const cs_lnum_t n_b_faces = domain->mesh->n_b_faces;
const cs_lnum_t *b_face_cells = domain->mesh->b_face_cells;
const cs_real_3_t *)domain->mesh_quantities->b_face_normal;
for (
cs_lnum_t ilelt = 0; ilelt < zn->n_elts; ilelt++) {
const cs_lnum_t face_id = zn->elt_ids[ilelt];
const cs_lnum_t c_id = b_face_cells[face_id];
CS_F_(
vel)->bc_coeffs->rcodcl1[face_id] = 5.0;
CS_F_(
vel)->bc_coeffs->rcodcl1[n_b_faces*1 + face_id] = 0;
CS_F_(
vel)->bc_coeffs->rcodcl1[n_b_faces*2 + face_id] = 0;
CS_F_(
p)->bc_coeffs->rcodcl1[face_id] = 5.5;
CS_F_(
e_tot)->bc_coeffs->rcodcl1[face_id] = 355.e3;
for(
int ii = 0; ii <
CS_F_(
vel)->dim; ii++)
uref2,
dhy,
rhomoy,
continue;
int sc_id = -1;
if (sc_id < 0)
continue;
for (
for (
CS_F_(
p)->bc_coeffs->rcodcl1[face_id] = 1e5;
CS_F_(
e_tot)->bc_coeffs->rcodcl1[face_id] = 294465.0;
for(
int ii = 0; ii <
CS_F_(
vel)->dim; ii++)
CS_F_(
vel)->bc_coeffs->rcodcl1[n_b_faces*ii +face_id]
= -b_face_normal[face_id][ii];
continue;
int sc_id = -1;
if (sc_id < 0)
continue;
for (
CS_F_(
p)->bc_coeffs->rcodcl1[face_id] = 5.e5;
for (
CS_F_(
vel)->bc_coeffs->rcodcl1[face_id] = 1.0;
Definition: cs_boundary_zone.cpp:711
#define restrict
Definition: cs_defs.h:145
Definition: cs_defs.h:342
#define CS_REAL_TYPE
Definition: cs_defs.h:486
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_defs.h:335
Definition: cs_field.cpp:3275
int cs_field_n_fields(void)
Definition: cs_field.cpp:1593
Definition: cs_field.cpp:2465
Definition: cs_field.cpp:2781
@ p
Definition: cs_field_pointer.h:67
@ t_kelvin
Definition: cs_field_pointer.h:117
@ vel
@ e_tot
Definition: cs_field_pointer.h:96
@ rho
Definition: cs_field_pointer.h:99
#define CS_F_(e)
static CS_F_HOST_DEVICE cs_real_t cs_math_pow2(cs_real_t x)
Definition: cs_math.h:561
static CS_F_HOST_DEVICE cs_real_t cs_math_fmax(cs_real_t x, cs_real_t y)
Definition: cs_math.h:503
static void cs_parall_sum(int n, cs_datatype_t datatype, void *val)
Sum values of a given datatype on all default communicator processes.
Definition: cs_parall.h:147
@ CS_EPHCF
Definition: cs_parameters.h:96
@ CS_ESICF
Definition: cs_parameters.h:92
@ CS_SOPCF
Definition: cs_parameters.h:95
@ CS_SSPCF
Definition: cs_parameters.h:94
@ CS_SMOOTHWALL
Definition: cs_parameters.h:89
Definition: cs_physical_constants.cpp:465
Definition: cs_turbulence_bc.cpp:772
real(c_double), pointer, save viscl0
reference molecular dynamic viscosity.
Definition: cstphy.f90:160
#define CS_FIELD_VARIABLE
Definition: cs_field.h:63
cs_real_t * rcodcl1
Definition: cs_field.h:109
Definition: cs_field.h:131
int type
Definition: cs_field.h:136
Definition: cs_field.h:163
double viscl0
Definition: cs_physical_constants.h:75
Example of input / output for which everything is known.
Without presuming subsonic or supersonic character, the user wishes to impose all the flow characteristics. A supersonic inlet is a special case.
If the speed is outgoing, an homogenous Neumann is imposed on turbulence and user scalars.
All features are output. Internal values are used to calculate the flow edge, they should not be imposed.
For turbulence and scalar, if RCODCL values are provided, they will be used in Dirichlet if the mass flow is incoming, otherwise a null flow is imposed (flow outgoing mass or RCODCL informed here). Note that for turbulence RCODCL must be defined for all turbulent variables. Otherwise a null flow is applied).
All characteristics exit. Nothing should be prescribed (the internal values are used to the computation of boundary fluxes).
Subsonic input example with density and velocity.
Two of three characteristics are incoming: two informations must be provided, third is deduced by a scenario of 2-contact and 3-relaxation in the field. Here we choose to give (rho, U).
2 characteristcs out ot 3 enter: both informations should be provided the third is deducted by a scenario of 2-contact and 3-relaxation in the domain. Here, whe choose to give (rho, U).
1 characteristic out of 3 exits: 1 information must be given the 2 others are deduced by a 2-contact and 3-relaxation in the domain. Here we choose to definer P.
Turbulence and user scalars take a zero flux.
