Set of functions to handle the interface with the MUMPS library to solve sparse linear system with a direct approach. More...
#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <float.h>#include <math.h>#include <dmumps_c.h>#include <smumps_c.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_array.h"#include "cs_base.h"#include "cs_log.h"#include "cs_fp_exception.h"#include "cs_halo.h"#include "cs_matrix.h"#include "cs_matrix_default.h"#include "cs_parall.h"#include "cs_timer.h"#include "cs_sles.h"#include "cs_sles_mumps.h"
Include dependency graph for cs_sles_mumps.c:Functions | |
| void | cs_user_sles_mumps_hook (const cs_param_sles_t *slesp, void *context, void *pmumps) |
| Function pointer for advanced user settings of a MUMPS solver. This function is called two times during the setup stage. More... | |
| cs_sles_mumps_t * | cs_sles_mumps_define (int f_id, const char *name, const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| Define and associate a MUMPS linear system solver for a given field or equation name. More... | |
| cs_sles_pc_t * | cs_sles_mumps_pc_create (const cs_param_sles_t *slesp) |
| Create a preconditioner structure relying on MUMPS solver. More... | |
| cs_sles_mumps_t * | cs_sles_mumps_create (const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| Create MUMPS linear system solver info and context. More... | |
| void * | cs_sles_mumps_copy (const void *context) |
| Create MUMPS linear system solver info and context based on existing info and context. More... | |
| void | cs_sles_mumps_free (void *context) |
| Free MUMPS linear equation solver setup context. More... | |
| void | cs_sles_mumps_destroy (void **context) |
| Destroy MUMPS linear system solver info and context. More... | |
| void | cs_sles_mumps_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup MUMPS linear equation solver. More... | |
| cs_sles_convergence_state_t | cs_sles_mumps_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Call MUMPS linear equation solver. More... | |
| void | cs_sles_mumps_log (const void *context, cs_log_t log_type) |
| void | cs_sles_mumps_library_info (cs_log_t log_type) |
| Print information on MUMPS library. More... | |
| void* cs_sles_mumps_copy | ( | const void * | context | ) |
| [in] | context | pointer to reference info and context (actual type: cs_sles_mumps_t *) |
| cs_sles_mumps_t* cs_sles_mumps_create | ( | const cs_param_sles_t * | slesp, |
| cs_sles_mumps_setup_hook_t * | setup_hook, | ||
| void * | context | ||
| [in] | slesp | pointer to a cs_param_sles_t structure |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
| cs_sles_mumps_t* cs_sles_mumps_define | ( | int | f_id, |
| const char * | name, | ||
| const cs_param_sles_t * | slesp, | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_mumps_create.
Note that this function returns a pointer directly to the sparse direct solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
| void cs_sles_mumps_destroy | ( | void ** | context | ) |
| [in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t **) |
| void cs_sles_mumps_free | ( | void * | context | ) |
| [in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
| void cs_sles_mumps_library_info | ( | cs_log_t | log_type | ) |
| void cs_sles_mumps_log | ( | const void * | context, |
| cs_log_t | log_type | ||
| [in] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
| cs_sles_pc_t* cs_sles_mumps_pc_create | ( | const cs_param_sles_t * | slesp | ) |
| void cs_sles_mumps_setup | ( | void * | context, |
| int | verbosity | ||
| cs_sles_convergence_state_t cs_sles_mumps_solve | ( | void * | context, |
| int | verbosity, | ||
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residual, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors | ||
| [in] | a | matrix |
| void cs_user_sles_mumps_hook | ( | const cs_param_sles_t * | slesp, |
| void * | context, | ||
| void * | pmumps | ||
One can recover the MUMPS step through the "job" member. MUMPS_JOB_ANALYSIS or MUMPS_JOB_FACTORIZATION
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that structure should not be temporary (i.e. local);
| [in] | slesp | pointer to the related cs_param_sles_t structure |
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | pmumps | pointer to DMUMPS_STRUC_C or SMUMPS_STRUC_C struct. |
