Include dependency graph for cs_sles_hypre.h:Go to the source code of this file.
| typedef void() | cs_sles_hypre_setup_hook_t(int verbosity, void *context, void *solver) |
| Function pointer for settings of a HYPRE solver setup. More... | |
| typedef struct _cs_sles_hypre_t | cs_sles_hypre_t |
| cs_sles_hypre_t * | cs_sles_hypre_define (int f_id, const char *name, cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context) |
| Define and associate a HYPRE linear system solver for a given field or equation name. More... | |
| cs_sles_hypre_t * | cs_sles_hypre_create (cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context) |
| Create HYPRE linear system solver info and context. More... | |
| void | cs_sles_hypre_destroy (void **context) |
| Destroy iterative sparse linear system solver info and context. More... | |
| void * | cs_sles_hypre_copy (const void *context) |
| Create HYPRE sparse linear system solver info and context based on existing info and context. More... | |
| void | cs_sles_hypre_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup iterative sparse linear equation solver. More... | |
| cs_sles_convergence_state_t | cs_sles_hypre_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Call HYPRE linear equation solver. More... | |
| void | cs_sles_hypre_free (void *context) |
| Free HYPRE linear equation solver setup context. More... | |
| bool | cs_sles_hypre_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
| Error handler for HYPRE solver. More... | |
| void | cs_sles_hypre_log (const void *context, cs_log_t log_type) |
| void | cs_sles_hypre_set_n_max_iter (cs_sles_hypre_t *context, int n_max_iter) |
| Set the max. number of iterations associated to the given HYPRE contrext. More... | |
| void | cs_sles_hypre_set_host_device (cs_sles_hypre_t *context, int use_device) |
| Define whether the solver should run on the host or accelerated device. More... | |
| int | cs_sles_hypre_get_host_device (const cs_sles_hypre_t *context) |
| Query whether the solver should run on the host or accelerated device. More... | |
| void | cs_sles_hypre_library_info (cs_log_t log_type) |
| Print information on hypre library. More... | |
| cs_sles_hypre_setup_hook_t |
This function is called during the setup stage for a HYPRE solver.
When first called, the solver argument is NULL, and must be created using HYPRE functions.
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | solver | handle to HYPRE solver (to be cast as HYPRE_Solver) |
| typedef struct _cs_sles_hypre_t cs_sles_hypre_t |
| enum cs_sles_hypre_type_t |
| void* cs_sles_hypre_copy | ( | const void * | context | ) |
| [in] | context | pointer to reference info and context (actual type: cs_sles_hypre_t *) |
| cs_sles_hypre_t* cs_sles_hypre_create | ( | cs_sles_hypre_type_t | solver_type, |
| cs_sles_hypre_type_t | precond_type, | ||
| cs_sles_hypre_setup_hook_t * | setup_hook, | ||
| void * | context | ||
| [in] | solver_type | HYPRE solver type |
| [in] | precond_type | HYPRE preconditioner type |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
| cs_sles_hypre_t* cs_sles_hypre_define | ( | int | f_id, |
| const char * | name, | ||
| cs_sles_hypre_type_t | solver_type, | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
The associated solver required that the matrix passed to it is a HYPRE matrix (see cs_matrix_set_type_hypre).
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
| void cs_sles_hypre_destroy | ( | void ** | context | ) |
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_hypre_t **) |
| bool cs_sles_hypre_error_post_and_abort | ( | cs_sles_t * | sles, |
| cs_real_t * | vx | ||
In case of divergence or breakdown, this error handler outputs an error message It does nothing in case the maximum iteration count is reached.
| [in] | a | matrix |
| void cs_sles_hypre_free | ( | void * | context | ) |
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_hypre_t *) |
| int cs_sles_hypre_get_host_device | ( | const cs_sles_hypre_t * | context | ) |
| [in,out] | context | pointer to HYPRE linear solver info |
| void cs_sles_hypre_library_info | ( | cs_log_t | log_type | ) |
| void cs_sles_hypre_log | ( | const void * | context, |
| cs_log_t | log_type | ||
| [in] | context | pointer to iterative solver info and context (actual type: cs_sles_hypre_t *) |
| void cs_sles_hypre_set_host_device | ( | cs_sles_hypre_t * | context, |
| int | use_device | ||
If no device is available, this setting is ignored.
| [in] | use_device | 0 for host, 1 for device (GPU) |
| void cs_sles_hypre_set_n_max_iter | ( | cs_sles_hypre_t * | context, |
| int | n_max_iter | ||
| [in] | n_max_iter | max. number of iterations |
| void cs_sles_hypre_setup | ( | void * | context, |
| int | verbosity | ||
| cs_sles_convergence_state_t cs_sles_hypre_solve | ( | void * | context, |
| int | verbosity, | ||
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residual, | ||
| cs_real_t * | vx_ini, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors | ||
| [in] | a | matrix |
