3]
Definition: cs_cdo_quantities.h:135
double unitv[3]
Definition: cs_cdo_quantities.h:134
