#include "cs_base.h"#include "cs_time_step.h"#include "cs_mesh.h"#include "cs_equation_builder.h"#include "cs_equation_param.h"#include "cs_field.h"#include "cs_cdo_connect.h"#include "cs_cdo_quantities.h"#include "cs_restart.h"#include "cs_source_term.h"
Include dependency graph for cs_cdovcb_scaleq.h:Go to the source code of this file.
| bool | cs_cdovcb_scaleq_is_initialized (void) |
| Check if the generic structures for building a CDO-vertex+cell based scheme are allocated. More... | |
| void | cs_cdovcb_scaleq_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step) |
| Allocate work buffer and general structures related to CDO vertex+cell-based schemes Set shared pointers. More... | |
| void | cs_cdovcb_scaleq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb) |
| void | cs_cdovcb_scaleq_finalize_sharing (void) |
| Free buffers and generic structures related to CDO vertex+cell-based schemes. More... | |
| void * | cs_cdovcb_scaleq_init_context (cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb) |
| Initialize a cs_cdovcb_scaleq_t structure storing data useful for building and managing such a scheme. More... | |
| void * | cs_cdovcb_scaleq_free_context (void *data) |
| Destroy a cs_cdovcb_scaleq_t structure. More... | |
| void | cs_cdovcb_scaleq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued CDO-VCb schemes. More... | |
| void | cs_cdovcb_scaleq_interpolate (const cs_mesh_t *mesh, const cs_real_t *cell_values, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a scalar steady-state equation with a CDO-VCb scheme. Use for interpolation purpose from cell values to vertex values. One works cellwise and then process to the assembly. More... | |
| void | cs_cdovcb_scaleq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction equation with a CDO-VCb scheme One works cellwise and then process to the assembly. More... | |
| void | cs_cdovcb_scaleq_solve_implicit (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equation with a CDO-VCb scheme Time scheme is an implicit Euler One works cellwise and then process to the assembly. More... | |
| void | cs_cdovcb_scaleq_solve_theta (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equation with a CDO-VCb scheme Time scheme is a theta scheme. One works cellwise and then process to the assembly. More... | |
| cs_real_t * | cs_cdovcb_scaleq_get_vertex_values (void *context, bool previous) |
| Retrieve an array of values at mesh vertices for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
| cs_real_t * | cs_cdovcb_scaleq_get_cell_values (void *context, bool previous) |
| Get the computed values at mesh cells from the inverse operation w.r.t. the static condensation (DoF used in the linear system are located at primal vertices and field related to the structure equation is also attached to primal vertices) The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
| cs_real_t * | cs_cdovcb_scaleq_get_source_term_values (void *context) |
| Retrieve the array storing the source term values associated to each DoF. The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More... | |
| void | cs_cdovcb_scaleq_boundary_diff_flux (const cs_real_t *pot_v, const cs_real_t *pot_c, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, const cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *vf_flux) |
| Compute for each vertex of a boundary face, the portion of diffusive flux across the boundary face. The surface attached to each vertex corresponds to the intersection of its dual cell (associated to a vertex of the face) with the face. Case of scalar-valued CDO-VCb schemes. More... | |
| void | cs_cdovcb_scaleq_flux_across_plane (const cs_real_t normal[], const cs_real_t *pdi, const cs_equation_param_t *eqp, int ml_id, cs_equation_builder_t *eqb, void *context, double *d_flux, double *c_flux) |
| Compute the diffusive and convective flux across a list of faces Case of scalar-valued CDO-Vcb schemes. More... | |
| void | cs_cdovcb_scaleq_diff_flux_in_cells (const cs_real_t *v_values, const cs_real_t *c_values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux) |
| Cellwise and threaed computation of the diffusive flux in each cells. Case of scalar-valued CDO-VCb schemes. More... | |
| void | cs_cdovcb_scaleq_diff_flux_dfaces (const cs_real_t *v_values, const cs_real_t *c_values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux) |
