#include "cs_defs.h"#include <assert.h>#include <stdlib.h>#include <string.h>#include <bft_error.h>#include <bft_mem.h>#include <bft_printf.h>#include "cs_fp_exception.h"#include "cs_log.h"#include "cs_math.h"#include "cs_multigrid.h"#include "cs_sles.h"#include "cs_param_sles.h"
Include dependency graph for cs_param_sles.c:Functions | |
| static bool | _system_should_be_sym (cs_param_itsol_type_t solver) |
| Return true if the prescribed solver implies a symmetric linear system. More... | |
| static void | _check_settings (cs_param_sles_t *slesp) |
| Check if the settings are consistent. Can apply minor modifications. More... | |
| static int | _get_poly_degree (const cs_param_sles_t *slesp) |
| Retrieve the value of the polynomial degree to consider according to the settings. Only for in-house solvers. More... | |
| static void | _set_saturne_sles (bool use_field_id, cs_param_sles_t *slesp) |
| Set parameters for initializing SLES structures used for the resolution of the linear system. Case of saturne's own solvers. More... | |
| static void | _set_mumps_sles (bool use_field_id, cs_param_sles_t *slesp) |
| Set parameters for initializing SLES structures used for the resolution of the linear system. Case of MUMPS's own solvers. More... | |
| static void | _set_petsc_hypre_sles (bool use_field_id, cs_param_sles_t *slesp) |
| Set parameters for initializing SLES structures used for the resolution of the linear system. Case of PETSc and Hypre families of solvers. More... | |
| static cs_param_sles_mumps_t * | _create_mumps_param (bool is_single, cs_param_sles_facto_type_t facto_type) |
| Create a new structure storing a set of parameters used when calling MUMPS. Set a default value for the advanced parameters. More... | |
| static cs_param_sles_mumps_t * | _copy_mumps_param (const cs_param_sles_mumps_t *mumpsp) |
| Copy into a new structure the given set of parameters used when calling MUMPS. More... | |
| static void | _log_mumps_param (const char *name, const cs_param_sles_mumps_t *mumpsp) |
| Log a set of parameters used when calling MUMPS. More... | |
| cs_param_sles_saddle_t * | cs_param_sles_saddle_create (void) |
| Create a cs_param_sles_saddle_t structure and assign a minimalist default settings. More... | |
| void | cs_param_sles_saddle_init_schur (const char *basename, cs_param_sles_saddle_t *saddlep) |
| Initialize a cs_param_sles_t structure for the Schur approximation nested inside a ref cs_param_sles_saddle_t structure. By default, this member is not allocated. Do nothing if the related structure is already allocated. More... | |
| void | cs_param_sles_saddle_copy (const cs_param_sles_saddle_t *ref, cs_param_sles_saddle_t *dest) |
| Copy a cs_param_sles_saddle_t structure from ref to dest. More... | |
| void | cs_param_sles_saddle_free (cs_param_sles_saddle_t **p_saddlep) |
| Free the structure storing the parameter settings for a saddle-point system. More... | |
| cs_param_sles_t * | cs_param_sles_create (int field_id, const char *system_name) |
| Create a cs_param_sles_t structure and assign a default settings. More... | |
| void | cs_param_sles_free (cs_param_sles_t **p_slesp) |
| Free a cs_param_sles_t structure. More... | |
| void | cs_param_sles_log (cs_param_sles_t *slesp) |
| Log information related to the linear settings stored in the structure. More... | |
| void | cs_param_sles_copy_from (cs_param_sles_t *src, cs_param_sles_t *dst) |
| Copy a cs_param_sles_t structure from src to dst. More... | |
| int | cs_param_sles_set (bool use_field_id, cs_param_sles_t *slesp) |
| Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver) More... | |
| void | cs_param_sles_mumps (cs_param_sles_t *slesp, bool is_single, cs_param_sles_facto_type_t facto_type) |
| Set the main memebers of a cs_param_sles_mumps_t structure. This structure is allocated if needed. Other members are kept to their values. More... | |
| void | cs_param_sles_mumps_advanced (cs_param_sles_t *slesp, cs_param_sles_analysis_algo_t analysis_algo, int block_analysis, double mem_coef, double blr_threshold, int ir_steps, bool advanced_optim) |
| Set the main memebers of a cs_param_sles_mumps_t structure. This structure is allocated if needed. Other members are kept to their values. Please refer to the MUMPS user guide for more details about the following advanced options. More... | |
