8.2
cs_turbulence_kw.h
1 #ifndef __CS_TURBULENCE_KW_H__
2 #define __CS_TURBULENCE_KW_H__
5  * k-w turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
63
64 void
65 cs_turbulence_kw(int phase_id,
66  cs_lnum_t ncesmp,
67  cs_lnum_t icetsm[],
68  int itypsm[],
69  const cs_real_t dt[],
70  cs_real_t smacel[]);
71
91 /*----------------------------------------------------------------------------*/
92
93 void
94 cs_turbulence_kw_mu_t(int phase_id);
95
96 /*----------------------------------------------------------------------------*/
97
99
100 #endif /* __CS_TURBULENCE_KW_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
@ dt
void cs_turbulence_kw_mu_t(int phase_id)
Calculation of turbulent viscosity for the SST model.
Definition: cs_turbulence_kw.c:1735
void cs_turbulence_kw(int phase_id, cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[])
Solve the k-omega equations.
Definition: cs_turbulence_kw.c:139
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:188
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:182
