#include "cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "fvm_defs.h"#include "fvm_io_num.h"#include "fvm_triangulate.h"#include "cs_parall.h"#include "fvm_tesselation.h"
Include dependency graph for fvm_tesselation.c:Functions | |
| fvm_tesselation_t * | fvm_tesselation_create (fvm_element_t element_type, cs_lnum_t n_elements, const cs_lnum_t face_index[], const cs_lnum_t face_num[], const cs_lnum_t vertex_index[], const cs_lnum_t vertex_num[], const fvm_io_num_t *global_element_num) |
| fvm_tesselation_t * | fvm_tesselation_destroy (fvm_tesselation_t *this_tesselation) |
| void | fvm_tesselation_init (fvm_tesselation_t *this_tesselation, int dim, const cs_coord_t vertex_coords[], const cs_lnum_t parent_vertex_id[], cs_lnum_t *error_count) |
| void | fvm_tesselation_reduce (fvm_tesselation_t *this_tesselation) |
| cs_lnum_t | fvm_tesselation_n_elements (const fvm_tesselation_t *this_tesselation) |
| cs_gnum_t | fvm_tesselation_n_g_vertices_add (const fvm_tesselation_t *this_tesselation) |
| cs_lnum_t | fvm_tesselation_n_vertices_add (const fvm_tesselation_t *this_tesselation) |
| int | fvm_tesselation_n_sub_types (const fvm_tesselation_t *this_tesselation) |
| fvm_element_t | fvm_tesselation_sub_type (const fvm_tesselation_t *this_tesselation, int sub_type_id) |
| cs_lnum_t | fvm_tesselation_n_sub_elements (const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type) |
| void | fvm_tesselation_get_global_size (const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type, cs_gnum_t *n_sub_elements_glob, cs_lnum_t *n_sub_elements_max) |
| const fvm_io_num_t * | fvm_tesselation_global_vertex_num (const fvm_tesselation_t *this_tesselation) |
| void | fvm_tesselation_vertex_coords (const fvm_tesselation_t *this_tesselation, cs_coord_t vertex_coords[]) |
| const cs_lnum_t * | fvm_tesselation_sub_elt_index (const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type) |
| cs_lnum_t | fvm_tesselation_decode (const fvm_tesselation_t *this_tesselation, fvm_element_t connect_type, cs_lnum_t start_id, cs_lnum_t buffer_limit, cs_lnum_t extra_vertex_base, cs_lnum_t vertex_num[]) |
| void | fvm_tesselation_distribute (const fvm_tesselation_t *this_tesselation, fvm_element_t connect_type, cs_lnum_t start_id, cs_lnum_t end_id, size_t size, void *data) |
| void | fvm_tesselation_vertex_values (const fvm_tesselation_t *this_tesselation, int src_dim, int src_dim_shift, int dest_dim, cs_lnum_t start_id, cs_lnum_t end_id, cs_interlace_t src_interlace, cs_datatype_t src_datatype, cs_datatype_t dest_datatype, int n_parent_lists, const cs_lnum_t parent_num_shift[], const cs_lnum_t parent_num[], const void *const src_data[], void *const dest_data) |
| void | fvm_tesselation_dump (const fvm_tesselation_t *this_tesselation) |
| fvm_tesselation_t* fvm_tesselation_create | ( | fvm_element_t | element_type, |
| cs_lnum_t | n_elements, | ||
| const cs_lnum_t | face_index[], | ||
| const cs_lnum_t | face_num[], | ||
| const cs_lnum_t | vertex_index[], | ||
| const cs_lnum_t | vertex_num[], | ||
| const fvm_io_num_t * | global_element_num | ||
| cs_lnum_t fvm_tesselation_decode | ( | const fvm_tesselation_t * | this_tesselation, |
| fvm_element_t | connect_type, | ||
| cs_lnum_t | start_id, | ||
| cs_lnum_t | buffer_limit, | ||
| cs_lnum_t | extra_vertex_base, | ||
| cs_lnum_t | vertex_num[] | ||
| fvm_tesselation_t* fvm_tesselation_destroy | ( | fvm_tesselation_t * | this_tesselation | ) |
| void fvm_tesselation_distribute | ( | const fvm_tesselation_t * | this_tesselation, |
| cs_lnum_t | end_id, | ||
| size_t | size, | ||
| void * | data | ||
| void fvm_tesselation_dump | ( | const fvm_tesselation_t * | this_tesselation | ) |
| void fvm_tesselation_get_global_size | ( | const fvm_tesselation_t * | this_tesselation, |
| fvm_element_t | sub_type, | ||
| cs_gnum_t * | n_sub_elements_glob, | ||
| cs_lnum_t * | n_sub_elements_max | ||
| const fvm_io_num_t* fvm_tesselation_global_vertex_num | ( | const fvm_tesselation_t * | this_tesselation | ) |
| void fvm_tesselation_init | ( | fvm_tesselation_t * | this_tesselation, |
| int | dim, | ||
| const cs_coord_t | vertex_coords[], | ||
| const cs_lnum_t | parent_vertex_id[], | ||
| cs_lnum_t * | error_count | ||
| cs_lnum_t fvm_tesselation_n_elements | ( | const fvm_tesselation_t * | this_tesselation | ) |
| cs_gnum_t fvm_tesselation_n_g_vertices_add | ( | const fvm_tesselation_t * | this_tesselation | ) |
| cs_lnum_t fvm_tesselation_n_sub_elements | ( | const fvm_tesselation_t * | this_tesselation, |
| fvm_element_t | sub_type | ||
| int fvm_tesselation_n_sub_types | ( | const fvm_tesselation_t * | this_tesselation | ) |
| cs_lnum_t fvm_tesselation_n_vertices_add | ( | const fvm_tesselation_t * | this_tesselation | ) |
| void fvm_tesselation_reduce | ( | fvm_tesselation_t * | this_tesselation | ) |
| const cs_lnum_t* fvm_tesselation_sub_elt_index | ( | const fvm_tesselation_t * | this_tesselation, |
| fvm_element_t fvm_tesselation_sub_type | ( | const fvm_tesselation_t * | this_tesselation, |
| int | sub_type_id | ||
| void fvm_tesselation_vertex_coords | ( | const fvm_tesselation_t * | this_tesselation, |
| cs_coord_t | vertex_coords[] | ||
| void fvm_tesselation_vertex_values | ( | const fvm_tesselation_t * | this_tesselation, |
| int | src_dim, | ||
| int | src_dim_shift, | ||
| int | dest_dim, | ||
| cs_interlace_t | src_interlace, | ||
| cs_datatype_t | src_datatype, | ||
| cs_datatype_t | dest_datatype, | ||
| int | n_parent_lists, | ||
| const cs_lnum_t | parent_num_shift[], | ||
| const cs_lnum_t | parent_num[], | ||
| const void *const | src_data[], | ||
| void *const | dest_data | ||
