#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <ctype.h>#include <stdio.h>#include <stdarg.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <float.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_air_props.h"#include "cs_base.h"#include "cs_boundary_conditions.h"#include "cs_domain.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_pointer.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_location.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_physical_constants.h"#include "cs_prototypes.h"#include "cs_thermal_model.h"#include "cs_atmo.h"#include "cs_atmo_aerosol.h"#include "cs_atmo_aerosol_ssh.h"
Include dependency graph for cs_atmo_aerosol.cpp:Functions | |
| void | cs_atmo_aerosol_initialize (void) |
| This function initializes the external aerosol code. More... | |
| void | cs_atmo_aerosol_finalize (void) |
| This function finalizes the external aerosol code. More... | |
| void | cs_atmo_aerosol_get_aero (cs_real_t *array) |
| This function fills the given array with aerosol concentrations and numbers from the external aerosol code. More... | |
| void | cs_atmo_aerosol_get_gas (cs_real_t *array) |
| This function fills the given array with gas concentrations from the external aerosol code. More... | |
| void | cs_atmo_aerosol_time_advance (void) |
| This function computes a time step of gaseous chemistry and aerosols dynamic using the external aerosol code. More... | |
| void | cs_atmo_aerosol_nuclea (cs_real_t *nc, const cs_real_t *rom, const cs_real_t *qldia, const cs_real_t *pphy, const cs_real_t *refrad) |
| Compute aerosol cloud droplets nucleation when using the atmospheric humid model using a microphysical model. More... | |
| void cs_atmo_aerosol_finalize | ( | void | ) |
| void cs_atmo_aerosol_get_aero | ( | cs_real_t * | array | ) |
This function fills the given array with aerosol concentrations and numbers from the external aerosol code..
| [out] | array | aerosol concentrations and numbers |
| void cs_atmo_aerosol_get_gas | ( | cs_real_t * | array | ) |
| [out] | array | gas concentrations |
| void cs_atmo_aerosol_initialize | ( | void | ) |
| void cs_atmo_aerosol_nuclea | ( | cs_real_t * | nc, |
| const cs_real_t * | rom, | ||
| const cs_real_t * | qldia, | ||
| const cs_real_t * | pphy, | ||
| const cs_real_t * | refrad | ||
It is taken into account as an additional step split from advection-diffusion equation, hence the droplet number is first clipped if necessary.
| [out] | nc | droplet number (scalar) in 1/cm**3 |
| [in] | rom | density of air in kg/m**3 |
| [in] | qldia | mass fraction of liquid water in kg/kg |
| [in] | pphy | true pressure in pascals |
| [in] | refrad | radiative cooling |
| void cs_atmo_aerosol_time_advance | ( | void | ) |
