8.2
cs_paramedmem_coupling.h File Reference
#include "cs_zone.h"
+ Include dependency graph for cs_paramedmem_coupling.h:
Enumerations
enum  cs_medcpl_space_discr_t { CS_MEDCPL_ON_CELLS , CS_MEDCPL_ON_NODES }
enum  cs_medcpl_time_discr_t { CS_MEDCPL_NO_TIME , CS_MEDCPL_ONE_TIME , CS_MEDCPL_LINEAR_TIME }
enum  cs_medcpl_field_nature_t {
  CS_MEDCPL_FIELD_INT_CONSERVATION , CS_MEDCPL_FIELD_INT_MAXIMUM , CS_MEDCPL_FIELD_EXT_CONSERVATION , CS_MEDCPL_FIELD_EXT_MAXIMUM ,
  CS_MEDCPL_FIELD_N_NATURE
cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_id (int cpl_id)
 Retrieve coupling struct pointer by id. More...
cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_name (const char *name)
 Retrieve coupling struct pointer by name. More...
cs_paramedmem_coupling_t * cs_paramedmem_coupling_create (const char *app1_name, const char *app2_name, const char *cpl_name)
 Create a new ParaMEDMEM coupling. More...
cs_paramedmem_coupling_t * cs_paramedmem_coupling_create_uncoupled (const char *cpl_name)
 Create a new ParaMEDMEM handler structure with no actual coupling. More...
void cs_paramedmem_coupling_destroy (cs_paramedmem_coupling_t *c)
 Destroy a given ParaMEDMEM coupling structure. More...
void cs_paramedmem_coupling_all_finalize (void)
 Destroy all coupling structures. More...
void cs_paramedmem_add_mesh_from_criteria (cs_paramedmem_coupling_t *c, const char *sel_crit, int elt_dim)
 Define coupled mesh based on a selection criteria. More...
void cs_paramedmem_add_mesh_from_zone (cs_paramedmem_coupling_t *c, const cs_zone_t *zone)
 Define coupled mesh based on a cs_zone_t pointer. More...
void cs_paramedmem_add_mesh_from_ids (cs_paramedmem_coupling_t *c, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim)
int cs_paramedmem_get_number_of_couplings (void)
 Get number of defined couplings. More...
cs_lnum_t cs_paramedmem_mesh_get_n_elts (const cs_paramedmem_coupling_t *coupling)
 Get number of elements of coupled mesh. More...
const cs_lnum_tcs_paramedmem_mesh_get_elt_list (const cs_paramedmem_coupling_t *coupling)
 Get indirection list for elements in coupled mesh. More...
cs_lnum_t cs_paramedmem_mesh_get_n_vertices (const cs_paramedmem_coupling_t *coupling)
 Get number of vertices of coupled mesh. More...
const cs_lnum_tcs_paramedmem_mesh_get_vertex_list (const cs_paramedmem_coupling_t *coupling)
 Get indirection list for vertices in coupled mesh. More...
int cs_paramedmem_def_coupled_field (cs_paramedmem_coupling_t *c, const char *name, int dim, cs_medcpl_field_nature_t field_nature, cs_medcpl_space_discr_t space_discr, cs_medcpl_time_discr_t time_discr)
 Define a coupled field. More...
int cs_paramedmem_def_coupled_field_from_cs_field (cs_paramedmem_coupling_t *c, cs_field_t *f, cs_medcpl_field_nature_t fn, cs_medcpl_time_discr_t td)
 Define a coupled field based on a cs_field_t pointer. More...
void cs_paramedmem_field_export (cs_paramedmem_coupling_t *c, const char *name, const double values[])
 Assign values based on parent mesh location to associated ParaFIELD objects. More...
void cs_paramedmem_field_export_l (cs_paramedmem_coupling_t *c, const char *name, const double values[])
 Assign values based on mesh location corresponding to coupled elements (and associated ParaMESH) to associated ParaFIELD objects. More...
void cs_paramedmem_field_import (cs_paramedmem_coupling_t *c, const char *name, double values[])
 Copy values from associated ParaFIELD object to array defined parent mesh location. More...
void cs_paramedmem_field_import_l (cs_paramedmem_coupling_t *c, const char *name, double values[])
 Copy values from associated ParaFIELD structure to array defined on mesh location corresponding to coupled elements (and associated ParaMESH). More...