| Cellwise and threaded computation of the diffusive flux across dual faces. This is only an interpolation since the dual faces are not the natural location for this discretization. Case of scalar-valued CDO-VCb schemes. More... | |
| void | cs_cdovcb_scaleq_vtx_gradient (const cs_real_t *v_values, cs_equation_builder_t *eqb, void *context, cs_real_t *v_gradient) |
| Cellwise computation of the discrete gradient at vertices. More... | |
| void | cs_cdovcb_scaleq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context) |
| void | cs_cdovcb_scaleq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context) |
| void | cs_cdovcb_scaleq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Operate a current to previous operation for the field associated to this equation and potentially for related fields/arrays. More... | |
| void | cs_cdovcb_scaleq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| void cs_cdovcb_scaleq_boundary_diff_flux | ( | const cs_real_t * | pot_v, |
| const cs_real_t * | pot_c, | ||
| void * | context, | ||
| cs_real_t * | vf_flux | ||
| [in] | pot_v | values at the location of the degrees of freedom |
| [in] | pot_c | values at the cell centers or nullptr |
| [in] | diff_pty | diffusion property or nullptr |
| [in,out] | vf_flux | pointer to the values of the diffusive flux |
| void cs_cdovcb_scaleq_current_to_previous | ( | const cs_equation_param_t * | eqp, |
| void * | context | ||
| [in,out] | context | pointer to cs_cdovcb_scaleq_t structure |
| void cs_cdovcb_scaleq_diff_flux_dfaces | ( | const cs_real_t * | v_values, |
| const cs_real_t * | c_values, | ||
| cs_real_t * | diff_flux | ||
| [in] | v_values | values at vertices |
| [in] | c_values | values at cells |
| [in] | diff_pty | pointer to the diffusion property to use |
| [in,out] | context | pointer to data structure cast on-the-fly |
| [in,out] | diff_flux | value of the diffusive flux |
| void cs_cdovcb_scaleq_diff_flux_in_cells | ( | const cs_real_t * | v_values, |
| void cs_cdovcb_scaleq_extra_post | ( | const cs_equation_param_t * | eqp, |
| void cs_cdovcb_scaleq_finalize_sharing | ( | void | ) |
| void cs_cdovcb_scaleq_flux_across_plane | ( | const cs_real_t | normal[], |
| const cs_real_t * | pdi, | ||
| int | ml_id, | ||
| double * | d_flux, | ||
| double * | c_flux | ||
| [in] | normal | indicate in which direction flux is > 0 |
| [in] | pdi | pointer to an array of field values |
| [in] | ml_id | id related to a cs_mesh_location_t struct. |
| [in,out] | context | pointer to data specific for this scheme |
| [in,out] | d_flux | pointer to the value of the diffusive flux |
| [in,out] | c_flux | pointer to the value of the convective flux |
| void * cs_cdovcb_scaleq_free_context | ( | void * | data | ) |
| [in,out] | data | pointer to a cs_cdovcb_scaleq_t structure |
| void cs_cdovcb_scaleq_get | ( | cs_cell_sys_t ** | csys, |
| cs_real_t * cs_cdovcb_scaleq_get_cell_values | ( | void * | context, |
| bool | previous | ||
| cs_real_t * cs_cdovcb_scaleq_get_source_term_values | ( | void * | context | ) |
| cs_real_t * cs_cdovcb_scaleq_get_vertex_values | ( | void * | context, |
| void * cs_cdovcb_scaleq_init_context | ( | cs_equation_param_t * | eqp, |
| int | var_id, | ||
| int | bflux_id, | ||
| void cs_cdovcb_scaleq_init_sharing | ( | const cs_cdo_quantities_t * | cdoq, |
| [in] | cdoq | additional CDO mesh quantities |
| void cs_cdovcb_scaleq_init_values | ( | cs_real_t | t_eval, |
| const int | field_id, | ||
| void cs_cdovcb_scaleq_interpolate | ( | const cs_mesh_t * | mesh, |
| const cs_real_t * | cell_values, | ||
| [in] | cell_values | array of cell values |
| [in] | field_id | id of the variable field |
| bool cs_cdovcb_scaleq_is_initialized | ( | void | ) |
| void cs_cdovcb_scaleq_read_restart | ( | cs_restart_t * | restart, |
| const char * | eqname, | ||
| void cs_cdovcb_scaleq_solve_implicit | ( | bool | cur2prev, |
| void cs_cdovcb_scaleq_solve_steady_state | ( | bool | cur2prev, |
| void cs_cdovcb_scaleq_solve_theta | ( | bool | cur2prev, |
| void cs_cdovcb_scaleq_vtx_gradient | ( | const cs_real_t * | v_values, |
| cs_real_t * | v_gradient | ||
| [in] | v_values | discrete values for the potential at vertices |
| [in,out] | v_gradient | gradient at vertices |
| void cs_cdovcb_scaleq_write_restart | ( | cs_restart_t * | restart, |
