#include "fvm_nodal.h"
#include "cs_halo.h"
| cs_ctwr_option_t * | cs_get_glob_ctwr_option (void) |
| cs_ctwr_zone_t ** | cs_get_glob_ctwr_zone (void) |
| int * | cs_get_glob_ctwr_n_zones (void) |
| void | cs_ctwr_define (const char zone_criteria[], int z_id, cs_ctwr_zone_type_t zone_type, cs_real_t delta_t, cs_real_t relax, cs_real_t t_l_bc, cs_real_t q_l_bc, cs_real_t xap, cs_real_t xnp, cs_real_t surface, cs_real_t xleak_fac) |
| | Define a cooling tower exchange zone. More...
| void | cs_ctwr_field_pointer_map (void) |
| | Map fields used by the cooling tower module to pointers. More...
| void | cs_ctwr_define_zones (void) |
| | Define zones. More...
| void | cs_ctwr_build_all (void) |
| | Define the cells belonging to the different packing zones. More...
| void | cs_ctwr_all_destroy (void) |
| | Destroy cs_ctwr_t structures. More...
| void | cs_ctwr_log_setup (void) |
| | Log Packing zone definition setup information. More...
| void | cs_ctwr_log_balance (void) |
| | Perform balances in packing zones. More...
| void | cs_ctwr_transport_vars (int iflag) |
| | Convert injected liquid scalars from and to their transported form. More...
| cs_ctwr_zone_t * | cs_ctwr_by_id (int ct_id) |
◆ cs_ctwr_model_t
Type of cooling tower model
| Enumerator |
| CS_CTWR_NONE | no cooling tower model
| CS_CTWR_POPPE | Poppe's model
| CS_CTWR_MERKEL | Merkel's model
◆ cs_ctwr_zone_type_t
Type of cooling tower exchange zone
| Enumerator |
| CS_CTWR_COUNTER_CURRENT | counter-current zone
| CS_CTWR_CROSS_CURRENT | cross-current zone
| CS_CTWR_INJECTION | water injection zone
◆ cs_ctwr_all_destroy()
| void cs_ctwr_all_destroy |
void |
◆ cs_ctwr_build_all()
| void cs_ctwr_build_all |
void |
◆ cs_ctwr_by_id()
| cs_ctwr_zone_t* cs_ctwr_by_id |
int |
ct_id | ) |
◆ cs_ctwr_define()
| void cs_ctwr_define |
const char |
zone_criteria[], |
int |
z_id, |
cs_ctwr_zone_type_t |
zone_type, |
cs_real_t |
delta_t, |
cs_real_t |
relax, |
cs_real_t |
t_l_bc, |
cs_real_t |
q_l_bc, |
cs_real_t |
xap, |
cs_real_t |
xnp, |
cs_real_t |
surface, |
cs_real_t |
xleak_fac |
- Parameters
| [in] | zone_criteria | zone selection criteria |
| [in] | z_id | z_id if zone already created (-1 otherwise) |
| [in] | zone_type | exchange zone type |
| [in] | delta_t | imposed delta temperature delta between inlet and oulet of the zone |
| [in] | relax | relaxation of the imposed delta temperature |
| [in] | t_l_bc | liquid water temperature at the inlet |
| [in] | q_l_bc | mass flow rate at the inlet |
| [in] | xap | beta_x_0 of the exchange law |
| [in] | xnp | exponent n of the exchange law |
| [in] | surface | total Surface of ingoing water |
| [in] | xleak_fac | leakage factor (ratio of outlet/inlet flow rate) |
| [in] | zone_criteria | zone selection criteria (or NULL) |
| [in] | delta_t | imposed delta temperature delta between inlet and outlet of the zone |
◆ cs_ctwr_define_zones()
| void cs_ctwr_define_zones |
void |
Define zones.
Define zones.
TODO rename this: definition (at setup stage) and build (instanciation on actual mesh are not the same).
◆ cs_ctwr_field_pointer_map()
| void cs_ctwr_field_pointer_map |
void |
◆ cs_ctwr_log_balance()
| void cs_ctwr_log_balance |
void |
◆ cs_ctwr_log_setup()
| void cs_ctwr_log_setup |
void |
◆ cs_ctwr_transport_vars()
| void cs_ctwr_transport_vars |
int |
iflag | ) |
- Parameters
| [in] | iflag | 1: Convert transported variables to physical variables 2: Convert physical variables to transported variables |
◆ cs_get_glob_ctwr_n_zones()
| int* cs_get_glob_ctwr_n_zones |
void |
◆ cs_get_glob_ctwr_option()
◆ cs_get_glob_ctwr_zone()
| cs_ctwr_zone_t** cs_get_glob_ctwr_zone |
void |
◆ cs_glob_ctwr_option