void cs_paramedmem_sync_dec (cs_paramedmem_coupling_t *c)
 Sync the coupling's InterpKernelDEC. More...
void cs_paramedmem_send_data (cs_paramedmem_coupling_t *c)
 Send values of field attached to DEC. More...
void cs_paramedmem_recv_data (cs_paramedmem_coupling_t *c)
 Recieve values of field attached to DEC. More...
void cs_paramedmem_attach_field_by_id (cs_paramedmem_coupling_t *c, int field_id)
 Attach a field to InterpKernelDEC for send operation using its index. More...
void cs_paramedmem_attach_field_by_name (cs_paramedmem_coupling_t *c, const char *name)
 Attach a field to InterpKernelDEC for send operation using its name. More...
void cs_paramedmem_send_field_vals (cs_paramedmem_coupling_t *c, const char *name, const double *vals)
 Send values of a field. If vals pointer is non-null, values are updated before send. More...
void cs_paramedmem_recv_field_vals (cs_paramedmem_coupling_t *c, const char *name, double *vals)
 Recieve values of a field. More...
void cs_paramedmem_coupling_all_init (void)
 initialize couplings based on user functions More...
void cs_paramedmem_coupling_define_mesh_fields (void)
 initialize coupled mesh and fields based on user functions More...
void cs_paramedmem_coupling_log_setup (void)
 Log ParaMEDMEM coupling setup information. More...
◆ cs_medcpl_field_nature_t
Enumerator
◆ cs_medcpl_space_discr_t
Enumerator
CS_MEDCPL_ON_CELLS
CS_MEDCPL_ON_NODES
◆ cs_medcpl_time_discr_t
Enumerator
CS_MEDCPL_NO_TIME
CS_MEDCPL_ONE_TIME
◆ cs_paramedmem_add_mesh_from_criteria()
void cs_paramedmem_add_mesh_from_criteria ( cs_paramedmem_coupling_t *  c,
const char *  sel_crit,
int  elt_dim
[in]cpointer to cs_paramedmem_coupling_t struct
[in]sel_critgeometrical selection criteria (string)
[in]elt_dimdimension of coupled elements
◆ cs_paramedmem_add_mesh_from_ids()
void cs_paramedmem_add_mesh_from_ids ( cs_paramedmem_coupling_t *  c,
cs_lnum_t  n_elts,
int  elt_dim
[in]n_eltslocal number of elements
[in]elt_idslist of local elements
[in]elt_dimdimension of elements (2: faces, 3: cells)
◆ cs_paramedmem_add_mesh_from_zone()
void cs_paramedmem_add_mesh_from_zone ( cs_paramedmem_coupling_t *  c,
const cs_zone_t zone
[in]zonepointer to cs_zone_t struct
◆ cs_paramedmem_attach_field_by_id()
void cs_paramedmem_attach_field_by_id ( cs_paramedmem_coupling_t *  c,
int  field_id
[in]cpointer to cs_paramedmem_coupling_t structure
[in]field_idindex of field in storing vector
◆ cs_paramedmem_attach_field_by_name()
void cs_paramedmem_attach_field_by_name ( cs_paramedmem_coupling_t *  c,
const char *  name
[in]namename of field (string)
◆ cs_paramedmem_coupling_all_finalize()
void cs_paramedmem_coupling_all_finalize ( void  )
◆ cs_paramedmem_coupling_all_init()
void cs_paramedmem_coupling_all_init ( void  )
◆ cs_paramedmem_coupling_by_id()
cs_paramedmem_coupling_t* cs_paramedmem_coupling_by_id ( int  cpl_id)
[in]cpl_idindex of the sought coupling
pointer to cs_paramedmem_coupling_t struct. Raise an error if the coupling does not exist.
◆ cs_paramedmem_coupling_by_name()
cs_paramedmem_coupling_t* cs_paramedmem_coupling_by_name ( const char *  name)
[in]namename of the coupling
pointer to cs_paramedmem_coupling_t struct or NULL if not found.
◆ cs_paramedmem_coupling_create()
cs_paramedmem_coupling_t* cs_paramedmem_coupling_create ( const char *  app1_name,
const char *  app2_name,
const char *  cpl_name
[in]app1_nameName of app n°1 or NULL if calling app is app1
[in]app2_nameName of app n°2 or NULL if calling app is app2
[in]cpl_nameName of the coupling. If NULL an automatic name is generated.
pointer to newly created cs_paramedmem_coupling_t structure.
