| void | cs_cell_segment_intersect_select (void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids) |
| | Select cells cut by a given segment. More...
| void | cs_cell_polyline_intersect_select (void *input, cs_lnum_t n_points, cs_lnum_t *n_cells, cs_lnum_t **cell_ids, cs_real_t **seg_c_len) |
| | Select cells cut by a line composed of segments. More...
| void | cs_cell_segment_intersect_probes_define (void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s) |
| | Define probes based on the centers of cells intersected by a given segment. More...
| void | cs_b_face_criterion_probes_define (void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s) |
| | Define a profile based on centers of faces defined by a given criterion. More...
| cs_real_t | cs_post_turbomachinery_head (const char *criteria_in, cs_mesh_location_type_t location_in, const char *criteria_out, cs_mesh_location_type_t location_out) |
| | Compute the head of a turbomachinery (total pressure increase) More...
| cs_real_t | cs_post_moment_of_force (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_t axis[3]) |
| | Compute the magnitude of a moment of force torque) given an axis and the stress on a specific boundary. More...
| void | cs_post_stress_tangential (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_3_t stress[]) |
| | Compute tangential stress on a specific boundary. More...
| void | cs_post_b_pressure (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_t pres[]) |
| | Compute pressure on a specific boundary region. More...
| void | cs_post_b_total_pressure (cs_lnum_t n_b_faces, const cs_lnum_t b_face_ids[], cs_real_t pres[]) |
| | Compute total pressure on a specific boundary region. More...
| void | cs_post_evm_reynolds_stresses (cs_field_interpolate_t interpolation_type, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_3_t *coords, cs_real_6_t *rst) |
| | Compute Reynolds stresses in case of Eddy Viscosity Models. More...
| void | cs_post_anisotropy_invariant (cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t coords[][3], cs_real_2_t inv[]) |
| | Compute the invariant of the anisotropy tensor. More...
| void | cs_post_boundary_flux (const char *scalar_name, cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[], cs_real_t b_face_flux[]) |
| | Compute scalar flux on a specific boundary region. More...
| void | cs_post_field_cell_to_b_face_values (const cs_field_t *f, cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[], cs_real_t *b_val) |
| | Compute values at a selection of boundary faces of a given field located on cells. More...
| cs_real_t | cs_post_scalar_boundary_integral (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| | Compute the surface integral of a scalar array of values located on boundary faces over a selection of boundary faces. More...
| cs_real_t | cs_post_bnd_scalar_boundary_integral (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| | Compute the surface integral over a selection of boundary faces for a scalar array of values located over the selection. More...
| cs_real_t | cs_post_scalar_boundary_mean (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| | Compute the surface mean of a scalar array of values located on boundary faces over a selection of boundary faces. Weighting is done using total surface of boundary faces. More...
| cs_real_t | cs_post_bnd_scalar_boundary_mean (const cs_real_t *scalar_vals, const cs_lnum_t n_loc_b_faces, const cs_lnum_t b_face_ids[]) |
| | Compute the surface mean over a selection of boundary faces for a scalar array of values located over the selection. Weighting is done using total surface of boundary faces. More...
| cs_real_t | cs_post_scalar_b_zone_integral (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| | Compute the surface integral of a scalar array of values located on boundary faces over a boundary zone. More...
| cs_real_t | cs_post_bnd_scalar_b_zone_integral (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| | Compute the surface integral of a scalar over a boundary zone faces, for an array of values located on the zone's faces. More...
| cs_real_t | cs_post_scalar_b_zone_mean (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| | Compute the surface mean of a scalar array of values located on boundary faces over a boundary zone. Weighting is done using total surface of boundary faces. More...
| cs_real_t | cs_post_bnd_scalar_b_zone_mean (const cs_zone_t *z, const cs_real_t *scalar_vals) |
| | Compute the surface mean of a scalar over a boundary zone faces, for an array of values located on the zone's faces. Weighting is done using total surface of boundary faces. More...
This selection function may be used as an elements selection function for postprocessing.
In this case, the input points to a real array containing the segment's start and end coordinates.
Note: the input pointer must point to valid data when this selection function is called, so either:
- that value or structure should not be temporary (i.e. local);
- post-processing output must be ensured using cs_post_write_meshes() with a fixed-mesh writer before the data pointed to goes out of scope;
The caller is responsible for freeing the returned cell_ids array. When passed to postprocessing mesh or probe set definition functions, this is handled automatically.
- Deprecated:
- Use cs_mesh_intersect_polyline_cell_select (rename) instead.
- Parameters
| [in] | input | pointer to segments starts and ends: [x0, y0, z0, x1, y1, z1] |
| [in] | n_points | number of vertices in the polyline |
| [out] | n_cells | number of selected cells |
| [out] | cell_ids | array of selected cell ids (0 to n-1 numbering) |
| [out] | seg_c_len | array of length of the segment in the selected cells |
This selection function may be used as a probe set definition function for postprocessing.
- Deprecated:
- : higher-level cs_probe_set_create_from_segment function with n_probes argument set at 0 or lower includes equivalent function.
- Parameters
| [in] | input | pointer to segment start and end: [x0, y0, z0, x1, y1, z1] |
| [out] | n_elts | number of selected coordinates |
| [out] | coords | coordinates of selected elements. |
| [out] | s | curvilinear coordinates of selected elements |
| void cs_cell_segment_intersect_select |
void * |
input, |
cs_lnum_t * |
n_cells, |
cs_lnum_t ** |
cell_ids |
- Deprecated:
- Use cs_mesh_intersect_segment_cell_select (rename) instead.
- Parameters