| void | cs_param_sles_update_cvg_settings (bool use_field_id, const cs_param_sles_t *slesp) |
| Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param_sles_t structure. This function is used only when a first setup has been performed. More... | |
| cs_param_sles_class_t | cs_param_sles_get_class_from_amg (cs_param_amg_type_t amg_type) |
| Retrieve the related solver class from the amg type. More... | |
| cs_param_sles_class_t | cs_param_sles_check_class (cs_param_sles_class_t wanted_class) |
| Check the availability of a solver library and return the requested one if this is possible or an alternative or CS_PARAM_SLES_N_CLASSES if no alternative is available. More... | |
| void | cs_param_sles_check_amg (cs_param_sles_t *slesp) |
| Check if the setting related to the AMG is consistent with the solver class. More... | |
static |
| [in,out] | slesp | pointer to a cs_param_sles_t structure |
static |
| [in] | mumpsp | set of mumps parameters |
static |
| [in] | is_single | single-precision or double-precision |
| [in] | facto_type | type of factorization to consider |
static |
| [in] | slesp | pointer to a cs_param_sles_t structure |
static |
| [in] | name | name related to the current SLES |
static |
| [in] | use_field_id | if false use system name |
static |
static |
inlinestatic |
| void cs_param_sles_check_amg | ( | cs_param_sles_t * | slesp | ) |
| [in,out] | slesp | pointer to a cs_pparam_sles_t structure |
| cs_param_sles_class_t cs_param_sles_check_class | ( | cs_param_sles_class_t | wanted_class | ) |
| [in] | wanted_class | requested class of solvers |
| void cs_param_sles_copy_from | ( | cs_param_sles_t * | src, |
| cs_param_sles_t * | dst | ||
| [in] | src | reference cs_param_sles_t structure to copy |
| [in,out] | dst | copy of the reference at exit |
| cs_param_sles_t* cs_param_sles_create | ( | int | field_id, |
| const char * | system_name | ||
| [in] | field_id | id related to to the variable field or -1 |
| [in] | system_name | name of the system to solve or NULL |
| void cs_param_sles_free | ( | cs_param_sles_t ** | p_slesp | ) |
| [in,out] | slesp | pointer to a \cs_param_sles_t structure to free |
| cs_param_sles_class_t cs_param_sles_get_class_from_amg | ( | cs_param_amg_type_t | amg_type | ) |
| [in] | amg_type | type of AMG to consider |
| void cs_param_sles_log | ( | cs_param_sles_t * | slesp | ) |
| [in] | slesp | pointer to a cs_param_sles_log |
| void cs_param_sles_mumps | ( | cs_param_sles_t * | slesp, |
| bool | is_single, | ||
| cs_param_sles_facto_type_t | facto_type | ||
| void cs_param_sles_mumps_advanced | ( | cs_param_sles_t * | slesp, |
| cs_param_sles_analysis_algo_t | analysis_algo, | ||
| int | block_analysis, | ||
| double | mem_coef, | ||
| double | blr_threshold, | ||
| int | ir_steps, | ||
| bool | advanced_optim | ||
| [in] | analysis_algo | algorithm used for the analysis step |
| [in] | block_analysis | < 0: fixed block size; 0: nothing |
| [in] | mem_coef | percentage increase in the memory workspace |
| [in] | blr_threshold | Accuracy in BLR compression (< 0: not used) |
| [in] | ir_steps | 0: No, otherwise number of iterations |
| [in] | advanced_optim | activate advanced optimization (MPI/openMP) |
| void cs_param_sles_saddle_copy | ( | const cs_param_sles_saddle_t * | ref, |
| cs_param_sles_saddle_t * | dest | ||
| [in] | ref | reference structure to be copied |
| [in,out] | dest | destination structure |
| cs_param_sles_saddle_t* cs_param_sles_saddle_create | ( | void | ) |
| void cs_param_sles_saddle_free | ( | cs_param_sles_saddle_t ** | p_saddlep | ) |
| [in,out] | p_saddlep | double pointer to the structure to free |
| void cs_param_sles_saddle_init_schur | ( | const char * | basename, |
| cs_param_sles_saddle_t * | saddlep | ||
| [in] | basename | prefix for the naming of the Schur system |
| [in,out] | saddlep | pointer to the structure to update |
| int cs_param_sles_set | ( | bool | use_field_id, |
| cs_param_sles_t * | slesp | ||
| [in] | use_field_id | if false use system name to define a SLES |
| void cs_param_sles_update_cvg_settings | ( | bool | use_field_id, |
| const cs_param_sles_t * | slesp | ||
One modifies only some specific options like the max. number of iterations or the relative tolerance
| [in] | use_field_id | if false use a name to retrieve the cs_sles_t struc. |