◆ cs_paramedmem_coupling_create_uncoupled()
cs_paramedmem_coupling_t* cs_paramedmem_coupling_create_uncoupled ( const char *  cpl_name)
This can be useful for a "dry run" when setting up a coupling, so as to first debug local commands before actually running in coupled mode.
In this case, data "received" matches the initialized values.
◆ cs_paramedmem_coupling_define_mesh_fields()
void cs_paramedmem_coupling_define_mesh_fields ( void  )
◆ cs_paramedmem_coupling_destroy()
void cs_paramedmem_coupling_destroy ( cs_paramedmem_coupling_t *  c)
◆ cs_paramedmem_coupling_log_setup()
void cs_paramedmem_coupling_log_setup ( void  )
◆ cs_paramedmem_def_coupled_field()
int cs_paramedmem_def_coupled_field ( cs_paramedmem_coupling_t *  c,
const char *  name,
int  dim,
[in]dimfield dimension
[in]field_naturefield nature flag
[in]space_discrfield space discretisation (nodes or cells)
[in]time_discrfield coupling time discretisation
index of field within the storing vector
◆ cs_paramedmem_def_coupled_field_from_cs_field()
int cs_paramedmem_def_coupled_field_from_cs_field ( cs_paramedmem_coupling_t *  c,
cs_field_t f,
[in]fpointer to cs_field_t struct
[in]fnfield nature flag
◆ cs_paramedmem_field_export()
void cs_paramedmem_field_export ( cs_paramedmem_coupling_t *  c,
const char *  name,
[in]valuesarray of values to write (defined on parent mesh location)
◆ cs_paramedmem_field_export_l()
void cs_paramedmem_field_export_l ( cs_paramedmem_coupling_t *  c,
const char *  name,
If the whole mesh is coupled, the behavior is the sames as that of cs_paramedmem_field_export.
[in]valuesarray of values to write (defined on selected mesh subset)
◆ cs_paramedmem_field_import()
void cs_paramedmem_field_import ( cs_paramedmem_coupling_t *  c,
const char *  name,
double  values[]
[in]valuesarray in which values will be stored
◆ cs_paramedmem_field_import_l()
void cs_paramedmem_field_import_l ( cs_paramedmem_coupling_t *  c,
const char *  name,
double  values[]
If the whole mesh is coupled, the behavior is the sames as that of cs_paramedmem_field_import.
◆ cs_paramedmem_get_number_of_couplings()
int cs_paramedmem_get_number_of_couplings ( void  )
number of defined couplings (int)
◆ cs_paramedmem_mesh_get_elt_list()
const cs_lnum_t* cs_paramedmem_mesh_get_elt_list ( const cs_paramedmem_coupling_t *  coupling)
[in]couplingpointer to cs_paramedmem_coupling_t struct
cs_lnum_t pointer to indirection list
◆ cs_paramedmem_mesh_get_n_elts()
cs_lnum_t cs_paramedmem_mesh_get_n_elts ( const cs_paramedmem_coupling_t *  coupling)
number of elements in mesh associated to coupling
◆ cs_paramedmem_mesh_get_n_vertices()
cs_lnum_t cs_paramedmem_mesh_get_n_vertices ( const cs_paramedmem_coupling_t *  coupling)
◆ cs_paramedmem_mesh_get_vertex_list()
const cs_lnum_t* cs_paramedmem_mesh_get_vertex_list ( const cs_paramedmem_coupling_t *  coupling)
pointer to indirection list; NULL if locally contiguous or empty
◆ cs_paramedmem_recv_data()
void cs_paramedmem_recv_data ( cs_paramedmem_coupling_t *  c)
◆ cs_paramedmem_recv_field_vals()
void cs_paramedmem_recv_field_vals ( cs_paramedmem_coupling_t *  c,
const char *  name,
double *  vals
[in]valsarray of values to read
◆ cs_paramedmem_send_data()
void cs_paramedmem_send_data ( cs_paramedmem_coupling_t *  c)
◆ cs_paramedmem_send_field_vals()
void cs_paramedmem_send_field_vals ( cs_paramedmem_coupling_t *  c,
const char *  name,
const double *  vals
[in]valsarray of values to write
◆ cs_paramedmem_sync_dec()
void cs_paramedmem_sync_dec ( cs_paramedmem_coupling_t *  c)
