Include dependency graph for cs_turbulence_kw.h:Go to the source code of this file.
| void | cs_turbulence_kw (int phase_id, cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[]) |
| Solve the k-omega equations. More... | |
| void | cs_turbulence_kw_mu_t (int phase_id) |
| Calculation of turbulent viscosity for the | |
| void cs_turbulence_kw | ( | int | phase_id, |
| cs_lnum_t | ncesmp, | ||
| cs_lnum_t | icetsm[], | ||
| int | itypsm[], | ||
| const cs_real_t | dt[], | ||
| cs_real_t | smacel[] | ||
Solve the
SST for incompressible flows or slightly compressible flows for one time step.
| [in] | phase_id | turbulent phase id (-1 for single phase flow) |
| [in] | itypsm | mass source type for the variables size: [nvar][ncesmp] |
| [in] | smacel | values of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp] |
| void cs_turbulence_kw_mu_t | ( | int | phase_id | ) |
SST model.
with
and
where
is the distance to the wall.
is calculated at the same time than
for use in cs_turbulence_kw.
with
and
where
