Include dependency graph for cs_halo_cuda.h:Go to the source code of this file.
| void | cs_halo_cuda_pack_send_buffer (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, cs_lnum_t stride, const void *val, void *send_buffer) |
| Pack cs_real_t halo data to send into dense buffer, using CUDA. More... | |
| void cs_halo_cuda_pack_send_buffer | ( | const cs_halo_t * | halo, |
| cs_halo_type_t | sync_mode, | ||
| cs_datatype_t | data_type, | ||
| cs_lnum_t | stride, | ||
| const void * | val, | ||
| void * | send_buffer | ||
A local state and/or buffer may be provided, or the default (global) state and buffer will be used. If provided explicitely, the buffer must be of sufficient size.
| [in] | halo | pointer to halo structure |
| [in] | sync_mode | synchronization mode (standard or extended) |
| [in] | stride | number of (interlaced) values by entity |
| [in] | var | pointer to value array (device) |
| [out] | send_buffer | pointer to send buffer, NULL for global buffer |
